Question about Goodman Heating & Cooling
Wiring diagram for 15kw and 5kw strip heat --replaces a one piece 20kw strip htr
3 Suggested Answers
FurnaceGuy
  • 74 Answers
SOURCE: I have a Comfortmaker heat pump and ICP air
Did you keep notes or remember all the stat wires and terminals? 20kw should heat your home very well. Has the unit heated the house good after you changed the thermostat?
Posted on Jan 03, 2010
Therinnaiguy
  • 1420 Answers
SOURCE: what type of heat does a 20kw heat strip put out
68,260 btus or enough to heat an area of approx 2,275 Sq. Ft. at 72 degrees F.
Posted on Mar 09, 2010
Heater not heating enough
Electric furnaces have strip heat inside of them. Depending on the model, size, etc, is how much heat the system can provide. Many times, if the system has worked in the past and started to have problems later, it's because you have lost half or more of your heat strips. They come in different sizes, 10kw, 15kw, 20kw, but ran on different contactors. So if you have a tripped breaker, faulty heat sequencer, etc, you can still have heat, but not the full amount. I strongly suggest any electrical related problems be look at by a qualified technician when dealing with air handlers. Hope this helps!
Dec 08, 2013 | Heating & Cooling
Had 16 xi Trane heat pump installed 3 years ago. It ran well for the first couple of years. It began to stop heating and would blow cold air only. Have tried both aux heat and reg. heat to run and neither...
That's a complicated system that needs a qualified technician to service it. Lots of people can install them and they run fine, for a few years. Your indoor unit, operating on 2 heat elements, will feel like its blowing cold air even though its heating, just not so well. And not like you are accustomed to. Each element (5kw)=22.7amps, on average. So 3 elements operating should trip a breaker. Its probably been operating on 2 heat element plus the heat pump. And now you have trouble with the heat pump. If you can't TRUST the guys working on your equipment, try someone else. A second opinion. Normally a 3 or 4 ton unit will have 15kw heat installed, heatpump or not. 5 ton, 20kw. If yours is a 3-4ton, cooling, the 100amp(or normally two 60 amp) breaker should have been installed upon equipment change out. If yours is blowing cold all the time, something is wrong with your heatpump. The electric heat inside operates only when the heatpump can't keep up(real cold outside), the heatpump is in defrost(then it's actually in cooling mode), or if you have the tstat in aux/em. heat. Try a local trane dealer? Of a technician with 15-20 yrs under their belt. A trane dealer should have trane tech support also. BIG HELP!!!
Mar 01, 2017 | Haier Energy Star ESA3183 Air Conditioner
HOW DO I WIRE A HEAT STRIP IN MY HEIL CENTRAL AIR CONDITIONER ?
Do you have power to the unit for the new heat strips? what size strips do you have? 10kw-15kw.. ect.
If you had heat strips previously, then i will just need to know the size and application.
Dec 15, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
We need wiring for heat strip install on Coleman Package Unit Model PHP036H1321A --- HELP!
Doesn`t this unit already come prewired for electric
heat? It shows 5kw,1okw and 20kw.
Jan 09, 2010 | Heating & Cooling
I have a Comfortmaker heat pump and ICP air handler-FPC3600-with 20kw back up heat. I replaced thermostat because the old one had been hit along the way and was pretty flaky. Last night the temp outside...
Jan 02, 2010 | Heating & Cooling
Will conditioner run same amps cold weather
Usually connected to a 30 amp & 40 amp double breaker, if it is a heat pump. 30 for cool, 40 for heat, to turn on 1 or 2 heat strips. heat strips are rated 2 5kw each.
Nov 12, 2009 | Carrier Heating & Cooling
Breaker keeps getting flipped off
20kw heat should have 2 separate 60 amp circuits on number 6 wire.
Mar 03, 2009 | Ducane Grilling
MY HEAT PUMP SYSTEM WILL NOT WORK IN EMERGENCY MODE
the thermostat sub base has a place to connect a wire usually white to energize the heat strips when you push the stat way hotter than the house temp. that is why the strips come on in normal heat. it also has a terminal that is only energized in emergency heat and it also should have a wire connected to it so that terminal can supply power to the strips when the stat is switched into emerg heat . you can identify the terminal from the wiring diagram and if need be jumper w2 wire over to the aux terminal and it will work. they both go back into the airhandler and power the same strips. w2..................................................................................................w2 in airhandler to strips or w2...jumper to aux......................................................................................................................w2 in airhandler to strips.
Nov 10, 2008 | Amana PTH123B25AJ Heat Pump Air...
Powermate 5000
20kw means 20 KILOwatts (kilo=1000), so 20kw=20,000 watts
So the Powermate 5000 refers to wattage. 5000=5kw
Sep 04, 2008 | Coleman Powermate Powermate 5000W...
Heating & Cooling Logo
60 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
