Question about Bushnell Yardage Pro 600 Rangefinder
Sight target needs adjustment
When i look through the viewfinder the displays are too high. I can barely see the target strength meter at the top it's so high. Naturally, when i put a target in the cross hairs the yardage isn't close to being right because the aim is off.
  • 3 more comments
  • Anonymous Dec 13, 2007
    I have exactly the same problem. The only way to use the unit is to put he target at the center of the bottom of the vertical line of the cross hair. Not an effective solution but it works for the meantime. I've bought the Pinseeker 1500 since but the problem should not be happening with a Bushnell product.
  • mavero Dec 25, 2007
    range finder gives more than one yardage..
  • Anonymous Jan 05, 2008
    I have the same problem. It is as if the screen holding the information has slipped and no longer lines up correctly in the view finder. Is their a way to open the unit up and reset the screen?
  • rayegg Jul 17, 2008
    I had the same problem and wrote to Bushnell asking for help.  I got no response at all (yes, I am unhappy.)  So I carefully peeled back the rubber sheet glued over the plastic case at the thumb grip area (it is only glued at the edges.)  With the rubber pealed back a little you can see the two screws at each side that hold the two **** shell halves together.  With the **** shell halves opened up, I could see the ribbon cable attached to the LCD on the center lens path was held in place with cellophane tape (not very high tech, I thought.)  The tape had dried out and broken, allowing the ribbon cable and LCD to float out of position.  A little new tape and all was well.  Be very careful with the ribbon cable/LCD as it is very fragile.  Although my unit was out of the warranty period, I still would not have opened it up if Bushnell had bothered to respond to my letter requesting help and instructions.  As it was, I thought I had nothing to lose by trying my own repair.
  • skibuoy Dec 15, 2008
    Displays in viewfinder too high. Range seems to be accurate if position target at base of vertical cross hair line.
I also had the same problem my Yardage Pro Compact 600. We live in the desert and I often leave my golf bag in the trunk of the car. One day the display on the rangefinder was shifted up so I assumed that the heat affected something. After checking with Bushnell, their answer was to ship it in and couldn't guarantee a cost.
So I also peeled back the rubber grips from the bottom - you only need to go far enough to unscrew the four screws. From there you have to snap apart the case so the top shell comes off (be sure to remove the battery and cover first). Once you've done that, unscrew the top circuit board (mine only had 2 of the 4 screws from the factory). Be careful not to unplug any of the 3 ribbon cables.
Move the top circuit board aside. Looking from the top front, there is an assembly at the back that holds the laser/reader, it is held in by 3 screws, 2 on the back left and 1 on the back right - remove them. Carefully remove the assembly leaving the 2 ribbon cables in tact. The 3rd (largest) ribbon cable is taped to the center sighting barrel. Gently remove the tape, the ribbon cable disappears into a **** in the back of the sighting barrel near the eyepiece, it is connected to the LCD display. Now flip the unit around and looking from the back eyepiece, remove the 2 screws near the ribbon cable. Now you should be able to lift the eyepiece up and away from the sighting barrel.
The ribbon cable and LCD window at the end of the cable should be glued on two corners inside the eyepiece (worse case the LCD is loose as mine was because the glue had deteriorated). First scrap out the old glue from the LCD and eyepiece frame, being careful to not let the remnants drop inside the eyepiece or you will see these in the viewfinder once you get it back together!
Using thick superglue and being careful not to touch the LCD and leave a smudge (or forget how it came out as your yardage display will be backwards!), put a tiny drop of glue on each lower corner of the eyepiece frame. Now carefully position the LCD window and push down to the bottom of the eyepiece frame. Try to center it left to right as near as possible (mine had a little gap on each side) while holding the LCD against the bottom edge. Keep it there until the glue dries.
Now reassemble everything, making sure the sighting barrel and especially the laser/reader assembly fits snugly in its cradle before reinstalling the 3 screws, then install the top circuit board. Snap the top cover back on and before putting the 4 cover screws in, put in the battery/cover and test it. Remember if your display is reversed you installed the LCD backwards!
Posted on Mar 18, 2009
SOURCE:
My rifle is shooting about five inches high. Do I turn the elevation adjustment towards "up" or opposite of "up"?
If you have a scope, the adjustment is under the top cap, and you should turn the adjustment 'down'. If you have iron sights, you would adjust the rear sight in the same direction that you want to move the bullet on the target (also 'down'). The opposite is true if you are adjusting the front sight.
Dec 26, 2014 | Optics
Tip
Sight in your scope
I have given this tip to a dozen people this week. It will save you a ton of ammo. If you don't have a bore sighter of access to one, get a big cardboard box, cut V's in the top that the rifle will sit in nicely, remove the bolt. Find a target, 100 yards away, sight down the bore, tilt box, rifle to target, make sure it doesn't move, adjust scope to the same target. check to see if the rifle is still on, then check the scope again. This will put you on paper at 100 yards.
on Feb 17, 2010 | Optics
How to sight in crosman extreme g1 pellet rifle scope
You would sight in an air rifle scope in the same manner as any other standard scope that you might find on a rifle:
You want to secure the rifle as best you can with the sights pointed towards a target, which should be set at the desired distance.
Reduce the error of your sight adjustments either by mounting the rifle in a gun mount or simply resting the stock (not the barrel!) on a solid surface such as a table.
Make sure that the weight of the rifle is carefully supported and the **** is firmly pressed into your shoulder. Looking through the sights, aim at the very center of the target (which for your purposes can be as simple as a piece of paper with a dot drawn in the middle).
Take time to ensure a careful shot, and be sure to avoid any shaking, utilizing the support of the mount/table (try resting the fore-grip of the stock on a roll of paper towels if you're having trouble keeping the rifle steady).
