Question about Grilling
Need instructions for a backyard pedestal charcoal grill
Did not come with instructions for assembly
CMV9
  • 594 Answers
SOURCE: One touch 22" charcoal grill
here is the link to the weber one touch 22 1/2 grill
http://www.weber.com/support/manuals/?id=1
please do not forget to rate and comment about your experience on Fixya today.
Posted on Aug 17, 2008
SOURCE: Need instructions for assembly of char-broil gas grill
mine wont line up i need help
Posted on Oct 10, 2008
SOURCE: patio classic 6000 charcoal grill
I could not find a replacement but used 2, 18" weber circular grates, one on each end and they overlap in the middle. It is not and ideal arrangement but it allows me to continue to use this discontinued charcoal grill that I love so much
Posted on Mar 31, 2009
SOURCE: I need the assembly instructions for a Four Seasons Gas Grill
I purchased this grill and assembled it yesterday. I noted the area that is providing confusion as it is wrong. Please follow the following instructions. It is quite simple when you have a background in electrical and electronics engineering. These directions should translate my knowledge into step by step instructions for all.
1. Attach the two thinner wires with two terminals on each wire, from the front of the grill head to the larger (Input or Control) terminals on the igniter assembly. These two wires are from the push to turn micro switches on each of the burner control knobs on the grill head. Attach the two smaller terminals on these thinner wires to the micro switch on the side burner control connected as part of the regulator and hose assembly.
2. Attach the three thicker wires from the front of the grill head to three of the six smaller (output) terminals on the igniter assembly. These wires go to the igniters themselves.
3. Connect the two thicker wires from the rear of the grill head to two of the six output terminals on the igniter assembly. The small wire is for the igniter on the bottom infrared burner and the larger, thermally insulated wire, connects to the igniter on the rear infrared burner.
4. Connect the lead from the side burner to the remaining small output terminal on the igniter assembly.
5. Mount the igniter to the front of the right side shelf by removing the battery cover and hexagonal nut. Insert the shaft through the hole in the front of the right side shelf and secure with the hexagonal nut. Replace the battery cap. Do not install the battery at this time.
6. Mount the side burner control by inserting the long end of the control into the side burner assembly. Attach the control to the front of the right side shelf with the two screws held in the front of the control assembly. NOTE: You must remove the screws from the control assembly and insert them through the Off/On bezel and front panel of the right side shelf before screwing them back into the control assembly. Install the control knob for the right side shelf. Verify that the connections to the side burner control micro switch made in step 1 are still intact.
7. Insert the battery into the igniter assembly by removing the batter cap and inserting the AA size battery with the positive (pointed) end out. Replace the battery cap.
8. Test the igniter assembly prior to installing the gas tank and installing the “Flame Tamers” and grates by pushing in on each burner control knob in turn. Listen for a popping sound and look for sparks at each burner.
I hope this helps.
Ed Roberts
President
E. F. Roberts & Associates
www.efrobertsassoc.com
Posted on Apr 09, 2009
  • 51 Answers
SOURCE: i don't mave instructions on how to assemble my grill
use your brain
Posted on Sep 04, 2009
Bought a Weber kettle grill at the weekend and when assembled it is at an angle - checked the legs and have assembled to the instructions?. Any answers?
https://www.cooksillustrated.com/how_tos/6519-properly-assemble-a-weber-charcoal-grill-that-wont-collapse
I would find an image of the specific model of Weber that you have. Maybe several images of different angles of this. Those images may reveal what has gone awry. Some of those images may be at sites selling them, others obtained by a Google IMAGES search.
Weber ORIGINAL KETTLE PREMIUM Assembly Manual
Aug 21, 2017 | Weber Grilling
Instructions for a 18.5 Backyard Charcoal grill. How to assemble
Simply follow the instructions provided with the grill.
No instructions? Do an internet search! (It's what we would have to do anyway, and we're not paid anything to do this.)
May 13, 2015 | Grilling
How to put a backyard grill together
Check it out here http://images.brinkmann.net/docs/pdf/810-5100-0.pdf
Apr 17, 2013 | Brinkmann Stainless Steel All-In-One Gas...
We recvd a "backyard classic
This imported (China) hybrid grill is an exclusive of Sam's Club. You can ether contact them (you aren't the first one to complain of this) or the manufacturer's Customer Support Dept. 1-888-837-1380. Even with the Owners/Assembly Manual they are are not easy to assemble, according to other customers.
Hope this helps you.
Jul 04, 2011 | Grilling
I've never used one and don't have a manual. How do you set up the grills and the pan to smoke something ? Thanks, Bob
It's not really hard to do. There only a few parts to it, as opposed to a gas grill. But, grilling and smoking on a charcoal grill can be a little tricky. Especially with controlling and maintaining just the right temperature. But, have the fun is learning how to use, accepting you mistakes and laughing at them.
I sense that you have either lost or misplaced your Owner's Assembly and Use Instruction Manual .
The link below will take you to the manual. You can download and print it for future reference.
http://images.brinkmann.net/docs/pdf/810-5301-C.pdf
Have a good time and Happy Grilling!!
Jun 16, 2011 | Brinkmann Smoke 'n Grill Double-Grill...
Purchased a toolbox grill and it came with alot of small screws and 1" hard plastic tube like things (4) have no instructions or assembly sheets to let you know what to do with this or these...
KEG Products is the manufacturer of your grill. You will need to contact them for the Owners Manual.
800-232-5347.
Hope this helps to get you up and grilling.
Mar 16, 2011 | Tool Box Grill Charcoal
Grilling Logo
53 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Are you a Grilling Expert? Answer questions, earn points and help others
