Question about Dishwashers
What does it mean when your dishwasher makes a loud screaching noise and the arm does not turn, and no water is coming out of the arm?
    An expert whose answer gotĀ voted for 100 times.
  • 88 Answers
Sounds like the wash motor has seized up.
Posted on Jan 18, 2009
GE Profile dishwasher too loud during the washing cycle
It has been my experience that water doesn't damage motors it destroys them! While it is possible I guess I would look and see if there is any kind of drive mechanism between the motor and the arm that could have been damaged. A warped shaft, bearing or bushing or something of that nature.
Mar 09, 2014 | General Electric PDW7880J01SS Dishwasher...
I have a customer that has a GE GLD6560L15SS dishwasher. The dishwasher works but it makes a couple odd noises. After it pumps out the water during the cycle when it starts back up it makes a very loud...
Hi Brian.
Clicking noise is often given by the bearing in the spray arm. The part is not expensive, less than one dollar.
The part is indicated as nr 611 in this diagram.
Here also parts and diagrams
GE GLD6560L15SS ' PartSelect
If that is not the problem try to understand if the noise comes from the bottom or from inside the door. If noise comes from bottom of the appliance check pump and drain line. If noise comes from the door it is possibly the control module. Noise from a relay in control module would be quite unusual with this model.
Check if the noise comes from arm bearing, that is the most common problem with this model.
Jan 20, 2012 | Dishwashers
Loud sounds
Many Frigidaire dishwashers come with the promise of being the "quietest dishwasher in its class," according to Frigidaire. However, a quiet dishwasher doesn't necessarily mean that the dishwasher is silent, as some noises are normal. It can take some troubleshooting at times to determine if a noise coming from the dishwasher is typical or if it indicates a larger problem Listen for the sound of water filling and draining throughout the wash cycle. These sounds are normal and do not indicate an issue.
  • 2 Pay attention to the drain motor, which operates at the beginning of each cycle. This noise should be fairly quiet and should not sound like a loud, grinding or banging sound.
  • 3 Note that the sound will change when the wash cycle moves between the lower and middle spray arms. This sound should be temporary and fairly quiet.
  • 4 Look for hard items in the dishwasher grinder or filter if a loud crunching, buzzing or grinding sound is heard. The dishwasher can typically grind up these items within one or two cycles, but the item may be lifted out and discarded to eliminate the sound.
  • 5 Remove the bottom rack and spray arms from the bottom of the dishwasher if there is a loud noise coming from the dishwasher that does not resolve itself. Look inside for the impeller, which is round and spins. Remove any debris that may be clogging up the impeller or pump.
  • Oct 07, 2011 | Frigidaire Professional Series 24 in....
    My mother-in-law called and her dishwasher is making a loud noise when the motor runs. sounds like a bad bearing somewhere? the noise stops when it drains (motor not running?). does that sound like the...
    There is only one motor -- it runs a water pump for recirculating the water when it's washing and runs a water pump when it's draining.
    It sounds like the spray arm is making the noise -- this is the part thru which the motor / pump forces the water during the wash cycle -- the pumped water causes the arm to rotate -- a warn or loose spray arm or mount is likely the problem.
    Or, it could be just some utensil stuck in the bottom of the dishwasher which the spray arm is rubbing.
    More info, let me know.
    Jul 16, 2011 | Kenmore Dishwashers
    I have an MDB760 dishwahser making a lot of noise
    The pump is not turned on when the what is sloshed around. It is the wash motor which turns the arms around. It is likely something is stuck under the washer arms or the washer motor bearing is faulty.
    If the dishwasher is only about 2 years old, I would suggest you call Maytag for warranty service. Depending on the part they will have different warranty time period. Normally 2 years should be a general policy .
    May 08, 2010 | Maytag 24 in. MDB7601AWS Stainless Steel...
    My dryer is making loud screaching noises. Everytime I turn it on to dry clothes is makes very loud screaching noises.
    Sounds like it needs what are called glides or felt. This is what keeps the metal drum from contacting the metal housing. If this is let go too long the drum can be ruined
    Dec 01, 2009 | Dryers
    Loud noise
    Check for bones/glass/ceramic from chipped plates in the food chopper (for lack of a better term). You'll need to disassemble the entire lower arm unit.
    Sep 06, 2009 | Maytag 24 in. MDB7600A Jetclean® II...
    Tv is making a loud screaching noise and no pic or
    Ur high voltage flyback transformer it dead.
    U need a new one.
    Aug 20, 2009 | Panasonic PT-51HX41 51" Rear Projection...
    Whirlpool dishwasher makes a loud notise then
    The spray arms do sometimes wear and need replacenent, and are available fron spares centres.
    The loud noise is probably the water pressure pushing it off at an angle, and instead of rotating, water will just escape out one side - so your dishes will not get clean untill it is replaced.
    Aug 05, 2009 | Dishwashers
    High pitched whining noise from bottom of dishwasher
    the arms are only turned by water coming out of them thro angled jets, they are not electrically driven. the noise will be coming from the circulating pump, probably one of the bearings. no cure except to replace
    Mar 10, 2007 | Baumatic 18 in. BDW45.1 Built-in...
    Dishwashers Logo
    51 people viewed this question
    Top Dishwashers Experts
