Question about Mtd 22" Yard Machine Push Mower
Snowblower not engaging leaks oil ?
Snowblower impeller and auger do not engaging I must of hit something hard thru the the machine. I looked down oil was leaking from back ?? what did I do to damage this? mtd yard machine model 32ad 179cc. ohv 4 cycle 22'
  • Horshack May 11, 2010
    It has shear pins that should snap before you do any damage to the power takeoff components. Is there an engagement mechanism for the auger and impeller, or do they run continuously?
HW_Dude
  • 87 Answers
SOURCE: tecumseh 8hp HIGH REVING! snowblower
be careful, if the engine over revs it may just explode. These engines are very picky if over sped and easily blow up.
Your problem may be a broken throttle control rod, have look at that first. If the control rods are fine and in place it could be the fly wheel governor is worn out.
Posted on Jan 10, 2009
  • 5 Answers
SOURCE: oil change
if this model has a fill tube on it- turn the unit on its side to drain.
Posted on Feb 06, 2009
panilling9
  • 284 Answers
SOURCE: Yard Machines 22 inch mower, I dumped it on its
if you bent the blade most likely you bent the crankshaft too.
Remove the spark plug and pull the rope and remove excess oil from the spark plug hole
check the spark plug for spark if you have none then a flywheel key is sheered a more in depth fix.
If you get it started you may notice a whole lota vibration due to a bent crank shaft or maybe not?
Posted on May 25, 2009
  • 32 Answers
SOURCE: where do you drain the oil on a 4 hp yard machine
to drain the oil then you open the oil cap and tip it over and let the oil drain out.
Posted on Jun 12, 2009
  • 420 Answers
SOURCE: MTD Yard Machines 22'' mower, pull cord won't extend
From what you describe it sounds like the line may be tangled, remove the rewind housing in order to inspect the line up close.
Posted on Jun 04, 2010
Auger on snowblower doesn't engage
how do I find good anime movie on Netflix help me fam
Feb 11, 2015 | Mtd Garden
MTD 8/26 snowblower
Either there is a belt or a chain off, or the linkage became disconnected or there is a pin sheared. Take one of the three. If you have power spinning like you said then those are your choices! Best of luck to you. Hope you beat the weather!
Fix ariens snowblower 520 dies when engaging the auger lever
Your front end is jammed. Its either frozen or there is a rock or something jamming it up. Before you start engine reach down chute and turn back impeller that throws the snow out of blower. Should turn freely. when its free its fixed. You will probably need a new belt.
Feb 17, 2014 | Garden
Auger blades are spinning
sound like you might have 2 problems. If auger doesn't engage in heavy snow you probably just have ice accumulation inside the impeller. Dont try to engage until impeller is cleared of snow (shut off and unplug spark plug before cleaning) Second if blades are spinning than you must have hit something in your path and broke the shear bolt (about 2 bucks at hardware shop) remove the old bolt and replace it and it should work again if this is the problem. Good luck.
Feb 05, 2014 | Yard Machines Garden
Continuous clunking when i engage the auger on my snowblower
check for bent blower and auger blades
check rear blower bearing, engine off( grab rear of shaft pull up and down) shouldnt move very much. if it does bearing bad
Dec 28, 2013 | Craftsman 22" 179cc* Dual-Stage Snowblower
Swisher 27" snowblower front impellers turn free
Hi Craig,
Most snowblowers incorporate "shear pins" between the motor and auger. A shear pin looks similar to a nut and bolt or pin that couples the drive to the auger - but it designed to break or shear off to prevent damage to the auger or motor in the event of a jam or overload. They look like these:
Only the shear pin recommended for your particular brand and model snowblower should be used. Under no circumstances should a regular bolt or other steel pin be used instead of a shear pin. Check your manual or consult with Swisher to determine the correct shear pin for your snow blower.
I hope this helps & good luck!
Dec 21, 2012 | Garden
I have an Ariens 1128 Snowblower. Here's the problem, everything seems to function fine, impeller spins, augers spin, howerver, when I put it into any real snow (more than 6-12 inches) the impeller and...
Hi, I will try to help you with this problem. I think the problem might be an adjustment issue. If you take the cover, usually plastic, situated just in front of the engine housing, you will see the belts and pulleys. Without the engine running, press on the auger/impeller lever, and if you look inside you should see how the belt is made to engage the auger pulley. Probably by an idler pulley that pushes on the belt to make it tight to turn the big pulley. That is the most popular way, it is to loosen the bolt on the idler pulley and push it towards the belt so it applies more pressure to the belt to turn the auger pulley and tighten the bolt. There could also be an adjustment on the linkage that might be adjustable. Another possibility is that the belt is worn and is riding on the bottom of the pulleys therefore not providing enough friction to turn the pulleys properly. I think if you take a good look at that system you will comprehend it. Hope this is helpful. All the best and good luck. I will gladly answer any other questions.
Feb 02, 2011 | Garden
I have trs22 john deere snowblower the the impeller turns but the auger does not turn . i think the key is sheard off in the augers transfer case . any one have a detailed diagram or a pdf file for the...
Go to weingartz web page and you will find the diagram and parts you need. I have a TRS22 with the same problem. You will need a worm gear, gasket/gear case, and a shaft key. I need to order the same parts. take appart the auger first you might need more parts
Jan 22, 2011 | John Deere Garden
Ariens snowblower impeller not throwing snow
Sounds like you have a broken or partially broken shear pin in the auger.Check along the auger[machine off]and see if there is what looks like a bolt anywhere along the auger shaft.If there is [and there will be] remove and inspect it and you will see why the auger is not working.Next time,never clean out a chute or auger while the engine is running,people loose limbs this way.
Feb 13, 2010 | Ariens 34 In. Zoom Series Riding Mower
Mtd 22" Yard Machine Push Mower Logo
171 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
