Question about Air Tools & Compressors
Durabuilt 6 gal., 2 hp #DB1552-1
Can I use it for paint spraying.
3 Suggested Answers
SOURCE: Durabuilt Air Compressor oil blowout!l
I have a new Durabuilt Air compressor Model # DP0200604
6 gal. tank, Wp 0f 140psi ; I need a owners manual that I misplaced. Where can I go to down load this item? FLT 04-2010
Posted on Apr 26, 2010
Go to this web site for users manual
http://www.powermate.com/pdfs/2007/11/29/manual_200-2659-a_%28dp0200604%29.pdf
Posted on Jun 18, 2010
Where do I buy a Piston connecting rod for Durabuilt compressor 6 Gal mo# DPO200604 con/rod/116mm length
only place will be from the compressor manufacturer
durabuilt will be the assembled unit but the compressor is made by some one else
you will have to identify the maker of the compressor to have any chance of getting a rod
makers leave a casting sign on the crankcase of the compressor or even a brand name
you could try a retailer for the compressor and find a service center for repairs and get the rod from that angle
breaking rods or needing rods for compressors is very unusual and one possible cause of a rod problem is excessive pressure being generated ( 150 psi or more )
Nov 21, 2016 | Air Tools & Compressors
I have not used my power roller 990 in a few years. I got it out today, turned it on, worked for one second. now nothing
Pump did not get cleaned out right the last time you used it-
Also this time when you clean it take the cover off the frame if its got dried paint on it throw it away, every time you use this roller cover take the cover off and clean it well these types of covers have lots of small little holes in them thats how the paint gets onto the roller cover in a 5 gal bucket fill it with warm water and start to work the paint off it and use a "brush spinner" made by Shur Line it also cleans out roller covers to by throwing the wet paint or dirty water out be sure to "spin the cover or brush" out in a empty 5 gal bucket as it is messy. not-used-power-roller-990-in-few-years-4z2gdaa2roisjyazpqzwiojf-3-0.jpg
Nov 01, 2014 | Wagner Spray Tech 0514001 Pro 990 Power...
Graco magnum paint sprayer won't prime
Airless won't prime- I always start trouble shooting an Airless that won't build/hold pressure look at sump hose inlet filter (the hose that goes into the paint if its got paint debris on it clean off filter and pour the paint thru a strainer bag into a clean 5 gal bucket-also remove the filter housing on the spayer and clean and flush and replace filter and housing- the shaft or the metal sleave has two ball bearings called "check balls" that maybe stuck turn on sprayer and put a piece of wood on shaft and give it a few good taps this will knock the check balls loose if after all this fails then you need to have new packings put in becuase the old ones are worn this is pretty easy to see because the rod the compresses the paint will have signs of paint on it indicating that the packings are worn.. Note keep rod and other moving parts oiled ith graco throat seal and finally Graco sprayers with the X on them are there (Graco) home owner line of sprayers that sell at home depot they are rated for only a certain amount of Gal per year keep it in good condition and cleaned store with coro-check inside of the pump when you are done using it.....
May 27, 2012 | GRACO INC 232745 Magnum XR-7 3/4-HP...
Porter cable PSH 1 - clogs even with thinned paint compressor 4 gal 5.1 scfm
strain paint befor using. run water in gun or thinner to see if it will spray it before using and mix paint to the consistancy that spray gun or paint requires for spraying ( fine strainer)
Feb 04, 2011 | Porter Cable Gravity Feed Paint Sprayer
What type of oil is needed in my Durabuilt air compressor-6 gallon tank? I need to replace some oil. Thanx. Send response to "gfrommell@wi.rr.com." Thanx.
Howdy. It's actually called Compressor Oil and is available at nearly all hardware stores and tool rental agencies. There are several brands and they are all comparable. I use Senco, but Campbell Hausfield is also good. Farmerbear at FixYa.com
Oct 23, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Aug 13, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Campbell hausfeld air compressor will not start
It should have a reset button. Try that. Out of curiosity, is the compressor near where you paint? If so, paint may have accumulated on the switch contacts. Remove the cover and check them out.
Apr 22, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Sprayer tips
Read and FOLLOW EXACTLY the spray material directions for mixing and use. Wear protective clothing including gloves and eye protection when spraying. Do not smoke, eat or drink when spraying; "wash up" afterwards. Spray on a calm day. Otherwise, winds may blow spray material off target. It's often best to spray in the early morning or late afternoon so excessive heat won't quickly evaporate the spray material. Follow the directions for use and maintenance that come with your applicator. Dispose of left over spray material and clean your applicator according to the directions on the spray material and with the applicator. Keep spray materials and applicator away from children and pets. Do not store spray materials in any but the original container in which they were purchased.
Aug 27, 2008 | Ultra Max R. L. Flomaster Atomist Electric...
Air Tools & Compressors Logo
83 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
