Question about Carver Audio Players & Recorders
Carver pm-1201 making buzzing noise in speakers
Carver making buzz in speakers, amp works and has power but buzz is driving me crazy between songs
Jexx
  • 148 Answers
SOURCE: when amp powers up it makes a buzzing noise-quite loud-
Probably a loose coil or bad ground in the amp itself. Contact www.audiotekx.com, ask for Jason, he can help you and is the best out there. The problem you're having is extremely tricky to rectify, I had an amp with the same problem at it stumped multiple techs, some that had been in the business 35 years, yet Jason got it solved.
Posted on Nov 02, 2006
black dingo
SOURCE: my old yamaha wont stop buzzing
HI SIR .THAT IS NOT BIG PROBLEM.ALL YOU HAVE TO DO MAKE SURE THAT YOUR PRE HAVE THE FLL.1 PROPERLLY EARTHED(THE GROUND FROM YOUR AMP ALSO GOES TO THE PRE )2 ASK YOUR ELECTRONIC MECHENIC TO CHECK IF THER'S NO BROKEN GROUND ON THE BOARD INSIDE.
Posted on Aug 23, 2008
  • 211 Answers
SOURCE: Buzzing in speakers on Carlsbro Marlin 8400 Power Amp
If your volume is down and there's a hum, then it could be that your capacitors in the power supply are blown. Also there could be a problem with the bridge rectifier, possible that there's 1 or more diode's defect. Any technician can reapir that.
Hope it helps,
Gerard
Posted on Jan 31, 2009
  • 11 Answers
SOURCE: nad c270 buzzing in amp
The buzzing is coming from the transformer. It is almost expected of an amplifier of this size, that the transformer (a large one) will excite the resonance of the casework and make some noise.
Posted on Feb 16, 2009
Grubhead
  • 5113 Answers
SOURCE: buzz from lexicon lx-7 power amp
Might be caused by any of the Large Capacitors in the power supply section of the amp.
Klh powered subwoofer model ASW10-120B... when you plug in to power... it makes a loud buzzing/humming noise
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
Jan 05, 2016 | Audio Players & Recorders
My speakers just out of the blue began to buzz in the middle of a song. The volume was low & did not seem to effect the buzzing - after I turned music off speakers began to make a high pitched ringing...
I've never worked on this model so I can't give you a definite part value or location, but you'll probably find a bad filter capacitor (or possibly more than one) in the power supply. The power supply converts the AC power line voltage to the DC (direct current) needed by the electronics. If the filter capcitors don't work, the result isn't smooth and steady, and the result is an annoying hum. You're probably hearing this.
It's possible to replace the bad capacitors, but it's not always easy. The people who make computer speakers don't often design them to be serviced, and sometimes it's a challenge getting into the power supply. But if you or someone you know with some electronic soldering skills is willing to give it a try, you might be able to bring these speakers back to normal. Good luck and thanks for using Fixya!
Jun 01, 2011 | Dell Ay410
My powered mixer Behringer is buzzing
Make sure the buzz doesn't happen because of feedback of speakers into mics. When feedback is processed it often goes to a buzz instead of the usual howl.
Also check that you are running adequate inout into the effect since a very low inout will incur digitizing noise and loss of signal=to-noise ratio.
Jun 02, 2010 | Behringer POWERED MIXER, 20 CH, 400 WTS...
Carver amp started making a low fluttering sound.
I have a Carver amp which developed a "hum" also. As a troubleshooting step only (long term this is NOT a solution) you can use a ground plug adapter that removes the ground lug from the unit. This is an adapter that has THREE (Line, Neutral, Ground) female sockets for the amp to be plugged into, and TWO male plugs to go into a wall socket. If the buzz goes away, you've got a leaky capacitor in the Power Supply section of the amp. It will take some doing to actually fix the problem, but this will narrow down the cause.
May 27, 2010 | Carver PM950 Amplifier
Buzzing noise coming from Vizio HD TV speakers
It ur Vizio tv,The power supply board is the problems.The transformers in the power supply board have gaps in the transformers.The high voltage curents flow that make that buzzing noise.
Apr 07, 2010 | Vizio VW32L 32 in. LCD HDTV
Carver PM900 power amp with hum/buzz
1-shut down all flourecent lamp and check.
2-check for your cables in a good condition and no touching of wires to the body of amp.
3-connect(ground loop isolator)code number(270-054)from radio shack near you and connect it between your audio device(like cd player and amp)
Apr 15, 2009 | Audio Players & Recorders
Carver pm-1.5 power amp has constant buzz in speakers
carver pm-1.5 power amp has constant buzz in speakers, try removing ground jumper on back
Sep 13, 2008 | Audio Players & Recorders
Distortion/noise and buzz in front left speaker
Try to see if the reciever will make the buzzing/noise without anything connected to it except power, and speakers. Tune into a local radio station and see if the noise continues. If the noise has stopped, then you know there is an issue with the player or cable.
Dec 28, 2007 | Onkyo TX-SR503 Receiver
Speakers making loud buzzing noise
From your alternator, Make sure none of your RCA's are near a power wire, check your grounds as well.
Jan 09, 2007 | Pioneer TS-D690R Coaxial Car Speaker
32 people viewed this question
Top Carver Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
jeff5may32
Are you a Carver Audio Player and Recorder Expert? Answer questions, earn points and help others
