Question about Panasonic TH-42PD50U 42 in. Plasma EDTV
Hooked up hdmi cable from laptop to my plasma TH42PD50U and nothing on tv screen
  • 45 Answers
SOURCE: 42" pansonic plasma hdmi problem
if I understand your question properly.. its because your direct tv output doesnt broadcast in high def so its giving you the standard tv definition inputs which are RGB or Component.so you will lose picture quality cos its running at fewer lines or pixels. hope this helps
Posted on Mar 25, 2008
SOURCE: i have only the cable and hdmi hook into my
Using your input key on the remote should switch you to the other modes. If you cannot access any HDMI or other input labels, go to your menu, and into the Input Labeling menu (under settings) and make sure you have all the inputs you require enabled. Its possible you (or an out of the box error) put these other inputs offline, which is why you aren't able to access your media from HDMI. If all inputs are enabled, and labeled, double check all the HDMI inputs on the unit. Plug what you are using with HDMI into each port, having the power on and sending information to the television. In some rare cases, I've seen that it doesn't allow access to the HDMI without it providing some source information.
Hope that helps.
Posted on May 08, 2009
roety
  • 585 Answers
SOURCE: When i connect my hp laptop to my panasonic plasma
Hi, you probably won't get audio from the HDMI port on a laptop post the exact model so I can check for you, you can get an adapter from the audio out to the in on the TV, as for the resolution, lower the resolution on the laptop before connecting it, simply right click the mouse anywhere on the desktop, then left click on properties then settings, then pull the resolution level to 800x600 save by clicking apply and OK , try a few settings to get the highest resolution the TV can display correctly.
Thanks
E
Posted on Aug 03, 2009
tvservice306
  • 458 Answers
SOURCE: Panasonic TH-46PZ85U Plasma TV
Symptom:
TV shuts off unless all the input (phono and HDMI) cables are disconnected. The
symptom may be intermittent.
Cause:
There is an abnormal AC voltage entering the TV from one of the input cables or AC
outlet.
Remedy:
Follow the Testing procedure to determine if there is a problem external to the product.
Concept
Constant symptom
If the TV no longer shuts off when all input cables are disconnected, then one of the
input cables is introducing abnormal voltages into the TV. Panasonic Plasma TV sets
have 3 wire AC plugs.
As a result, abnormal voltages introduced into this TV will cause the TV to shut off for
protection.
Intermittent symptom
If the abnormal input voltage is borderline (marginal), the TV shut off symptom may be
intermittent. However the cause may still be detectable with a voltmeter.
Protection Proof:
Release the protect mode - the TV has to be unplugged to reset this protection circuit.
Threats from the HDMI input:
Excessive voltage from an HDMI cable connected product will activate the Plasma TV’s
protection circuitry. Placing an isolating / buffering connector (sometimes called a voltage
conditioner) between the TV and the HDMI input cable often solves the problem.
Testing -
Unplug all the HDMI inputs from the TV. Turn on the TV. Plug in the HDMI inputs one at a
time. The cable that causes the TV to enter the protection state is connected to the product
that has the excessive voltage (and signal). Avoid connecting this product until an isolating
connector is found.
Posted on Jan 27, 2010
  • 11800 Answers
SOURCE: My Panasonic Viera 50" 1080i
The Panasonic doesn't detect the presence of the signal on the antenna input so it just skips it. shut down the player and turn the cable box on before attempting to switch sources.
But why aren't you using the Composite RCA connection on the cable box ? Not only you would get a much better image but the tv would detect that change in the AV source and should switch by itself. If it doesn't then the control processor is faulty and the entire mainboard will will have to be replaced
Posted on Nov 05, 2010
Partial black screen on mulitple (but not all) inputs on panasonic plasma tv
Sorry but it's time to shop for another tv the cost of repairing would cost almost as much as a new unit.
Mar 18, 2014 | Computers & Internet
No OSD menu on Panasonic ST50 plasma TV
My guess is that the OSD function can only be enabled directly at the Panasonic TV.
Nov 18, 2013 | Yamaha Audio Players & Recorders
How to hook up a panosonic 50" Flat screen plasma
Try connecting TV to DVD with a scart lead or a hdmi cable now hdmi v cables are the next best thing from a scart lead
Dec 21, 2011 | Televison & Video
Panasonic TH-46PZ85U Plasma TV All 3 HDMI was working fine with cable box, PS3, XBOX360. I used to connect my pc to the tv with a dvi-hdmi cable, but recently unplugged it. So I tried to plug in the same...
Symptom:
Cause:
outlet.
Remedy:
Concept
Constant symptom
protection.
Protection Proof:
Testing -
connector is found.
Jan 27, 2010 | Panasonic Viera TH-46PZ85U Plasma TV
No dvi pictur showin up on my plasma tv
try a lower video output resolution on your PS3
Nov 09, 2009 | Gateway GTW-P42M303 42 in. Plasma...
How do a hook up a hdmi cable to my laptop and than display my laptop screen on a tv?
I have a Dish hd set and on the side of the t.v i put in the Hdmi cable to the Hdmi 3, but when i switch to that channel it comes out static and nothing appears....what should i do??
Jun 03, 2009 | Tivo Series2 TCD649080 Video Recorder
Screen craked broken screen
Is it a Plasma TV? Are you saying the screen is cracked? do you have a top box cable box? Also, make sure you have your TV input set to HDMI if you have an HDMI cable hooked up between your cable box and TV.
Apr 04, 2009 | Panasonic TH-42PWD6UY 42 in. HD-Ready...
Samsung HDMI issue
Have you try to replace your HDMI cable?I recommend you to pick up a good Monster HD700 HDMI cable from a local retail store like best buy or circuit city.In case it isn't the cable problem,you could return it.
However,when you are a using the HDMI cable,it is normally either have both picture and sound or nothing at all.Are you sure you didn't hook up the audio OUTPUT from your TV back to a receiver input?
Or even an optical output from the TV to the receiver?
solutiondoct
Sep 24, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Flashing screen
It sounds like its set for s video at 480p for analog tube tv's you need to hook up to tube tv and change in settings for hdmi
Jul 24, 2008 | Sony Playstation 3 (PS3) Console
Panasonic TH-42PD50U 42 in. Plasma EDTV Logo
29 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
