Question about Vacuums
VAX Centrix Steam Cleaner - cannot remove clean water tank
Under Operation it tells you to remove clean water tank which according to diagram looks as though glass part sould slide off. Have been unable to do this. Could you please give me a more accurate instruction as to how to do this as it doesn't appear to come off very easily
ukvacfan
  • 328 Answers
SOURCE: Operating instructions for Vax wet cleaner
What is an IPX4 by Vax?
Posted on Dec 29, 2007
  • 3 Answers
SOURCE: Polti Vaporettto 3000 Steam cleaner
I suggest using KalStop to remove the calcium and minerals built up in the machine. Polti has built the machines to stop working when there is too much calcium in the boiler to prevent further damage.
Posted on May 15, 2009
  • 97 Answers
SOURCE: Hoover steamvac not picking up water
you don't have the recovery tank lid on correctly.
Posted on Jul 19, 2009
Vac Belts
  • 701 Answers
SOURCE: Bissell pro heat steam carpet cleaner, not releasing water.
That means that you need to replace the pump belt. Here is the belt you need and a manual you can view:
Bissell 7901 Belt and Manual
Posted on Mar 02, 2010
Testimonial: "just what I was looking for thank you"
SOURCE: Steam cleaner stopped sucking up water.
steam vac won't **** up water
Posted on May 21, 2010
Where do I add detergent to my vax VRS29M powermax 10 in 1 steam cleaner
usually in the water before adding that to the tank .
Feb 27, 2015 | Vax Vacuums
How do iput water in a vax hard floor advance+steam cleaner s3s+
look for a big knob that you can unscrew. When you locate this knob unscrew fully and add water......then screw tighten and you are ready to turn on appliance.
Dec 06, 2014 | Vax Vacuums
My VAX steam mop cleaner i bought in July is dripping water from the reservoir,what do i do, i have proof of purchase?
have u used any chemicals that not recommended in the user guide?
check for seals. some chemicals could damage water seals. those are not covered under warranty. but better to talk to warranty provider.
Aug 21, 2014 | Vacuums
Bissell instruction manuals
The instructions tell you to clean filters after each use. Check the User's Guide for specifics. Quick guide though. Water tank Cap: Under the cap is filter (looks like a screen) remove, clean, replace. Locate the Flow Indicator: turn it counter-clockwise to remove the cap. Lift out the rotor and the filter underneath, Clean and reinstall in reverse order. That should fix the problem. Consumer Care phone number is listed in the User's Guide.
Aug 20, 2014 | Bissell ProHeat Turbo Deep Cleaner Upright...
Most likely Water Tank Filter clog. The filter is located in the cap of the water tank (looks like a screen) remove it and clean and replace it. You may want to check the User's Guide for anyother filters that should be cleaned after each use.
Jul 28, 2014 | Bissell ProHeat Turbo Deep Cleaner Upright...
Vax co uk support
There are a number of possibilities. I have this appliance and I'm not a fan of it!
  1. Check the water filter isn't void, which is behind the main water tank at the front. It should have a sandy colour to it and if it is low or discoloured, then it requires to be replaced.
  2. Fill the water tank with water and the back tank (if fitted) with clear "white" vinegar and switch on. If there is only one tank fill half with water and vinegar. Then press the trigger on the handle. If nothing comes out, You will need to buy a new water limescale filter which can be purchased from Vax UK.
Oct 31, 2013 | Vacuums
No steam comming out of my h2o x5 cleaner
see the causes and proceed with common sense. and fix it. God bless you
If the spray function has quit working on the carpet cleaner, check to make sure there is a full tank of water. If the water level is adequate, check the position of the gasket on the bottom of the water tank assembly. The gasket can become lodged, damaged, or removed. If this has happened, fix the gasket to the proper position according to the user manual, or replace the damaged or missing gasket.
  • 2 Change the belt on a steam cleaner that has inoperable brushes. From time to time, belts on carpet steam cleaners become worn, and you must replace them. If the brushes on your unit have stop moving or do not turn on, you may have a damaged belt.
    Replace a belt at home easily with little expense. Refer to your user's manual for replacement instructions and the part number for purchasing the belt. Remove and replace the belt according to the model of steam cleaner you own. Purchase a new belt at home improvement stores or directly
  • Sep 22, 2012 | H2o TR220002 Steam Cleaner
    SteamVac Carpet/Upholstery Deep Cleaner Vacuum: how do i add the solution to the steam vac? how mu...
    You didn't give a model number so I'll tell you both methods. The F5xxx and F6xxx models have a cap at the top of the clean water tank that doubles as a measuring cup. The cap is about 3 inches in diameter. Fill the cap to the fill line with shampoo and dump it in the tank. Then fill the tank with hot (Not Boiling) water.
    The F7xxx series has a 2 section tank. The large section is for hot (Not Boiling) water. The smaller section is for shampoo. Fill the smaller section with shampoo and the Steam Vac will mix the water and shampoo for you in the proper proportion.
    May 16, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
    Hoover Steam Vac V2 Deep Cleaner leaking clean water
    Fill the tank and determine if the plastic is leaking, or if the valves are leaking. if the tank is cracked, it would need replaced. There is an improved design now available.
    You may cycle the valves on the bottom with the eraser end of a pencil.
    Sep 24, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
    Vacuums Logo
    113 people viewed this question
    Top Vacuums Experts
    AskDyson
    AskDyson
    D. Floyd Kolb
    D. Floyd Kolb
    Are you a Vacuum Expert? Answer questions, earn points and help others
