Question about SimpleTech SimpleDrive Portable USB 2.0 60GB 5400rpm 480Mbps USB 2.0 USB 2.0 External (STIUSB2560FT) Hard Drive
Simpledrive 96300-40001-001 driver for windows 8
Windows 8 does not recognize my SimpleTech SimpleDrive model 96300-40001-001.
5 Suggested Answers
  • 309 Answers
SOURCE: i upgraded my sysyem from xp to windows 7 and mu
You will need to download a Windows 7 driver for the drive from SimpleTech. Chances are VERY great that there are no Windows 7 drivers developed for this drive. A call to SimpleTech's support line may provide you with a workaround if you can't locate a driver online.
Posted on Jan 24, 2010
lock123
  • 6831 Answers
SOURCE: My simpletech simpledrive 750gb external drive is
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
J-Chris Ward
  • 731 Answers
SOURCE: SimpleTech SimpleDrive Pininfarina 500GB External
Make sure it is plugged in to a USB 2.0 compatible port on the computer.
Posted on Feb 07, 2011
bronk50
  • 27725 Answers
SOURCE: SimpleTech SimpleDrive Portable USB 2.0
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
Posted on Apr 22, 2011
My computer will not recognize the drive. Does it have to be connect to a power supply? I have it connected to a usb port
Windows 7 does not recognize SimpleTech 250GB external USB drive ...
answers.microsoft.com/...does-not-recognize-simpletech-250gb/f7ceccd0...
Just bought a new computer, running Win 7. Drive worked fine on Win XP. ... Windows 7 does not recognize SimpleTech 250GB external USB drive ... I find it hard to believe that a external USB 2.0 drive can't work with Win 7. There must be ...
SimpleTech dvi hdmi pc Hard Drives Questions & Answers ...
www.fixya.com > Forum > Tags > dvi hdmi pc > Hard Drives
Question about SimpleDrive 160 GB External USB 2.0 Hard Drive ... Question about250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive ... my PC does not recognize the external drive 96300-40001-001 Driver Problem: Check whether ..
Dec 18, 2015 | SimpleTech SimpleDrive 250 GB External USB...
How to solve simple tech 160GB EXTERNAL USB HARD DRIVE
I was having a problem on Windows 7 with the SimpleTech 160GB drive not being recognized, went to the SimpleTech site and could not find any drivers - Went to MajorGeeks and found a driver update program - watch when you install it, do custom install so as not to get new homepage or toolbar. But it scanned and found where my drivers were deficient. Updated driver and drive is now recognized
Jul 14, 2014 | SimpleTech SimpleDrive 160 GB External USB...
HP windows 8 does not recognize simpleteck hard drive
I purchased a SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive - Onyx for my Vista machine and all was well. Then I purchased a Windows 7 machine. It would not recognize the devise. I contacted SimpleTech only to be told my model cannot be used on machines newer that the Vista. Recently I purchased a Windows 8.1, did a little research, plugged the SimpleTech into the 8.1 and reformatted it using the Windows feature. The SimpleTech is alive and well on my 8.1.
Aug 02, 2013 | SimpleTech SimpleDrive Pininfarina 500GB...
My windows XP OS won't recognize my SimpleTech SimpleDrive Pininfarina 300GB External USB 2.0 Hard Drive
I found that often, external hard drives just don't have any active partitions and thus don't show up in Windows. Go into the control panel, administrative tools, computer management and then the disk manager and see if it has a partition. If it's just unallocated space, right click and make one.
Jan 16, 2012 | SimpleTech Simpledrive Computers &...
Device no reconized , my W7 don't want install drivers for simpledrive 640 GB pinifarina
The usb device not recognized error generally means the right drivers are not present on the computer. I would expect that Windows 7 can recognize most external HDD automatically, but you might need to install a driver for it.
But try the disk on a different USB port, or even computer, to see if it still works properly.
Jun 28, 2010 | SimpleTech SimpleDrive Pininfarina 320GB...
Hi where i can get the dirver for simple tech simpledrive pininfarina 320gb external usb 2.0 harda drive- blue? please i need one dirver to recognize my usb where i can get it?
If your version of windows dosn't have the driver, there is that possibility that your drive is not supported.
Two things I want you to do ... check the Microsoft Hardware compatability list at http://www.microsoft.com/whdc/hcl/default.mspx
Visit the simpletec web site ... http://www.simpletech.com/support/ and see if they offer something.
If your device is not on the windows compatability list you are probably out of luck unless the manufacturer offers something for it.
I have presumed you are running windows ... since you dont say otherwise.
May 30, 2010 | SimpleTech SimpleDrive Pininfarina 320GB...
SimpleTech 500 GB external hard blinking red light
I got one with the same problem. I opened up the case and hooked up the hard drive to a generic usb to sata adapter that i picked up on ebay and it works fine now if a bit clunky looking.
Sep 10, 2009 | SimpleTech 500GB SimpleDrive Pro External...
I have a simpletech pininfarina 500 external hard-drive and cant find driver software online to install it.computer also doesnt recognise it
I have found a driver page of simpletech:
http://www.simpletech.com/support/support_downloads.php
I believe that driver for your model is not available in the above link.
The drive would not be recognized when it is not compatible with your notebook hard disk.
I suggest you to contact simpletech for getting the drivers as they will have the hard disk drivers.
Jun 19, 2009 | SimpleTech SimpleDrive Pininfarina 500GB...
Simpletech usb drive model 96300-40001-001 Mac OS9 compatibility
If its 9.2 it may be because your mac is usb 1 and your external HDD is usb 2. It will recognize it but sometimes it takes longer to see the drive.
Feb 12, 2009 | SimpleTech SimpleDrive Portable USB 2.0...
Computers & Internet Logo
399 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
