Question about Yamaha Rx-v465/rxv465 Home Theater Receiver
Is there a update for yamaha rx v465 to allow 3d passthrough
5 Suggested Answers
smarthome2
  • 1114 Answers
SOURCE: RX-v465
Unfortunately the RX-V463's HDMI output is version 1.2 or 1.1. In simple terms, It is useless! Not to blame yamaha or any other manufacturer but the firmware was riddled with problems; just like what you describe. There is no fix for your model for the video issue, however, the optical issue is solveable. The receiver should play 5.1- 6.1 7channel stereo etc. in optical or coaxial mode. If you have the ability to switch to coaxial, do so. it's sound is warmer anyway. Secondly, check your settings thru the receivers "GUI" or "Menu" in Manual setup for audio. Thirdly, check your samsungs "Native" resolution, chances are it will only do 720p or 1080i and; if your TV is 50" or smaller, the human eye cannot see the difference between 720p and 1080p anyway, provided you use good cables. I am a professional in the industry and still avoid using HDMI whenever possible!
Just make sure you set your BluRay and TV to the same resolution. If your choices are 720p or 1080i use 720p it's cleaner 1080i is equal to 540p, which is just a hair over std DVD video. If you still have problems and need more help, post a comment and I will help some more. Hope this helps
Posted on Jun 11, 2009
  • 127 Answers
SOURCE: RX-V465 Yamaha Reciver we can get picture but no sound w/PS3
Check HDMI Sound settings:
Enter Setup menu via remote, then Func. Setup / HDMI / Audio. You can choose from Amp (sound will be played via Yamaha), TV (sound will go straight via HDMI out to your TV and not play on Yamaha) and Amp+TV (Yamaha will play the sound and also pass it to the TV).
Also what is your source? DVD or some network player? For example Yamaha cannot decode audio in AAC or other computer formats, so be sure to change the audio settings of your player to output PCM and not raw/bitstream.
Posted on Apr 27, 2010
  • 127 Answers
SOURCE: Yamaha RX-V465 switches off when increasing volume
What speakers you have connected? This receiver supports only 6 and 8 ohm speakers (not 4 ohm). Also check if the ohm settings are correctly set in Advanced Setup (in standby press on the front panel STANDBY while holding STRAIGHT button). In this menu check the setting SP IMP. (speaker impedance) if it maches your speakers (6 or 8 ohm).
Disconnect all inputs and also all speakers. With nothing connected, try to increase the volume. If it still will power off, the unit is probably faulty and should be repaired.
If it does turn off only with speakers connected, check the speaker wires and the speakers, the problem will be there.
  • 127 Answers
SOURCE: my wii won't play video through my Yamaha RX-V465.
This receiver doesn't support processing of video signal, only switching. This means that it can output only the same format of video. Only some more expensive models do upscaling from component/composite to HDMI out.
From HDMI out, you can output only signal that came via HDMI in 1-3. For component out, you can output only component in. The same for composite.
So in order to use wii through receiver to TV, you must connect receiver and TV also via the component cables.
Or other option is to connect component from wii directly to TV and connect only audio to receiver.
Posted on Aug 13, 2010
Can I hook up my yamaha receiver to soundbar
can I hook my yamaha rx-V465 to my vizio soundbar? When I soldered the rca plugs on to the speaker wire and connected my center channel on the receiver now ther receiver randomly shuts itself off.
Nov 21, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
I have a Yamaha RX-V465 receiver. Is the newer YDS-12 docking station compatible with this receiver? the YDS-12 seems to accept newer IPods.
Yes, it is compatible.
http://usa.yamaha.com/products/audio-visual/accessories/yds-12_black__u/?mode=model
It has 2 modes of operation. For RX-V465 you need to select mode B. In this mode it is compatible with YDS-11, which is supported for RX-V465. But iPhone is not officially supported in this mode. But I have found on Yamaha website FAQ, where they claim that iPhone switched to Airplane mode worked well.
http://faq.yamaha.com/us/en/article/audio-visual/accessories/yds-12_black__u/4742/4061
Nov 11, 2010 | Yamaha RX-V463 Receiver
Is a yamaha rx-v465 supposed to recieved both
What connection do you use?
This receiver supports both video and audio over HDMI. It has also other video inputs, but it doesn't have any video processing.
So if you connect your equipment for example to component video in, its video output will be present only on component video out (NOT on the HDMI output nor s-video output).
Jan 03, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
I have yamaha rx-v465 receiver and yds-11 docking station. how can i get tv{through hdmi 1}to display what's on ipod.i have nano w/video camera{newest one]. is this possible
I think it is not possible, because RX-V465 does not have HDMI-video processing. It can only pass-thru the HDMI video to HDMI-out, but not alter the signal in any way.
If it should support TV output with YDS-11, it will work only via analog video out (s-video / composite / component).
Dec 30, 2009 | Yamaha Rx-v465/rxv465 Home Theater...
I have a PS3 hooked up via HDMI to my Yamaha RX-V465.When I play a blueray disc the signal info shows PCM.Shouldn't it show Dolby Digital or True HD?
Your PS3 probably has a setting for what digital bitstream it produces. Check it out. Dolby Digital is probably what you want.
Dec 27, 2009 | Yamaha Rx-v465/rxv465 Home Theater...
Can i output component video via the hdmi out on a Yamaha RX-V465?
component video is analog. although it can carry a high definition image, it is not compatible with hdmi.
Dec 26, 2009 | Yamaha Rx-v465/rxv465 Home Theater...
Open Questions:
See all Yamaha Rx-v465/rxv465 Home Theater Receiver Questions
Yamaha Rx-v465/rxv465 Home Theater Receiver Logo
320 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