Once you are confident with the placement of the cross-hairs over the center of the target, gently squeeze (don't pull) the trigger.
Determine where the pellet struck the target, and adjust the scope accordingly; while every scope is a little different, the same basic principles for adjustment apply. Unscrew the caps on the top and side of the scope, and carefully read the markings on the adjustment dials.
If the pellet struck low, twist the dial on the top of the scope 'up' (the markings should specify clockwise/counter), and if the pellet struck high, twist in the opposite direction. If the pellet struck to the left or right, follow the same procedure for the dial on the side of the scope.
If the pellet struck low and to the side, make the vertical (up/down) adjustments first, repeat the shot, and only move on to make adjustments left/right once the pellet strikes in vertical alignment with the center of the target.
Take your time, and adjust in increments of only 2-3 clicks to start. Repeat the procedure until the pellets are striking consistently in the center of the target (if you're having a hard time remembering which shot went where, replace the target and continue.
Once you are satisfied with placement of your shot groupings on the targets, replace the dial covers on the scope.
Tips and Notes:
- In order to maintain the accuracy of your rifle, try to avoid resting the rifle on its scope and try to prevent the barrel from contact.
- Take note of your rifle's range, and be aware that the further away you place the target, the less consistent your results will be.
- Be realistic; don't attempt to sight in an air rifle at 50 yards. Remember that even with a rifle that has been professionally sighted, good results still come down to the accuracy of the shooter.
-Sight in your rifle at a range where you are confident in your own abilities; start with a closer target and only move back (i.e. sight in at a greater distance) if necessary.
Further Instruction:
http://www.chuckhawks.com/sight-in_rifle.htm
http://www.youtube.com/watch?v=lLirsAFpsfE
May 05, 2011 | Sport & Outdoor - Others
My Weaver Classic riflescope is maxxed out for elevation
I don't think the tube holding the cross hairs will go up that high, and shimming the front base, I don't know. What you need is a new cross hair with the dots below the cross, They will raise your line of sight past the 350 zero. Or,,,,, just put the cross at the top of your target, 600 yards without the right scope is a long shot. I hope you have a heavy barrel target rifle in 308 or bigger. My M42 is unbelievable, but, It will shoot better than me all day long and I rarely go over 200 yards. I tried the 600 yard line once, didn't like it. Oh I could hit the target, but I like hitting doorknobs at 200 yards better. What are you shooting anyway? I hope your not trying to stretch out a 223 to the max.
Mar 01, 2010 | Bushnell BANNER RIFLE SCOPEPower: 3-9X40 /...
Mamiya 645 ADF viewfinder/meter issues...
You likely have a defective display module, probably with a dead back-light. Try putting a newly charged battery in it, but if the problem persists, you'll need to send it in for service.
Aug 04, 2017 | Mamiya 645AF Medium Format Camera
How to reset to zero a Tasco RF3- 7X20 Scope? I am having prblems centering this scope Thank You
Making sure it is correctly fitted to the rifle, you Bore sight it. Best to put it into a vice using a thick piece of blanket to protect the rifle. Looking through the bore you line it up on an object about 10 to 20 meters away. Then you adjust the scope to fix the crosshairs on that same object. This will get you approximately on target. Depending on what a where you are going to shoot, assuming you are using a rimfire rifle, You then set up a target about 30 to 35 meters away. And adjust your scope to center on this target. That will give you dead aim at 30 meters and again at 90 meters, with only a slight variation in height in the middle.
Feb 04, 2010 | Tasco RF37X20D 3-7x20 Rimfire Riflescope -...
Windage and elevation adjustment all over the place
Sounds like you want to "re-sight" in your rifle. Make sure mounts are okay and tight. Look down barrel and then thru scope and eyeball windage and elevation adjustments so the scope seems to be fairly in line.
Clean barrel if it needs it.
For basic sight in, start at 25 yards with a large(3 to 4 feet) cardboard or wood backdrop around target (bullseye). Fire at target. Once done, look through scope and position rifle such that the shot mark you created is dead zero. Hold rifle very steady and you or buddy move windage and elevation adjustments until scope moves dead zero back toward original target (bullseye). Fine tune from there. Air cool rifle between rounds. Once dead eye, fire another round or two to check grouping. Check your ballistics (sometimes on ammo box) to see how height at 25 yards affects your desired dead on target (100 yards, 150 yards, 250 yards etc.). Adjust accordingly. Example: you may need to sight in at an inch high at 25 yards, depending on your dead on target distance..
Always remove sling from barrel when sighting in.
Try to sight in at similar temperature as you intended shooting temperatures, if possible.
If not black powder, avoid cleaning barrel between sight in and hunt/competition unless you note bad buildup inside.
If you change ammo, understand that that may affect performance. Once a preferred ammo is found, some even try to buy a decent quantity with the same lot number on the boxes if storage allows for such.
May 02, 2009 | Optics
Viewfinder of Sony DSC-H2 does not work anymore
Viewfinder has focus lever at bottom, please adjust viewfinder internal focus as per your eye sight looking on-screen display. Every thing will be fine after that.
Feb 04, 2009 | Sony Cyber-shot DSC-H2 Digital Camera
Different shutter speed on top lcd & viewfinder display
Even moving your eye away from the viewfinder can potentially change the amount of light entering the exposure meter, so even if the camera is on a tripod, if AE lock isn't on or manual mode selected, the exposure setting may change.
Sep 08, 2005 | Pentax *ist D Digital Camera
Bushnell Yardage Pro 600 Rangefinder Logo
285 people viewed this question
Top Bushnell Optics Experts
Steve Allison
Steve Allison
Ekse
Goldi Kunal
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
