Question about KitchenAid Dishwashers
Kitchenaid dishwasher KUDS01DLWH6: normal button keeps blinking, but won't start the wash
The Normal Cycle button keeps flashing and none of the other buttons will work.
  • KitchenAid Master
  • 17,129 Answers
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect.
Check how to remove the control panel: http://www.espares.co.uk/advice/dishwashers/a/3/1287/how-to-replace-a-hotpoint-dishwasher-fascia-p.html
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor. The water pressure must be good and the spraying must be seen to be good. If there is low pumping or pressure then the spray arms will not turn around to inject with pressure. If so the pump must be checked for clogging.
To replace check this link:
http://www.espares.co.uk/advice/dishwashers/a/3/1293/how-to-replace-the-spraying-system-on-a-dishw.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the drain valve/pump activated so as to drain off all the water.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
Posted on Dec 31, 2012
SOURCE: Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Posted on Mar 22, 2008
  • 56 Answers
SOURCE: the light on the buttons that say cancel and normal are flashing and the dishwasher won't turn on.
first thing to try is to disconnect power for 15 minutes and then try again if goes into default again take off bottom panel and behind the black trim will be a tech sheet see if it gives yousome diagonostics sounds like it may be the computer if the power off and on doesnt make it work,.
Posted on May 31, 2009
  • 127 Answers
SOURCE: kenmore dishwasher ultra was quiet guard 3 model
that would be model # 66516012403 correct??
you may have inadvertently set the lock on function..
check this out from your manual...
Lock On
Use the Lock On to prevent unintended use of the dishwasher
between cycles. You can also use the lock feature to prevent
unintended cycle or option changes during a cycle.
When LOCK ON is lit, all buttons are disabled.
NOTE: The dishwasher door can be opened while the controls
are locked. However, the lock must be turned off and the Start/
Resume button pressed to resume the cycle.
To turn on the Lock
Press and hold HEATED DRY for 4 seconds. LOCK ON glows.
If you press any pad while your dishwasher is locked, the light
flashes 3 times.
NOTE: If the Heated Dry option is selected, the light will
temporarily turn off until Lock On glows.
To turn off the Lock
Press and hold HEATED DRY for 4 seconds. The light turns off.
hope this helps,
best of luck,
ttfn
Posted on Oct 25, 2009
SOURCE: electrolux dishwasher all lights blinking and wont
Remove the toe kick by loosening 2 screws. There is a panel there with little lights that correspond to specific problems. The light that is on will correspond to the problem that the dishwasher has detected. Correct the problem and you should be good to go. I have no idea why this is not in the instruction manual. A common one is that there us a leak that the dishwasher has detected, normally in the drain pipe.
Posted on Dec 12, 2009
  • 1382 Answers
SOURCE: dishwasher won't start
The door latch pulls the door tightly closed to prevent water leakage around the door. It is also designed to prevent operation while the door is open. The door latch works in concert with the door switch to ensure that the door is tightly closed and latched
The door switch is a separate part from the door latch and is found inside the cabinet. The switch is off when the door is open. Depressing the switch closes the circuit and enables dishwasher operation. Closing the door does not depress the switch all the way. Only when the door is closed and latched, does the door fully depress the switch.
If the door latch is not properly aligned it may not pull the door tightly closed and the door switch will not be fully depressed. Unless the switch is fully depressed the dishwasher will not operate.
It is a simple matter to determine whether the door latch is the problem. Simply open the door, close the latch and select a cycle and depress the switch. Note that if the test is successful, with the door open, the dishwasher will operate and water may spray out. Make sure to first remove all tools from inside the dishwasher. Do not reach inside the dishwasher during the test. Now, inspect the cabinet where the door makes contact with it and locate the door switch. It may have a protruding button or spike or more likely it is a hole with a piece of metal or plastic inside it. You must fully depress that switch. If the switch is recessed, then use a non-conductive object, such as a wooden pencil, to depress the switch.
Posted on May 17, 2010
Kitchenaid dishwasher kuds30ivwh3 start light blinking. Dishwasher won't start.
Press these keys :
Heated Dry----> Normal-----> Heated Dry-----> Normal
All the l.e.d.s should lite up and then, if you push start, it will go from function to function. push the button 8 or 9 times, then
Reset the power to the unit via the circuit break, then run a normal wash cycle and see if it completes...
Nov 20, 2016 | KitchenAid Dishwashers
Updated details: Normal cycle keeps blinking
Have u tried unplugging it for about 2m and plug it bk in that will master reset everything like u just bought it and see how that's works out
Sep 18, 2015 | Dishwashers
All Cycle Lights on with one blinking sometimes working often not working.
1) tight the connector wires very well and clean with spray contact, of course unplugged the machine
2)resolder all point from the board for colder joint
3) Try again.
4) If the problem persist the problem is the board defective.
5) Call some service tech.
God bless you
Jun 19, 2012 | KitchenAid KUDS301V Dishwasher
Talking about a kenmore 665.16389300 dishwasher. the "normal wash" button is blinking, but none of the other buttons seem to work and the cleaning cycle will not start when i press the...
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad. Hope this helps... Please post back if you need more information.
Daniel
May 18, 2011 | Kenmore Dishwashers
The clean light will not stop blinking so the normal cycle will not run
From another link, clean light flashes 7 times. Turn off breaker for dishwasher, wait 5 minutes, turn back on. with dishwasher door open, push high temp, energy save dry, high temp, energy save dry, then close door, open door, press cancel and then Normal wash cycle. Dishwasher Starts!!!!!! Save myself several hundred $. Was about to buy new one from Lowes!!!!!! Thanks everyone!
Feb 01, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishwasher control light blinking
1 Press down the overfill protection float on the floor of the dishwasher's tub in the right, front corner near the door. If it cannot move up and down freely, the "clean" light will flash.
2 Make sure the dishwasher's water supply is turned on.
3 Look for suds on the inside of the dishwasher and wipe them off with a wet cloth. If the washer's sensor detects suds or foam, it may not run. Use the correct amount of dishwasher soap, not hand soap or detergent for washing dishes in the sink, to ensure suds and foam do not form. Also, make sure the cap on the rinse aid dispenser is secure--this will keep suds and foam from forming as well.
4 Close the dishwasher door. Push the "normal wash" button, then push the "heated dry" button. Push the "normal wash" button again, and push the "heated dry" button again.
5 Watch for all of the lights on your Kenmore dishwasher's panel to turn on and then turn off. The washer may start a new wash cycle at this point; if you do not want it to do so, press the "cancel" button. Otherwise, allow the dishwasher to run through this cycle.
Nov 25, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Normal cycle button blinking, cannot start new wash cycle
Press Heated Dry, Normal, Heated Dry, Normal buttons in sequence within 6 seconds to reset control. Could also be locked. Press and holding the air dry button for four seconds.
Nov 18, 2009 | KitchenAid 24 in. KUDI01IL - Multiple...
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
"normal cycle" light keeps blinking
The blinking button indicates the button is bad. The button console will have to be replaced.
If you need further assistance, let me know
Regards,
reg501
Jul 11, 2008 | Whirlpool 24 in. DU1050SS Built-in...
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Dishwashers Logo
74 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
