Question about Garmin nuvi 260W GPS Receiver
Corrupted map on a Garmin 260W, can't get out of bootloop?
Tried to perform a software update to the device. After loading for a while, a dialog box showed up but I accidentally hit exit on the box, and disconnected the device. Now the device will only boot to the Garmin logo, then it restarts and does the same thing. If I try connecting the USB cable to it, it says "loading maps" at the bottom, then shows a picture that indicates it's being connected to a computer, and then a bar starts loading, but stops about halfway and it restarts, doing the same thing. Is there any solution to this? The warranty is no longer available.
  • 13 Answers
SOURCE: Garmin Map update 2008
you will need to install the usb driver which should be located on the 2008 disk. When you attach the gps to your computer it should ask where the usb driver is located. If your dvd drive is (D) click browse and go the disk and find usb driver folder. I have purchased the new 2008 disk and had problems with it freezing on loader loading. I then browsed the disk and downloaded and then was able to get to the maps. I did not install it due to it asking what map I want to download. I wanted the whole thing so needless to say I am taking it back to walmart. I hope this helps.
Posted on Jan 06, 2008
solasknows
  • 199 Answers
SOURCE: have usa garmin nuvi 260 ,want to load austalia maps how?
well you need to update the firmware of your gps also call garmin customer support they are great tell them about the map, also the poor satelite cover might be because of your location or weather conditions
Posted on May 26, 2009
  • 6 Answers
SOURCE: Garmin Nuvi 260w not recognized by computer
Take a look at this site, http://www.garmin.be/missing.html Download and unzip the software, plug your garmin in the USB and start the updater.exe program. It gets you started again. Later on you can use the Webupdater to get possible newer software..
It worked for me and my Zumo550
Goodluck
Auke
Posted on Jun 03, 2009
HarryHarley
  • 343 Answers
SOURCE: Garmin Nuvi 260W will not start up. When not
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If the device does not power on it could be a result of a extremely low battery. Please ensure that the device is receiving a charge while it is connected to the vehicle power cable. If the battery is receiving power from the vehicle power cable then the battery icon (located next to the time) would disappear from the Main Menu. clip_image001.jpg clip_image002.jpg
If the unit does not power on while attached to the vehicle power cable please follow steps from below to perform a soft reset:
  1. Connect the device to an external power source1
  2. Slide and hold the power key to the on position for 15 seconds
The device should power on. Notes:
  1. Preferably the vehicle power cable or a USB cable from a computer
  2. Some of the older Nuvi 200 series will have a reset button on the bottom of the device. It can be found on the bottom of the device on the same sticker that the serial number is printed on.
If your GPS unit powers down before it can fully boot up, the battery will need to be charged. Please charge the unit with the vehicle power cable or on a computer for at least three hours. After charging the unit, it should power on and function normally. If the unit will not charge in the vehicle, check the fuse in the power cable for the unit and the power outlet in the vehicle.
Posted on Jan 17, 2010
ZJLimited
  • 17970 Answers
SOURCE: My garmin nuvi 1350 freezes
I geard a lot question about Garmin Freezen when updates firmware; if you have firmware v3.1. I suggest you try to install v3.0 instead.
Keep in mind Hard Reset warnings:
* Note that this procedure has been known to delete your favorites so back them up beforehand: From the nuvi drive, copy x:/Garmin/GPX/current.gpx to your backup location. After the hard reset, copy current.gpx back to the same folder on the nuvi but rename it temp.gpx (important). On the next power cycle, the favorites will be read from temp.gpx into the non-user accessible memory area on the nuvi where they are actually stored (current.gpx is only a shadowed backup of your favorites)
* Note that this procedure will clear all user selected settings under Tools>Settings like map view mode, navigational settings, selected vehicle, selected voice, etc. These settings will need to be re-configured afterwards. It will also clear out your Recent Finds so make sure you save these as favorites or archive them in another way. Maps, vehicles, voices and user-loaded custom POI's stored on the unit will not be disturbed.
Hard Reset Procedure: (All except the 8x0/8x5/37xx series units):
1. Power the unit off.
2. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
3. Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
4. Press "yes" and the unit will reboot.
Reset all your location settings and user preferences. Also restore your favorites using the method outlined at the beginning of this post.
nuvi 8x0/8x5 series hard reset:
To perform a master reset on a nuvi 800 or 805 series device:
1. Remove battery from n?vi
2. Place battery back into n?vi
3. Touch-and-hold the bottom right corner of the touch screen when a progress bar appears
4. Release the screen when "Do you really want to erase all user data?" appears
5. Touch "Yes"
*Note that a "power-cycle" (or power-on/power off sequence) on the nuvi 8x0/8x5 units consists of removing, then reinserting the battery into the unit -or- sliding the power switch to the ON position and holding it there for ~10 seconds. Using the power switch normally on the unit (slide to ON position and immediately release) to power it off only puts the unit into a "sleep" mode.
nuvi 37xx series hard reset:
1. Power off the unit (press/hold the power button for ~7 seconds)
2. Power on the unit
3. When the Garmin copyright screen is displayed, press & hold the bottom-right corner of the screen
5. Touch "Yes"
Alternate method:
1. With the unit powered on at the map screen, press the bottom-right "Speed" field which will take you to the Trip Computer page
2. Press/hold the area just above the numerical speed on the round speedometer dial (where the compass heading is displayed when moving)
3. After pressing this spot for ~7 seconds, you will enter diagnostics mode
4. Select the first option displayed "Clear all user data", then follow the prompts
If possible after the hard reset (all units), let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire satellite almanac data.
