Question about Zanussi F1045W Front Load Washer
Cannot remove rear panel of Zanussi FJR1454 W
I have removed the top and the hex screws on the top and at the rear. I realsie the rear and side panels come off as one but whiel the top seems to be moving the bottom seems solid. I cannot see any other screws to release. I am doing this to change the belt.
  • 135 Answers
At the bottom on eacvh side there is a small round plastic plug which is hiding the other screws.
Please post back if any further assistance needed.
Thankyou for using Fixya.
Posted on Jan 18, 2009
Doorhandle
for passenger side:
1. unclip screw cover 'center flap' of inside door opener plastic cover, flap is 3/8"x 3/8" (center of plastic cover)
2. remove phillips screw now showing
3. push fabric panel (edge of door opener plastic cover-at hinged end of chrome handle) to allow uncliping of edge of plastic cover (top rt & lwr rt (for passenger side) of plastic cover)
4. open chrome inside door handle to allow plastic cover to be removed-slide plastic cover toward rear, free end of door to remove cover
5. remove switch panel-gently pry with wide non maring pry bar (cover wide blade screwdriver using cloth) do rear of sw panel 1st (don't pry front edge)
6. slide switch panel toward rear to allow removal
7. remove large phillips screw under sw panel
8. remove the 2 plastic covers near top, hinge edge -use plastic spoon handles to encourage caps to pop off. May also require small screwdriver approx 1/8" in to complete pop off
9. remove the 2 phillips screws w/ captive washers
10. remove 3 phillips/hex screws along the bottom inside of door panel
11. on outside/rear edge of panel push the 2 center pins of each in about 1/8"-this allows the clip to be pulled out w/ pin pushed in
12. remove plastic cover (REAR OF SIDE MIRROR)-pull window edge up and back.
13. lift rear of door panel (not hinge edge) up allow hinge edge to pivot around lower pin in door (hinge edge)
14. remove the 2 rt edge "L" brackets (gently pry center plastic pin out) (note the color and replace as removed)
15. slowly peel the clear plastc away from the non hinged end to expose the plastic panel with 3 phillips head screws
16. remove the 3 screws and panel for access to door handle.
17. using access area now available unlatch the rod attached to exterior door handle (unclip plastic to rotate clip up to allow rod to slide out-toward hinged edge)
18. using access area now available remove rod from ext door handle from inside door area
19. remove the 3 -10mm head bolts
20. remove the ext door handle (bottom edge out first)
reverse order to replace door handle
Mar 24, 2014 | 2003 Toyota Avalon
I need to replace the hinge receptacles on a Jenn-air wall oven (WW30430PC). How do I access those parts?
The only way to replace the hinge receptacles is to pull the oven out of the opening. If you need parts you can get them on the link below. Also if you call the link below they will walk you through on how to replace.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=45883&diagram_id=28594572#d28594572
May 16, 2011 | Jenn-Air Ovens
How to replace on switch
  • Unplug the Frigidaire dryer from the wall outlet and move the dryer two feet from the rear wall.
  • Locate the screw on each end of the control console, securing the console to the dryer top. Remove the screws with a Phillips-head screwdriver. Lift the front of the control console and rotate the console toward the back of the dryer.
  • Remove the three hex head screws that secure the rear of the top panel to the dryer with a nut driver. The three screws will be on the top rear edge of the top panel.
  • Grab the top panel on each side and slide the panel forward. This will release the front spring clips that secure the front of the top panel to the dryer. Lift the top panel off the dryer and set the panel out of the way.
  • Dec 23, 2010 | Frigidaire Dryers
    How do I remove the top and front panels of my Maytag MDG7600AWW dryer?
    Open the door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
    Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
    The top panel is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top panel lip.
    Open the door then lift the front of the top panel and tilt it toward the rear of the dryer.
    Reinstall the top panel and the front panel by following the removal steps in reverse order.
    May 06, 2010 | Maytag MDG7600AW Gas Dryer
    How to remove top of Maytag dryer
    The top panel can be lifted only after the front panel is removed. Open the door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
    Apr 28, 2010 | Maytag Neptune MDE4000 Electric Dryer
    How do i access the battery
    It appears the battery is under the left side of the gas tank.
    First get a 3 mm hex key and remove all the side panel screws and remove the screws that hold the cover around the gas filler cap, and remove the two plastic side panels. After the screws are out the side panels the panels slide forward and will come out. There are two hex screws (size ?) that have to be removed to release the fuel tank. One is under the tank and is accessed from the rear with about a 1 foot extension for the hex bit. The other is on the front rt side and is quite obvious. There is enough fuel hose on the tank that you can simply prop-up the front of the tank with a piece or wood or anything convenient and get access to the battery. I put battery tender leads on my 696. Hardest part is removing all the small screws that hold the side panels and cover for the fuel tank.
    Oct 21, 2009 | 2008 Ducati Monster 696
    How to reach the battery on 696 monster ducati, and install charger.
    Under gas tank cover
    Oct 20, 2009 | 2008 Ducati Monster 696
    Zanussi FJD1666W heater removal.
    There is no easy way to access the heater without stripping it down.
    Remove top cover.
    Remove 2 scews at rear bottom of cabinet.
    Remove 2 plastic covers at front bottom sides of cabinet, and remove 2 screws located in holes, you will need a nut socket to remove them.
    Remove inlet hoses, and undo screw at top where the hoses connect to, prize up the plastic retainer that holds the valves in place.
    Remove screws at top of cabinet that hold the 2 halves together.
    Then lift rear half of cabinet clear of the front.
    At the bottom rear you will see the heater element located.
    Undo center nut and remove element..
    Fit back all parts in reverse order.
    Not an easy job. Good luck.
    Plz rate my solution.
    Thanks.
    Jan 14, 2009 | Zanussi FJS1225W Front Load Washer
    Unsure how to access drier to put on new drive belt
    Here is my own solution...
    Disconnect from mains (of course) remove top (2 screws at back near top) Unplug electric connectors (on back panel, top RHS). Make sure note what goes where! Lie unit down on front remove screws (2) holding the drum spindle cover (centre of back) and remove cover pop off the circlip holding drum spindle, and washer unscrew back panel - hex headed screws round outside of back Remove screws at bottom of back panel which screw into the plastic vent housing (3 I think) Lift whole back off. (there's a plastic lip at bottom - need to pull away from this a bit) The drum spindle will be unsupported now, so don't move unit Full access now to drum and motor beneath Get and put on new belt reassemble.
    Actually, having got into unit, found could not get belt from local spares shop (it had closed down), so bought new drier!
    Dec 15, 2008 | Zanussi TD4212W Electric Dryer
    Zanussi F1045W Front Load Washer Logo
    191 people viewed this question
    Top Zanussi Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    shaun taylor
    Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
