Question about Sony Handycam CCD-TR94 8mm Analog Camcorder
Sony video camera ccd tr9 door will not stay closed
quang123
  • 107 Answers
SOURCE: get output from sony video camera CCD-TRV238E
You need a computer with video card capable to take composite or super video input if you have that then the software it come with that video card then you can transfer from your CAM to computer and burn into DVD or HDD
Cheers
Posted on Dec 10, 2008
memturbo
  • 226 Answers
SOURCE: Manual for CCD-TRV16E
here you are
Posted on May 12, 2009
SOURCE: How do I hook up a Sony Handycam Video 8 CCD-TRV41 NTSC to view on television?
The connector for video/audio is located under a cover next to the red Start/Stop button on top, near the lens. If you don't have the right cable, they are available at Best Buy for example. There are analog outputs only, if you want to capture on a computer you'll have to get a video capture device for the computer. I use Pinnacle. -Stan
Posted on May 22, 2009
leecom72
  • 4806 Answers
SOURCE: sony handycam ccd-trv35e how to video record on my laptop
Hi there.
The computer must have standard Audio/Video (A/V) RCA input jacks and compatible video capture software to complete this procedure. Because there are many different video capture applications on the market and we cannot reasonably know which video capture software you are using, Sony is unable to provide specific instructions or support for software we do not manufacture. However, many video capture applications have detailed help files, including specific instructions about capturing and importing video from a camcorder to a computer.
The help files should be available in the Help menu of the video capture software or in a separate file on the software disc. If you cannot find instructions in the help file or on the disc included with your software, consult the software manufacturer for more detailed support information.
  1. Connect an A/V cable to the A/V output jack of the camcorder:
    If your camcorder has standard A/V RCA output jacks, use standard A/V cables for the connection. avstnd.png
    If your camcorder has a mini A/V output jack, use an A/V cable with a mini connection on one end.
  2. Connect the other end of the A/V cable to the A/V input jack on the computer.
  3. Turn on the camcorder to the VCR, VTR or PLAYBACK mode.
  4. Cue the video in the camcorder to the beginning of the video footage to be transferred.
  5. Turn on the computer.
  6. Start the video capture software.
  7. Begin playing the video in the camcorder.
  8. Begin importing the video with the video capture software.
Good luck and thanks for choosing FixYa!!
Posted on Jun 02, 2009
satavlad
  • 405 Answers
SOURCE: Sony Handycam CCD-TR64 cassette door won't close
Common problem with this mechanism. In order to fix the problem you will have to replace part called CHASSIS LS. Expensive repair, probably not worth the effort.
Posted on Dec 04, 2009
Testimonial: "Thanks. We ended up getting a new camcorder. That Handycam was as old as I am (18 years), so it was time for an upgrade anyway."
Sony handycam ccd-tr9 video playback is distorted
sir,
the video head problem, try to clean it with head cleaner cassette. play the cleaner cassette several times, test, if still problem must change the video head.
Jan 20, 2016 | Sony Video Cameras
Sony video handycam ccd fx420
The take up spool is no longer working. Time for a new V8 machine.
Jun 10, 2017 | Video Cameras
Tape door won't open or close to release tape
Sony Handycam CCD-TRV58 Hi-8 Analog Camcorder
1. Per the manual on esupport.sony.com
- if the power is disconnected door won't open, and if the battery is the dead the door won't open.
Plug it in and hopefully you can get the tape out.
Did this work?
Feb 11, 2013 | Sony Handycam CCD-TRV58 Camcorder
CASSETTE DOOR WILL NOT CLOSE. CCD-TR760E
For sony handycam DV4000 the battery is not holding battery charger means don't fit the place
Jan 01, 2013 | Sony Handycam CCD-TRV65 Camcorder
Sony Handycam CCD-TR818: The camcorder cassette door stays in the open position. It won't stay closed. Even when you put a casette in, it will expell the casette, and the door will stay open. I have...
Tape mechanism problems can be quite complicated but they can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Jan 28, 2011 | Sony Handycam CCD-TR818 Camcorder
Handycam CCD-TR618E Hi-8 Analog Camcorder: I have a Sony Handycam CCD-TR61. It has worked fin...
that is look to be the cassette in switch
located on the side of the cass housing
or a sensor ...
hope that will help and this kind of trouble
is easy to fix for experienced tech an hour max
hope you will find one
regards Alan
May 18, 2010 | Sony Handycam CCD-TR618E Camcorder
Tape door will not stay closed. shut tape compartment door...runs for 3 seconds...reopens.
It is possible on the CAM mode the tape reached to the end, or this is
typecal problem from Sony the sensor it detecting 2 reels to turning the tape were faulty.It require to replace the cassette compartment or it call LS chassis assy. It will cost about $200, $250 in Australia to repair it
Jan 08, 2010 | Sony Handycam CCD-TR96 Camcorder
Dec 04, 2009 | Sony Handycam CCD-TR64 Camcorder
Tape door wont close on my Sony CCD-TR416 camcorder
Try this for anyone having this issue:
HERE'S WHAT WORKED FOR ME PER SONY TECHS:
Take? OUT the battery or disconnect the AC cord.
Turn the camera ON (tape, memory, edit settings) for 15 seconds.
Turn camera to off setting.
Plug battery or AC cord back in.
VOILA!
Worked for me and I had the stupid C32:11 error code for weeks! Door would not close. Followed the SIMPLE and SAFE instructions and IT WORKED! Just like magic. I couldn't believe it! Save your money TRY THIS!
Sep 22, 2009 | Sony Handycam CCD-TR416 Camcorder
Cassete door will not stay closed
Unit may have jumped mechanism timing. Take in for service
Jul 08, 2008 | Sony Handycam CCD-TRV37 Camcorder
Video Cameras Logo
46 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