Even you have warranty? Contact Garmin site.
Also, could contact this site poi-factory.com/node/6656
Or this: Repair Freezing On Startup for Garmin Nuvi 1350 LMT
Hop helps.
Posted on Dec 24, 2010
I have a garmin 260w that was a gift in dec 2009. I want to update the maps to the unit and thought there wasa n option at no charge but I cant find it. Do you have instructions on how to update unit for...
Sorry, no free maps. I know I've tried. You either live withthe old map or buy the latest version.
I bought the life time maps updates and I'm glad I did.
I've updated my maps at least 6 times.
New maps are about $70.
Life time maps are about $99 (when I bought mine)
BUT FIRST make SURE you have the latest software in YOUR computer and in YOURGarmin before you load any maps.
You can get that FREE at Garmin here:
To download the latest unit software visit Garmin website: www.garmin.com/webupdater First you have to set up an account at Garmin using theserial number on your GPS. Once you do that you can download firmware updatefor free. After installing WebUpdater once from the Garmin website,perform all future software updates from your computer. Simply connect yourcompatible Garmin device to your computer, then run WebUpdater from yourcomputer's "Start Menu" by selecting "Start","Programs", "Garmin", and finally "WebUpdater" REMEMBER: It takes hours to do a complete a mapupdate.
Unless you bought the Lifetime maps you may have to pay for current maps. By the way, thecorrect Garmin approved power OR download cables are a must!! Does this help? Let us know. Thanks.
Nov 22, 2010 | Garmin nuvi 260W GPS Receiver
Maps won't load. Screen says "Loading Maps" when turning it on, but it never loads.
You may have one of two issues. One, the power cord, 12 volt adapter cord may be broken and needs replacement. A defective cord will cause erratic behavior in the Garmin GPSs. You can get one from Garmin.com
Or... your software may have become corrupted (for whatever reason) and needs to be updated/reinstalled. To do that, you may go here: http://www8.garmin.com/support/download.jsp
Aug 02, 2010 | Garmin nuvi 260W GPS Receiver
Map updates
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To download the latest unit software visit Garmin website: www.garmin.com/webupdater
After installing WebUpdater once from the Garmin website, perform all future software updates from your computer. Simply connect your compatible Garmin device to your computer, then run WebUpdater from your computer's "Start Menu" by selecting "Start", "Programs", "Garmin", and finally "WebUpdater"
REMEMBER: It takes hours to do a complete a map update.
Sep 19, 2009 | Garmin nuvi 260W GPS Receiver
Own a Garmin NUVI 260W gps. How can we update this with new map, etc.? thanks.
How old is it and have you updated it once, if so
you might have to buy a update
Jun 23, 2009 | Garmin nuvi 260W GPS Receiver
SYSTEM SOFTWARE MISSING
Update with the newest software:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To download the latest unit software visit Garmin website: www.garmin.com/webupdater After installing WebUpdater once from the Garmin website, perform all future software updates from your computer. Simply connect your compatible Garmin device to your computer, then run WebUpdater from your computer's "Start Menu" by selecting "Start", "Programs", "Garmin", and finally "WebUpdater"
May 31, 2009 | Garmin nuvi 260W GPS Receiver
I bought a new nuvi 260w gps on 12/29/08 and i tried to use it yesterday in the state of Maryland but the town would not come up. the town has been there for years and years. The town is Timonium and the...
Your maps are old. You really need to update and it may cost you. I really like you 260. I have the same. For about $100 you get new maps for life. Well worth it. Or you can buy new maps as they become available, but those cost $80 each!! Doesn't take much to decide that.
Normal 0 false false false MicrosoftInternetExplorer4 REMEMBER: It takes hours to do a complete a map update.
Mar 22, 2009 | Garmin nuvi 260W GPS Receiver
Nuvi 260w system software missing on screen when i open it
Fairly simple to do:
Jan 20, 2009 | Garmin nuvi 260W GPS Receiver
Nuvi 260w system software missing on sreen when open
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Update your 260 to the newest software, which is what I think your asking??
System software missing
BEFORE you connect the Garmin to your computer you must download the free Garmin program on your computer called UPDATER. Did you do that?
If not:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To download the latest unit software visit Garmin website: www.garmin.com/webupdater AFTER installing WebUpdater once from the Garmin website, perform all future software updates from your computer. Simply connect your compatible Garmin device to your computer, then run WebUpdater from your computer's "Start Menu" by selecting "Start", "Programs", "Garmin", and finally "WebUpdater"
Dec 26, 2008 | Garmin nuvi 260W GPS Receiver
Current version of software is 5.0
Download that as that may be your problem.
You must download the newest version of WebUpdater from Garmin for free to your computer.
Then:
Dec 03, 2008 | Garmin nuvi 260W GPS Receiver
Garmin nuvi 260W GPS Receiver Logo
99 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
