Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
No spinning. I let a coworker borrow my mother's Steamvac SpinScrub, and she cleaned it before she returned it to us. I tried to use it, but the rollers wouldn't spin, even though it still has suction though. When I turn it on, the motor sounds a bit louder and you can smell what seems to be the motor burning. I took it apart to see if I could fix it myself and I found the mechanism that spins the rollers. It's a disk that spins a screw-like piece of metal, and the screw spins the nearby gears that connect to the rollers. I spun the disk with my hand to see if I could figure out what was wrong, and even though I was spinning the disk as fast as I could, the gears would only barely spin. I'm trying not to call my coworker and explain to her that my mother wants her to pay for a new one, so if there's an easy fix or replacement part for my problem, I need to know. I'd like to see if it's possible to fix it rather than make my friend buy my mother a new Steamvac.
  • Anonymous Mar 01, 2008
    I'm all set to clean my carpet, soultion is in, water in in tank, turn on my hoover Steam vac spin brush, and the brushes are not spinning!!
Most common problem when the brushes stop spinning on this model or any "SpinScub" model is that screen filter is clogged as suggested above. If that isn't your problem then likely the turbine has gone bad. Some genius at Hoover designed a metal gear to drive a Nylon gear (Inside the black part that says "Assembled in Mexico". If the brushes jam hard and sudden, the metal gear just shaves the nylon right off. Solution: You will need a new turbine unit. Cost for the part is about $36, installation takes about 15 minutes (about 6 screws and two tubes).
I refurbish and repair vacuums and steam cleaners for a living and see this all the time.
Posted on Nov 12, 2008
My brushes also stopped spinning so I took it apart. (Here is why the brushes stopped spinning on my vac) The motor that spins the brushes (the one that says "ASSEMBLED IN MEXICO")was covered with dirt and grimme. this crap was all over the gears and since this motor is not very powerful, it seazed very easily. After cleaning off the whole inside I lubed the gears with some lube from Walmart and cleaned all the hair and dirt from the brushes. My brushes now spin fine. However, If your gears are worn out then cleaning them will not help, you will need a new motor.
Posted on Jul 11, 2007
There are a bunch of people with this problem. The first thing is to check the little slide out lint trap on the bottom (red on my machine). If this is clogged the brushes won't spin--so I've heard. Check these websites www.mendmy.com/answers.php?id=24062 and for the part schematic for the machine www.vacshopusa.com/f7425.htm
Posted on Jul 02, 2007
I did take my Hoover apart but not with the bottom. You kind of need to take the top off first Take off all the pieces that are easily removeable then, start getting all of the screws out. The top kind of hinges up--I didn't want to do anything I couldn't undo. I picked out some dust and hair there wasn't much inside. I didn't see the belt or anything like that, a big part had a black plastic cover that I was afraid to remove. I put the machine back together and it worked awesome for about one hour. Guess I will try it again. Anymore advice would be greatly appreciated.
How doI hook up furniture/stairs attachment
Hoover Steamvac Spinscrub - How To Attach Hose and ...
? 2:54
https://www.youtube.com/watch?v=XTgoEezUlRs
Mar 13, 2011 - Uploaded by Doug Weeks
... spin tool. Used for stairs and stains etc. hand held. ... Hoover Steamvac Spinscrub - How To Attach Hose and Spin Tool ...Every time I attach the upholstery and then turn the vacuum on, water begins to leak from the bottom.
Hoover SteamVac Connecting Hose & Tools F5915900 ...
? 1:41
https://www.youtube.com/watch?v=heAeez1YlFc
Nov 23, 2011 - Uploaded by HooverVideoGuides
How to properly connect the hose and tools ... Hoover VacuumVideo Guides ... I cant get the water to come out the water isnt coming out the spray part to scrub my furniture ... Get Best Price for Hoover SteamVac Carpet Cleaner here ... for the love of god when not using the hand tool where on the machine ...
Hoover SteamVac Connecting Hose & Tools F5912900 ...
? 1:41
https://www.youtube.com/watch?v=fPU9pXgNo98
How to properly connect the hose and tools ... Hoover SteamVac Connecting Hose & Tools F5912900 F5914900 F591... ... Hoover Vacuum Video Guides .... Hoover Steamvac Spinscrub - How ToAttach Hose and Spin Tool ...
Jan 09, 2016 | HOOVER COMPANY Steamvac Deluxe
How can I get power switch to work on hoover spinscrub steam carpet cleaner?
Replace the switch.
http://www.ereplacementparts.com/hoover-f5914900-steamvac-with-clean-surge-parts-c-37315_37419_37425.html
Aug 28, 2014 | Hoover SteamVac F5914-900 SpinScrub...
My hoover steam vac spin doesnt pump solution
it's probably the pump motor seized and needs oiling this video will give you instructions..
Nov 23, 2012 | Hoover SteamVac F5914-900 SpinScrub...
My brushes dont spin on my Hoover SteamVac F5914-900 SpinScrub
ensure that the selector button is in the appropriate spot for aggitation.
Oct 18, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Were can i find the belt on a hoover steamvac spinscrub the wheels quit spinning on it
There is no belt on the Hoover SpinScrub. The brushes are turned by an air driven turbine. To test the turbine, insert a flat screwdriver into the square hole that the pin on the brush assembly normally fits into, and see if the fitting turns. If it doesn't turn, the turbine has seized up and will need to be replaced.
Jun 20, 2011 | Hoover SteamVac F5914-900 SpinScrub...
The spin scrub brushes do not spin.
Try this: Make sure the setting is set to floor, then remove the little window (you might need a flat screwdriver to "pry" it up) and clean off the filter. If there is a blockage, the brushes will not spin! I hope this helps, if so, please give feedback when asked. Thanks, Rene(the VAcuum Doctor)
Nov 09, 2009 | Hoover SteamVac F5914-900 SpinScrub...
I have a Hoover SteamVac SpinScrub. The brushes
If the speed control switch on the hood is in the On position, it would appear the drive mechanism for the brushes is not spinning internally. The drive mechanism could easily be replaced by a technician.
Oct 03, 2009 | Hoover SteamVac F5914-900 SpinScrub...
My Hoover SteamVac spin scrub #5914-900 will not **** up solution
http://www.hoover.com/pdfs/manuals/F5914900.pdf here is the manual for your model try cleaning the vent inside the plastic container in the front of the machine if its new you may still be under warrenty and contact info for that is on the site above as well!
Godbless
Jun 16, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Was using the SteamVac and it just stopped doing
Bad news! The humming is the pump so it is still good, but that means either the ac to dc converter is bad or the motor went up. The good news, neither would be your fault.
Apr 16, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
327 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
