Question about Car Audio & Video
Kenwood kac 720 - Car Audio & Video
  • 631 Answers
SOURCE: kenwood KAC-PS201T
The first thing you must do is to confirm that you have voltage at the amp. Just because the fuses look good, that doesn't mean you're getting power to the amp.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Posted on Jan 22, 2008
zzedly
  • 300 Answers
SOURCE: kenwood kac 9152D
Usually, protection mode is caused by one of these conditions:
  • Shorted speaker outputs.
  • Speaker output shorted to ground.
  • There is an internal issue, causing DC voltage to be present on the speaker outputs.
  • Amp overheats.
  • Ground connection is insufficient for amp or HU.
I'm not sure of the history or symptoms of your amp, but those are the reasons why the amp could go into protection mode.
Posted on Mar 13, 2008
etirbynnor
  • 655 Answers
SOURCE: To bridge a Kenwood KAC-9102D
Hello laurogleal,
The Kenwood KAC-9102D is a mono amp. There is no bridging. Having two sets of terminals is just a more convenient way of connecting two subwoofers. The amp is stable down to 2 ohms impedance, so it is safe to run 2 4 ohm loads in parallel.
Hope this helps.
Posted on Apr 28, 2009
wikkidd420
  • 96 Answers
SOURCE: want to bridge my subs I have a kenwood kac-719
from what i have read about your amp, it is already a mono amp, and rated for 2 ohm's, so all you have to do is wire the subs in parallel (both positives together to positive and both negatives together to negative) or series/parallel if you have dual voice coils (both positive and both negative paired on each sub, then positive from amp to positive on one sub; negative on that sub to positive on next sub; then negative on sub to negative on amp) Note though, with two dual voice coil subs, you can have a 1 ohm load with the first set up, which can damage your amp. Let me know if this helps :)
Posted on Jun 11, 2009
  • 136 Answers
SOURCE: connecting subwoofer to kac-7201 kenwood amp
from your sub connect one short piece of cable from + on one side to - on the other side using the same diameter cable as you are running to the sub from amp . this will leave you with + and - on opposite sides of speaker these will then run to the amp +to+ and - to- on the mono side of connetor which is one left + and one - right and the amp switched to bridged
Posted on Sep 03, 2009
What size amp is the kenwood KAC-9103d amp
im not sure what you mean by what size amp....whether you mean physical size or wattage (power) so I have provided a website link for all the specifications that you require..........
http://my.kenwood.com/Car_Entertainment/Power_Amplifiers/KAC-9103D
PLease vote if you liked this response....
Aug 20, 2010 | Kenwood KAC-9103D Car Audio Amplifier
Leads for old kenwood car stereo amps
Hey wdalley69, I've got the KAC-8070. My setup has the crossover module for it.
Oct 27, 2009 | Kenwood Car Audio & Video
KAC-8070 kenwood 4-channel power amp
Audio section
Max Power Output (4 ohms, 1kHz)
Rear 70W + 70W
Front 35W + 35W
Max Power Output (4 ohms, 1kHz, 10% THD)
Rear 45W + 45W
Front 25W + 25W
Max Power Output (4 ohms, 1kHz, 1& THD)
Rear 37W + 37W
Front 20W + 20W
Frequency Response (-3dB)
Rear 2 Hz ~ 100 kHz
Front 5 Hz ~ 50 kHz
Sep 27, 2009 | Kenwood KAC-8101D Car Audio Amplifier
How do i get my kenwood kac-8402 out of protection
first thing first open it up ull need to check ur heat sinks and capacitorsand see if any of them are blownd if there are blowend replace the bownd once. and try it
Jul 07, 2009 | Kenwood KAC-8402 Car Audio Amplifier
Hello laurogleal,
Hope this helps.
Apr 28, 2009 | Kenwood KAC-9102D Car Audio Amplifier
Connecting subwoofer to kac-7201 kenwood amp
Mar 22, 2009 | Kenwood KAC-7201 Car Audio Amplifier
Schematic
Try manualsparadise.com or go to the Kenwood web site and look in the support section.
Dec 18, 2007 | Kenwood KAC-848 Car Audio Amplifier
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
