Question about Zonet ZSR1114WE 802.11g 54Mbps Wireless Broadband Router w/4pt Switch Retail
HI, i m facing problem with my internet actually it is wireless when i try to access internet it speed is very slow and there are logging problem in any accounti like yahoo msg yahoo mail gmail etc. could u help me
Well Prob. indicated me that ur massenger need to update once again !
Posted on Jan 19, 2009
I have an issue with Wireless Access Point D-Link DAP 1155 When i'm connected to the internet via WiFi by mobile device (different ones Galaxy Note 1, Galaxy Note 2, Galaxy ACE) when browsing internet is...
Do other wireless laptops connect to your wireless router, and give good speeds? Do you have many wireless networks, other than your own, that show up when you try to connect? It could be interference from other wireless networks in your vicinity.
Aug 21, 2013 | D-Link Computers & Internet
My ipad 2 will connect but the load time is very slow
Your throughput (speed) is limited by the speed of the service from your provider. Additionally, this speed is divided or shared with every device connected via network cable and devices that are connected wirelessly, too.
To make matters worse, while the wireless N standard provides a faster speed, it only does so at a closer distance. When further away from the router, you may actually get better speed by connecting to the G side of the router (assuming you have G enabled).
Proper router configuration is key. Make sure you haven't locked it down to a slow speed. Install additional wireless access points or upgrade antennas with those that offer higher gain to provide good coverage in your home / space. Locate the wireless routers and access points closest to the areas these drevices will likely be used. Avoid installing in basements, behind brick and concrete walls. Aluminum siding can thwart a signal pretty well, too. Unplug / replace cordless phones that run on 2.4GHz - they can rob bandwidth from your router in the form of interference. Select Ch 1, 6 or 11 for the least interference from other wireless devices as long as they are not already in use by someone close by. Protect your WiFi by NOT broadcasting your SSID and be sure to lock it down with WPA or WPA2 security and a password that does not appear in the dictionary. This will help keep others from stealing your WiFi bandwidth.
All of these suggestions will either increase your throughput / speed or provide additional security and prevent others from stealing your bandwidth. I hope they help!
Feb 08, 2013 | D-Link DIR-815 Xtreme N Wireless 802.11N...
Slow internet connection with TP Link router.
im also facing that type of problem on tplink TL_WR340GD
May 27, 2012 | TP-LINK TL-WR740N 150Mbps Wireless Lite N...
Hi i have realtek RTL 8187 wireless adapter, and when i watch in my antenna managing program, connection is quality and signal streght about 80% THATS GOOD. always was good connection, but now yellow and...
somebody is accessing your wireless network and getting free internet service from you unless you had setup a wep security! if you have an un-secure network then anybody with a wireless adapter can access your network and access your internet free and drag down the speed of your internet connection.
however, if you do have wep enabled and there is more than one computer connecting then this will slow your connection down as well. please remember that there are some games and gaming sites that are bandwidth hogs and will slow down other computers connection on the same network. also watching streaming videos and gaming at same time can slow down connections as well.
Aug 25, 2011 | Toshiba Realtek RTL8187B Wireless...
Hi, I'm using a Belkin N1 wireless router. I mostly have a stable internet connection, but once in a while the "wireless" icon start blinking orange. What is this? My internet some times get...
if the wireless light is lit up in red it says "someone is trying to connect to your network using wrong password"
Sometimes if any of your devices are not compatible with the security enabled in the router then the light will lit up in red. click here to know more about security types of belkin router
routers has to be turned off atleast 2 hours per day for it to work properly... so better turn off the router when not in use, this will clear the routing table of your router and will make the router to work as a fresh router everyday, so you wont face any speed problems.
May 03, 2011 | Belkin N1 Wireless-N Wireless Router
I am running hughes net satelite internet on a hughes HN 9000 modem and trying to setup and configure my linksys E3000 wireless router for two hp laptops on direct ethernet connection to our desktop,...
Are you trying to connect the laptops via wireless? Is that where you are seeing 75 mbps? I am assuming you are, and 75 mbps is really not how fast your internet connection is. Rather, that is how fast you are transferring data from your laptop to the wireless router and back. Generally speaking, this should be a way faster connection than your internet is running at. Chances are your internet connection speed is 10 to 20 mbps, which is good and fast.
It is easy to get the two confused, but basically a wireless connection of 75 mbps is an uber fast connection to your wireless router, and only if your actual internet connection was faster than that 75 mbps would you see any slowness due to that.
Wireless N routers are capable of delivering up to 100 mbps connection speeds, but again that is only from your device to the router. The router then goes to your modem and out through the internet. Chances are that connection is not 100 mbps because of interference, which can be walls, other wireless devices, etc.
One way to test your actual internet connection speed is to go to and click on one of the links on the map. This will tell you how many mbps you get to the internet.
Mar 17, 2011 | Linksys E3000 Wireless Router
I have a D-Link wireless router DIR-655 with 4 computers on a home-based network. Everything worked fine for 9 months at good speed. All of a sudden the internet is extremely slow. My test between my cable...
Get your router a security key(password) just in case your neighbors are use it.
There a great article at General Router Setup.
If you need more help post back!
Thumbs and testimonial are welcome!
Feb 11, 2011 | D-Link Xtreme N DIR-655 Wireless Router
Slow internet download speed from my edimax ew 7206 access point
You dont say what internet access technology you are using - DSL, Cable Modem, satellite, etc.
It is possible that your aggregate speed is being throttled by excessive traffic somewhere ELSE in the network and it may have nothing to do with the link from you access point. When you reset it, it may attempt to operate at the maximum speed only to be throttled by some other choke point in the network.
When you reconnect and get the 4-5 speed, how long does it last? Can you actually see the difference in performance? Most people cant tell the difference unless they are downloading large files.
Sep 24, 2009 | Edimax EW-7206APg (EW7206APG) 802.11b/g...
PLEASE RATE ;] you can find out whos accessing your router by logging into it. Usually once your in there is usually an option for attached devices or connected devices it should show you what computers or devices are connected to that router
Feb 06, 2009 | D-Link DI 514 Wireless Router (DI-514)
Slow connection
Your slow connection could be affected by poor location wireless router (therefore poor signal strength), electrical interference, or even someone else with a wireless router transmitting on the same channel as your wireless router.
Try relocating your router away from solid walls, and/or move your computer or router to another location.
If your connection speed varies, could be electrical interference with appliance/s in your house, turn off all appliances, test your internet speed connecting then turn on one appliance at a time to determine which appliance is at fault (could have a faulty capacitor in the appliance)
Jul 24, 2008 | NetGear MR814 Wireless Router
Computers & Internet Logo
54 people viewed this question
Top Zonet Computers & Internet Experts
Prashant M
Prashant M
KG John Justin
KG John Justin
Are you a Zonet Computer and Internet Expert? Answer questions, earn points and help others
