Question about Frigidaire Affinity ATF7000E Front Load Washer
How to remove coin catcher from affinity front load washer
SOURCE: ERROR CODE E20
Just fixed mine, only I did not have to take it all a part. Just tip it over and reached in thru the opening in the bottom. Took the clamp loose with a phillips screwdriver and pulled the rubber off that contains the filter. Stuck my hand in the opening and pushed up on the filter from the bottom on the rubber container. Out came the filter and I cleaned it and pushed back down inside until it was past the lip that held it in place. Works great, took about 10 mins., not bad for a woman, huh. Thanks for the info, could not have done without your diagram and information.
Posted on Jul 26, 2008
onthejob5130
  • 640 Answers
SOURCE: My front load washer affinity pauses 3 or 4 times during a cycle
the unit is waiting for something,,,like water ,,,or a slow drain..you must see where the unit is ,in the cycles,,and make sure that action the unit is trying to do is able to do...onthejob
Posted on Feb 01, 2009
  • 4 Answers
SOURCE: frigidaire affinity front load washer doesn't start
mabye there is something keepin the door open, thats usually why most washers dont start
Posted on May 11, 2009
  • 4 Answers
SOURCE: how do you check if the coin catcher is plugged on
Remove bottom pannel. you will see a black rubber boot.Undo the clamp that connects to the tub. Pull boot down a little and reach the top of the boot with fingers and pull out plastic coin catcher. Clean out and replace.
Posted on Oct 21, 2009
SOURCE: My Affinity Front load washer, Model #ATF7000ES1
I am having this same exact issue, have you figured out what the was?
Posted on Sep 11, 2010
Where is the coin catcher on a frigidaire front load washer?
Good Afternoon Friend,
I understand you want to know where the coin catcher is located. The coin catcher is located inside your washer, at the bottom right-hand side, attached to the drain pump. If you want to get to the coin catcher, I suggest contacting your local authorized technician for assistance. Hope this is helpful.
-Best Regards-
WP
Jun 25, 2014 | Frigidaire FTF2140FS Front Load Washer /...
Where is the coin trap on my frigidaire affinity
Hello Friend, this is Z. That's a great question!
I understand you are seeking the location of the coin trap on your Frigidaire Affinity washer. Typically, the coin trap is located inside the sump to pump hose, inside the cabinet and under the tub. Hope this information helps to some degree! If there is anything else that I can help you with, please feel free to reconnect!
May 24, 2014 | Frigidaire ATF6000ES Front Load Washer
My washer will not drain
Be careful about removing the main hose on the sump. It contains a coin catcher. The small hoses are a bear to get back on there. Try and remove the **** from within without disturbing the smaller hose. SERVICE MANUAL
Jul 21, 2012 | Frigidaire Affinity ATF7000E Front Load...
COIN CATCHER LOCATION
I can help if you have a clear mind and patient it will take about a 1 hour.
Jan 11, 2010 | Frigidaire Affinity ATF7000E Front Load...
Where is the filter on the kenmore elite h3 washer
There is not a filter per say, but there is a coin catcher in the pump assembly. remove the bottom panel and it will be right in front.
Eric
Oct 17, 2009 | Kenmore Elite 45986 Front Load Washer
How do you check if the coin catcher is plugged on a frigidaire ftf2140fs0 washer?
Oct 01, 2009 | Frigidaire FTF2140FS Front Load Washer /...
Drum wont drain
We had the same problem and the repairman found a Color Catcher sheet clogging the outlet drain inside the machine. Not covered in the warranty but after he removed it, runs like a charm. And cost us $114.00. We called the color catcher hotline and they sent us $50.00 for our problem.
Mar 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity front load washer will not spin
sounds like the impeller on the drain pump is blocked. Noise could be coins trapped in drum. Check filter thoroughly, if you cannot remove blockage you may have to remove tubes from pump to clear out any blockage.
Dec 20, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Washer wont spin
either a bad motor control board or your coin catcher is full of stuff. i would check the coin catcher first. open the front panel and you can see the pump the coin catcher is the part that comes from the bottom of the tub to the pump.Careful when you take it out there will be water in it and you will have to be ready with a towel or shop vac. put it into drain first before taking apart. it will not drain all of the water.
Oct 31, 2008 | Washing Machines
Frigidaire Affinity ATF7000E Front Load Washer Logo
75 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
