Question about Ridgid Saws
R 4511 blade elevator rack and pinion keeps stripping
3 Suggested Answers
  • 384 Answers
SOURCE: The blade will no longer raise or lower on my Jet
Make sure the set screws in the handle and gear are clamping against the shaft..
Posted on Jun 17, 2009
SOURCE: Stripped rack for elevation adjustment
Possibly from Orion. Call them:
http://www.telescope.com/control/main/
Posted on Aug 30, 2009
Power steering hose keeps breaking, even when replaced by high pressure hoses. Replacing rack and pinion does not help either.
A bad seal in the rack and pinion would have caused low pressure from fluid by-passing the seal. This also would have caused noticeably increased effort to steer the vehicle. Excessively high pressure would indicate an issue between the power steering pump and the rack, and since the hoses have been replaced I would focus on the pump. PS, find a real mechanic, not a parts changer.
Apr 06, 2014 | 2001 Chrysler Town & Country
What makes your tires not move when u turn your steering wheel on a 1999 chrysler 300 m
gear stripped at steering wheel to shaft, stripped steering gear at the rack n pinion. Inspect steering shaft and connections.
CHeck here first:
I doubt its here, but if not anywhere else, check here:
Dec 08, 2013 | 1999 Chrysler 300M
Bevel gears are worn
Most common repair for this saw
1) remove blade & blade housing guard plate
2) You will find 2 allen head screws holding the elevating screw bracket
This will allow you to move the gears apart to replace
Remove the small retaining ring and slide the gear off (be careful not to lose the woodruff key when you slide the gear off)
Typically we find that the 2 rods (elevating shafts) are bent and this causes the resistance that strips the gears out - I always replace the 2 rods and the elevating screw when replacing the gears - you already have it apart and the parts are inexpensive.
Aug 31, 2013 | Dewalt Saws
How to remove rack and pinion from 99 chrysler lhs
There are few help links showing exact accurate procedure to replace Rack and Pinion. Click the link below and follow the procedure:-----
Pinion Seal Replace on Dodge Dakota? http://howtobyme.blogspot.in/2012/04/pinion-seal-replace-on-dodge-dakota.html
How to Replace a Rear Pinion Seal.
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-rear-pinion-seal.html
How to replace Power steering rack and pinion gear on Chevy Silverado 2500 HD? http://technoanswers.blogspot.in/2012/02/how-to-replace-power-steering-rack-and.html
How to replace Power Rack and Pinion Steering Gear on Acura Car Models? http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-power-rack-and-pinion.html
How to replace power rack and pinion steering gear on Toyota cruiser? http://repairhelpcenter.blogspot.in/2012/02/how-to-replace-power-rack-and-pinion.html
Front Drive Pinion Seal Removal on Ford Explorer? http://repairhelpcenter.blogspot.in/2012/03/front-drive-pinion-seal-removal-on-ford.html
How to Replace Driveshaft, Pinion Flange & Seal?
http://repairhelpcenter.blogspot.in/2012/03/how-to-replace-driveshaft-pinion-flange.html
How to Replace Power Rack & Pinion Steering Gear On 2007 Ford Taurus? http://repairhelpcenter.blogspot.in/2012/03/how-to-replace-power-rack-pinion.html
How to Remove Power Rack & Pinion Steering Gear on Ford Windstar? http://repairhelpcenter.blogspot.in/2012/03/how-to-remove-power-rack-pinion.html
Power Rack & Pinion Steering Gear replacing details for Buick Park Avenue and Pontiac Bonneville
http://repairhelpcenter.blogspot.in/2012/03/power-rack-pinion-steering-gear.html
How to Replace Power Rack & Pinion Steering Gear on Mercedes Benz Truck? http://howtobyme.blogspot.in/2012/03/how-to-replace-power-rack-pinion.html
How to replace Power Rack & Pinion Steering Gear on Toyota 4Runner? http://howtobyme.blogspot.in/2012/03/how-to-replace-power-rack-pinion_27.html
Power Rack & Pinion Steering Gear Replacing on Toyota Land Cruiser & Sequoia? http://schematicsdiagram.blogspot.in/2012/03/power-rack-pinion-steering-gear.html
Power Rack & Pinion Steering Gear Removal on Toyota RAV4? http://repairhelpcenter.blogspot.in/2012/03/power-rack-pinion-steering-gear-removal.html
How to Replace Power Rack & Pinion Steering Gear on Toyota Sienna? http://technoanswers.blogspot.in/2012/03/how-to-replace-power-rack-pinion.html
These details will help.
Thanks.
Nov 23, 2012 | Cars & Trucks
Stuck in elevated
RUN the software calibration for diagnostic, troubleshooting and fix it.
However try to lube the motor , rack, and pinion, adjust the POT, and fix it. see the diagrams
God bless you
Oct 16, 2012 | Matrix T3x Treadmill Deck Treadbed Parts
Incline is stuck in the up position
LUBE the elevation motor: rack+pinion and the motor +try to adjust the POT see the picture+ diagram
However RUN the software calibration for diagnostic, troubleshooting, and fix it.
God bless you
Sep 29, 2012 | Nordic Track Nordictrack Commercial 1300...
My steering wheel just "free-wheels" I have lost all steering capibilities.
sounds like a bad "Rag Joint ', that;s a piece of tire carcass material (a two inch circle at the bottom of the steering collumn) where the steering wheel connects to the rack and pinion(It;s to kill vibration)
It's fairly easy to replace, also easy to get your steering wheel upside down
if the rag joint's good the steering rack and pinion assy must have a stripped gear.
This is rare, check the rag joint firstit's a small ***** to replace but not impossible usualy you have to unbolt the collumn inside the cab (Two bolts under the bottom of the dashboard, there's a cover to remove beneath the stering column)
Sep 13, 2009 | 1996 Ford Ranger SuperCab
Aug 30, 2009 | Orion Optics
I have a minor broken seal on my rack and pinion
There is but it's not going to help, the rack and pinion steering has large amount of pressure on it when you turn the steering wheel. If the seal is bad, sooner not later. The seal will fail and you lose all the power steering fluid and the power steering which can in turn also damage the rack and pinion. The safest and cheapest thing to do is get it repaired before it get's worst and you end up replacing the rack and pinion too. Good luck and keep me posted. be glad to help
Jun 08, 2009 | 2001 Oldsmobile Aurora
Slik Tripod Quick Release Port
http://www.tripodquickrelease.com/Slik_Quick_Releases.htm Has it listed as the part number 6121. It should fit both models.
Oct 31, 2007 | Photography
Saws Logo
26 people viewed this question
Top Ridgid Saws Experts
ken skalski
John Trevino
Are you a Ridgid Saw Expert? Answer questions, earn points and help others
