Question about Sharp AM-900 All-In-One Laser Printer
Consistent Squeaking Noise
I'm on my second toner and lately, there's a consistent squeaking noise as the unit warms up and it peaks when actually printing the page. Calls to Sharp technicians didn't provide any clues or any help. Reseating the toner or drum had no effect. For the price of another toner or drum, I'm ready to prucahse another MFP probably go back to a Brother.
  • Herman Moye Jun 24, 2007
    Hey 24 seven, Thanks for the suggestion. Does anyone have an illustrated procedure or service manual pages in regards to where exactly are the bushings or how to disassemble the fuser roller? Where can I purchase hi-temp grease.
We've got the same problem and in our case it isn't the nice easily-removable drum unfortunately.
Posted on Mar 07, 2008
I had the same squeaking. I found that it was the drum (the greenish colored roller that pops right out the side along with the toner cartridge). All I did was take a little wd40 and lubricate the ends of the drum. It fixed it right up. Good luck!!!
Posted on Oct 09, 2007
  • 883 Answers
The fuser unit, [near the paper exit] which heat-sets [fuses] the toner onto the paper, has bearings (bushings) that are screaming for high-temperature grease. Open it, and apply some common sewing machine oil onto the bushings. If the noise stops, you will need to repeat this every 2-3 months or disassemble the fuser roller and apply high-temperature grease.
Posted on Jun 24, 2007
  • Marty marty Jun 24, 2007
    you can get hi-temp grease from an auto parts supply store. The bushings for the fuser may be visible when you open the unit (power disconnected), locate the very last roller that touches the paper before exiting the printer and, using a screwdriver if necessary, removing all shields until the bushings are visible.
SOURCE:
Squeaking noise after engine warms up changed all pulleys, finally took of serpentine belt, still squeaks. 99ram 5.9
Ck all units that run against the belt, something is probably locked up and causing the belt to squeak.
May 04, 2016 | Cars & Trucks
Hoover 2300L 6.okg boss. Squeaking when agitating back& forth, not when spinning. Is this a bearing problem? & is it replacable. If so, from where in south australia? Or wherever.?
Washing machines don't usually run silently, but in most cases, a squeaking noise that occurs while the washer is agitating the clothing is not normal and signifies a problem. If the noise only happens when the washing is agitating, the problem is likely connected to the motor or your water pressure. Depending on the specific cause, you may feel comfortable fixing it yourself. Otherwise, call a professional.
Other People Are Reading
The Agitator
  • Agitators are located in the center of the drum, or basket, of top-load washing machines. Front loading washing machines do not use agitators -- instead, gravity moves the clothes from the top of the drum to the bottom. Agitators usually consist of a tall cone fitted with arms at the base. The purpose of the agitator is to rotate the clothes and soapy water around the tub to clean the clothes. The agitator itself is not usually the cause of the squeaking noise. It is powered by the drive mechanism, which consists of a motor, clutch and gears.
Motor Problems
  • A repetitive squeaking noise during the agitation cycle may signify a problem with the motor. Specifically, the belt on the motor may be wearing out. Some motors use rubber couplers, which also wear out easily. The belt is necessary for the agitator to turn, but over time, it wears thin, just like the belts in your car's motor. An easy way to test for this problem -- if you're handy -- is to take the belt off the motor and then run it. If the squeaking noise stops, the problem is indeed your belt. Of course, this means your agitator won't move. Replacing the belt should fix the problem.
Water Pressure Issues
  • The tub, or drum, fills with water right before the agitator turns on, and water continues to circulate throughout the washing process. As the tub fills and water circulates, you may hear a squeaking or squealing noise if you have high water pressure. This sound is caused by the force of the water moving through the pipes. To adjust this, turn the knobs on the hot and cold valves on the pipes that go into your washing machine.
Considerations
  • New washing machines may squeak at first as the parts "warm up," according to the GE Appliances website. The noise should disappear after five complete washing cycles have run on the machine. Unbalanced loads, overly heavy loads and loose items in the drum may also cause noise when the agitator comes on, but these things usually do not produce a squeaking sound.
Read more :http://www.ehow.com/info_12131280_washer-squeaks-agitating.html My Washer Squeaks When Agitating eHow
Jun 14, 2015 | Hoover Washing Machines
Occassional squeaking from front driver-side tire
could be wheel bearing ,could be cv joint could possably be bushings in suspenion.
Aug 15, 2013 | Toyota Cars & Trucks
Altima 2005 squeaking in the rear
Chattering is caused by components tooclose to each other. This happens when bushings wear out. Get under there (not whenthe car has been running) and shake the exhaust system and any suspension component to see if you can make it chatter. Then look for why the part is able to move so much.
Sep 03, 2017 | 2005 Nissan Altima
My P2055DN is making a squeaking noise while printing. Not that big of a deal I guess just annoying. I hope nothing major is on the horizon. Please advise if I should worry about this or not. It...
If you are printing invoices from the MP tray the pickup roller might be squeaking against the separation pad (common with this design). Other common squeak is toner cartridge noise.
Jun 21, 2011 | HP P2055DN LaserJet Monochrome Printer
My HP P1505 makes a squeaking noise when there is a motor turning inside, but not when it's just on. Sounds like a roller or bearing. It has a non-HP toner cartridge. Does this model have a known...
Most noises on these models are caused by the cartridge. Typically fuser issues will cause a growling noise not a squeak. If the inside of the machine is dirty you could have toner on the transfer roller busings. Try a different cartridge first, you fastest and most likley problem.
Apr 30, 2011 | HP LaserJet P1505n Printer
If my printer is squeaking what could be the problem besides the toner cartridge?
Squeaking noise is usually caused by the toner cartridge, expecially after market ones. But if its not the toner, I've seen the mirror motor cause a rotation noise in the 1300/1200 series printers.
Nov 18, 2010 | HP LaserJet 1300 Printer
My hp 2605dn is squeaking, i can't figure out where it is coming from
i have found that the toners cause a squeaking noise.if you have old toners change one at a time to find the problem toner
Mar 12, 2010 | HP LaserJet 2605dn Printer
Consistent Wheel Squeaking - Right Front Wheel
This may be a worn down front brake shoe or pad, some after market pads come with a wear indicator.
This wear indicator rubs the rotor when the pad is in need of changing.
Apr 19, 2009 | 1993 Cadillac DeVille
Squeaking
the squeak is coming from the drum unit. If you take out the drum and rotate it by hand it will most likely give you the same noise. you may be able to stop it by pouring some toner on it, but in reality it is more annoying than a problem.
there is a blade that scrapes off excess toner from the drum, it is slightly dry and causes the squeaking, technicians usually use a special powder that looks like baby powder to "lubricate" the blade, and stop the noise.
Aug 11, 2008 | Canon PC1061 Copier
Sharp AM-900 All-In-One Laser Printer Logo
471 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
