HP Compaq Presario v4000  PC Notebook
Problem for HP Compaq Presario v4000 (PL696AV) PC Notebook
No picture
By ushao on Jan 18, 2009
put adapter in, it turn on laptop by itself, its led light is on, but no picture on screen.
Solution #1
posted on Jan 18, 2009
Somewhat Helpful)
BillW50
Rank: Wiz
Rating: 83%, 80 votes
If you mean you hooked up an external monitor and you want to see the display there. Well there should be a Fn key combo to toggle the displays. It should be one of the keys that looks like a monitor plus the Fn key at the same time. Otherwise go into the Control Panel -> Display -> Settings and you can switch to the other monitor there. Hope this helps.
Was this helpful?
Yes
No
Solution #2
posted on Jun 15, 2009
Not Rated)
tim804441
Rank: Apprentice
Rating: 0%, 0 votes
how to tell:
have you got a spare monitor? plug the spare monitor into the (right) side of the laptop as i have done in the image: http://img32.imageshack.us/img32/1439/15...
as BillW50 has stated, once external monitor has been plugged in, press the combination of Fn and F4, this should switch the display to the external monitor you have just plugged in. If it doesnt work the first time, try the combination a few times as there are different modes for the Fn+F4 (such as LCD only, LCD + external, external only, external 1 + lcd 2....ect)
if you get a picture on an external monitor but not on your laptop, then the most likely problem is with your laptop screen itself, which it is most safest to take to a computer/laptop repairs specialist.
If you DONT get a picture on the external monitor, the scenario seems most likely in the computer's Graphics Card/Display Unit. A malfunction there is most likely causing a no picture or no signal to the LCD.
In my situation, a picture had lasted on the Laptop's screen for about 10 seconds, then a very muddled up screen, then no picture, this was the result of the LCD within the laptop as you can see i have plugged in another computer screen to test my above theory.
hope that can help you
Tim
Was this helpful?
Yes
No
Popular Solutions for HP Compaq Presario v4000 PC
Questions and Unsolved Problems for HP Compaq Presario v4000 PC
Do you recommend HP Compaq Presario v4000 (PL696AV) PC Notebook?
Answer
Answer
screen does not light up
Answer
I had eee pc 1000h,it showed wirless connection but not show web page
Answer
drivers for integrated cameraof NEO GL31 laptop with Genuine Intel(R) CPU T2400 @ 1.83GHz
Answer
Amilo Li 1705 replaced 1GB (2 x 512 Mb) with two x 1GB ram. System still only sees original 1GB Ram... (More)
Answer
keeps giving errors of not finding files on the installation cd, changed cd, same problems
Describe your PC Laptops problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptop Experts
Top Computer & Laptop Repairmen
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
