Insignia 42inch plasma screen flickers
Ok so it flickers at random and sometimes the screen goes out completely but then it will come back after a few mins, ive visually checked all the boards for burns or cracks, ive checked all connections, i may need to replace the ysus board an zsus board, but i wanted to check and see if anyone else had this issue as i know no video would make me thing the zsus and ysus boards need to be replaced but it works sometimes and sometimes doesn't.would i need to verify proper voltage to each board, could that cause this issue if it was under charged
  • 5 more comments
  • dp6721 Jan 18, 2009
    no, this has happened in 2 houses so it is not due to magnetic interference
    It has happened in 2 houses with nothing around them, so magentic interferance would not be the answer, im wondering if the voltages are off on the zsus board an ysus board
    its a insignia IMP4219 and it flickers at random it can be on for 1 minute or a hour
    well i got the powersupply tested its voltages are all proper the volatages to each board is good...just trying to find the test points on the board for the y sus board its a 6870qye011d board if that helps any
    i did test it with the power on :) and it has been placed in another spot i just want to verify the ysus board is getting proper power but im not finding the test points on the board
    well after hours of soldering and and cable checking still no go, but i did find the spots to check my vsc which is 115 which it should be and my -vy which is -75 which it should be but im not aware of what the vzbias on the z board should be its showing 164 volts can anyone confirm what it should be?
  • dp6721 Jan 19, 2009
    after all my testing ive come to the conclusin that its the control board because i can get menus and everything else is clear as day, and after testing the board its definately has issues. i have a new one on order so its all good
    Sergeant:
  • 221 Answers
Its not proper as something is getting short on the circuit or may be it can be the possibility that whole board bneeds replacement to make it work.
Posted on Jan 18, 2009
  • 4,234 Answers
Since the problem seems to come and go, it suggests transient problem that can be as simple as a bad connection or more complex like a failing part. Since the signal levels inside the set are so low, it doesn't take much to interrupt the signal. If the set is still under warranty, request warranty service, but report the problem as an intermittant problem. This will insure that additional testing time will occur and avoid a "no problem found" result. Also, reporting an intermittant problem will effectively extend the warranty if a repair attempt does not completely resolve the problem.
On to your specific case...
If the set is no longer under warranty, the first step is to disconnect and reconnect all cables and connectors. This should provide good connections at all places and resolve the problem if the connection was the problem. If you can solder, examine all of the solder connections at the connectors and on the power supply board. Resolder any that appear grainy of have rings.
Let me know your results.
Dan
    Sergeant:
    Champion:
  • 435 Answers
Hi, Check the power unit in the TV. Voltage may be normal but it might flutuate when the TV is on.
Look for loose connections also.
Try connecting the TV to different power source/ point and see if this flickering continues ...
    Genius:
  • 1,913 Answers
Check your power supplty waltage fluctuation and earthing problem.
  • kishor khatri
    kishor khatri Jan 21, 2009
    ya u have to purchase new bord or repair it in service shop.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, post back the exact model number. Additionally provide information if the problem is persistent whether the Insignia is on TV (tuner), DVD (or external video source) or some other inputs (receiver). Likewise, it might help to know if the problem occurs upon powering the TV or after the TV has been in used, say 1 hour or so.
Check and perform preliminary visual or necessary inspection. Pls post back result(s). Good luck and Thank you for using FixYa.
    Scholar:
  • 160 Answers
Do u have any magnetic field or high sound speakers or something very close to your tv.move them away.this disturbance and flickering can be caused by this.
I have had my Philips Flat screen Plasma 42inch TV for about 4 years now and all of a sudden the TV screen will not come on all the tv is showing is the green light flickering and the sound comes through...
Yes, this is caused by a capacitor problem, take the tv apart and on the main PSU board the faulty capacitors will be evident by their bulged appearance. Andrew Eve
Sep 22, 2010 | Philips 42PF7220A 42 in. Plasma Television
I have insignia 42inch plasma model Insignia INP4227. It may be a rebadged Prima PH42T7. This problem is intermittent and so far have not been able to repeat consistently. Uploaded pics of the problem here...
if sound is ok main is good y and x can be presumed to be good because we have a image i see two solutions 1 lvds cable is defective or not well connected( lvds cable goes from logic to main board) 2 logic board is defective .
Jun 08, 2010 | Televison & Video
I have a 42inch insignia plasma screen. The tv was knocked of the stand, and the inside panel broke. Surprisingly enough the outside glass is still intact. I've been told that insignia no longer makes...
It's likely that parts are available for repairing your TV. Service can be obtained by calling 1-888-237-8289 in the U.S. or 1-866-237-8289 in Canada.
Apr 14, 2010 | Insignia 42" LCD Flat-Panel HDTV
It's a little over a year old. The screen will randomly start flickering and gets really dark and I can't see very well and sometimes just goes black altogether. It is very frustrating and sometimes when i...
Sounds like a loose connection at the inverter board. Laptops use an inverter to step up voltage to drive fluorescent tube(s). The problem could be at the inverter or at the tubes.
Mar 12, 2010 | HP Pavilion dv5-1125nr Notebook
My akai pdp4225m 42inch plasma went out. when i turn it on i dont get the blue akai splash screen. just black. any ideas on what part to order?
You may have one or two problems, the power supply has failed or the Y-Sustain board has failed also. The more common problem is the Y-Substain board if fails the most in plasma television, next comes the power supply then the X-substain board, My best solution for you is to check the power supply first and consider ordering the Y-Board also, the PS is usually the center board and the Y-Board is to the left of it. The X- Board is on the right side..
Dec 03, 2009 | Akai PDP4225M 42 in. Plasma Television
LG 42inch plasma tv suddenly lost picture, now only works intermitently. Sound is ok.
i have got the same problem with my LG 42PC1D might work for a few days or a few hours no solution as yet
Oct 25, 2009 | LG 42PC3D 42 in. Plasma Television
Vizio P42HD, ok for a few minutes then flickers, picture looks "solarized" then goes blank. Flickers on/off at random intervals. May stay good for minutes to hours, may stay bad for minutes to hours, or...
Disconnect the Z sustain board ribbon cables that go to the display and clean them with a small amount of acetone, ( nail polish remover ). ONLY THE COPPER TIPS ON THE RIBBON.....NOT THE RIBBON. Put those back in and do the same with the Y.
Z on the right Y on the left..
Oct 21, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
My tv screen keeps flickering on and off
  1. Need Model # of set and the brand so I know if its a plasma, LCD, or CRT set keep me posted
Aug 23, 2009 | Televison & Video
Dell Inspirion Laptop Screen Randomly Flickers, Then Blacks Out
not to get to concerned just yet, a few tips, when you press on the top of the laptop case by the screen area in the back of the laptop do you notice the screen flickering off? and when you let go dose it come back on? if so this can be a faulty wire or bad inverter, they are actually both very simple to fix and relatively cheap fixes.
Aug 20, 2009 | Dell Inspiron 1100 Notebook
No picture
btw for anyone experiencing these problems with the infamous "is-lcdtv32" byd:sign is the same manufacuterer as insignia, its the same company with a different sticker. i know this isnt a solution, but parts for all discontinued insignia';s can be purchased thru byd:sigh(by design). hope this helps .
Oct 06, 2007 | byD sign d:4232 42 in. HD-Ready Plasma...
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
