Question about Baby Lock Sewing Machines
Babylock ellageo 3 how do I fix the timing
The needles keep breaking. I tried to use heavier needles (embroidering towels), but it didn't stop. Needles are now breaking when I embroider plain cotton fabric, and when I sew. I removed the race, and there are 2 solid needle holes in the shelf, of the race. I had it serviced, last year for this problem, and it was still breaking needles when I got it back, but not to this degree. I managed to monogram a dozen towels, and embroider 5 pcs. of cotton (for a quilt)...sewed together a quilt, and quilted some of it before the issue got so bad I had to switch to one of my other machines, for sewing ( I don't have another that will embroider)
  • 12 Answers
SOURCE: I have a White 955
I know this is strange, but make sure the pressure foot is down. When I quilt sometimes, after getting the bulk under the needle, I forget to put the pressure foot down or it get's knocked back up by the quilt and causes the same problem. Good luck.
Posted on Jan 09, 2009
talk2ginny
  • 34 Answers
SOURCE: thread breaking on Simplicity Denim Star
Hi, when your thread breaks or frays right before in goes through the eye of the needle:
  1. Change your needle - after awhile, the eye can wear down and cause your thread to break or fray, eventhough it looks like the thread isn't even going through the needle. When you change your needle, make sure to install a needle that is compatible with the thread you are using (see below).
  2. If your thread still frays or breaks, make sure you've threaded your machine correctly. Most machines have a hook or bar right above the needle that your thread need to pass thru before you put the thread thru the eye of your needle. Sometimes that spot above the needle is really hard to get to, and sometimes the thread slips out. Always a good idea to double check. If you are still having problems, the needle you are using is probably the wrong size.
There are lots of needles on the market, and lots of threads. You need to make sure your needle is compatible with the thread you use for each project.
The most common needles are size 80 and 90 universal needles, which are fine for most sewing projects. But if you are using a specialty thread, you need to use a needle that is designed to work with that particular thread. For example, top stitching needles have a larger eye than a universal needle, because top stitching thread is thicker than sewing thread. The same is true for metallic thread - needles made for metallic thread an eye designed to allow the thread to pass thru without fraying. Further, if you using fine thread, you need a small needle.
FYI - unfortunately, thread sizes do not correspond directly with needle sizes. Small needle numbers indicate a needle with a small eye. But the smaller the thread size, the larger the thread. For example, size 50 thread is very fine and would usually be used with a size 70 needle. Size 30 thread is fairly thick and would probably be used with a size 90 top stitch needle.
Hope this helps, and remember, you should always change your needle after about 10 hours of sewing, no matter what size needle you are using. If you have more questions, please post again. Thanks, Ginny
Posted on Jan 31, 2009
  • 3 Answers
SOURCE: Babylock Ellure thread issues
I have the same machine and love it. Sometimes if the thread is old that will happen to me.  And also I spray the thread with static guard before i thread the machine in dry cold weather.  Since you said you are an embroiderer I assume you are using the same weight thread top and bottom. The other thing that causes that on my machine is if there is a nick on the spool of thread I am using and the thread catches just a little as it comes off the spool.  I use a fine nail file and smooth off the edge where the little v is to reattach the thread when you are finish using it.  I never use them. You do sew a little and cut off the tail off the top thread before you let it go through the rest of design. I hope you have found the solution but I learned these tricks while having the same problem as you.
Posted on Mar 07, 2009
  • 17 Answers
SOURCE: The needle thread on my bernina minimatic keeps breaking.
There is special thread for denim/jeans. It usually comes in shades of brown. It's a little heavier and might help with the breakage. You might also want to try a little less tension. I assume you already have a Schmetz denim needle?
Posted on Aug 15, 2010
  • 1788 Answers
SOURCE: When I was last sewing, my needle kept seizing up
What are you try to sew? If, it is heavy denim or something, sometimes the needle needs to be a heavier grade, like a 16 or 18 if that is not the problem, I think that it is your timing is causing the problem. You probably will need to take it in for service because if I am right, it is not a do it yourself job. You need the tools and expertise to fix it. Try to go to a shop that does Singer warranty work, I don't know if your machine is new but even if it isn't at least they know the machines. You can find them listed at www.singerco.com. If there isn't one near you, try to find a shop you can trust. Good luck
Posted on Nov 22, 2010
The top thread keeps shredding/ripping while trying to embroider. Using a babylock ellure.
as you thread the machine check for burrs, also on the needle plate
Feb 24, 2014 | Baby Lock Ellure
Needles keep breaking when embroidering.
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time
Oct 17, 2013 | PfaFF Quilt & Craft Pro 7530
The right needle on my babylock keep breaking
Perhaps the needle is not fully pushed in or not tight in the holder or has the needle plate moved and the needle is now hitting it? A bent needle will break as it hits the plate but apart from that I cannot imagine what is causing this.
May 04, 2012 | Baby Lock Sewing Machines
Baby Lock Ellageo will not work. Says to "Lower the presser foot" but it is lowered.
did you have this problem before the tune up or after?
it sounds like part of the computer is malfunctioning
Mar 16, 2012 | Baby Lock Sewing Machines
When I start to try to embroider the red light just blinks and I can not send tothe machine
you might try youtube for video's on embroidery
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Feb 02, 2012 | Sewing Machines
Every time I go over a seam, the thread breaks. I just put in a new needle to see if that would fix it. No go. Changed to new thread. Still breaking. Any ideas? shegkel@gmail.com
Sometimes the thread is old and breaks easily, another cause could be what you are sewing requires a heavier needle such as a #14 or #16. If it is denim or canvas there is a gadget called a jean a ma jig, sold at JoAnn fabrics that lets you sew over heavier seams. You didn't give really enough information to really be able to diagnose.
Apr 20, 2011 | Singer 20U73
Babylock seger machine keep breaking the left side needle.
Try rethreading the machine, and make sure the thread is not wrapped around anything. Then check the tension for the needles. Run a few inches of chainstich off slowly, while watching the thread and loopers make the loops over the finger. Your threads may be in the wrong position, or underneath the wrong parts to start.
Jun 12, 2009 | Baby Lock Eclipse Serger
Embroidery bobbin problems.
Each manufacturer have their own bobbins.......not interchangable
Apr 28, 2009 | Baby Lock Sewing Machines
Serger/sewing machine
You probably are in need of a new bobbin case they are plastic and oif you have broken a needle lately it may have gouged the case and the top thread is getting caught and bunching up underneath. Visit www.stevessewandvac.com you can contact them and have a bobbin case sent to you.
Mar 21, 2008 | Baby Lock Ellure
Sewing Machines Logo
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
SewTechWayne
SewTechWayne
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
