Question about Maytag Neptune MAH5500B Front Load Washer
Hot water won't stop running
Yesterday the water to my washing machine froze. Since the lines thawed the hot water continously runs to the machine even if the machine is OFF. Do you have any idea which part might have been damaged by the freeze
  • Anonymous Feb 07, 2009
    hot water to washing machine won't stop unless turned off manually cold works fine
  • Maytag Master
  • 3,463 Answers
It is the hot inlet valve that is the problem. replace it and that should solve the problem.Plz rate my solution.
Thanks.
Posted on Jan 18, 2009
Subzero 245 stopped making ice, repairman suggested replacing supply line and leaving unit off to thaw out frozen inlet tube. Did that and now have a water leak, but not coming from connections and water...
It is possible that the line running off the fill valve has broken where it runs through the machine from heat . or when it froze it popped off where it attaches to the fill tube in the back. Does the leak stop when you turn off the icemaker? May be a defrost issue if it doesn't
Feb 06, 2014 | Sub-Zero 245
My moms pipes froze to her washing machine. They thawed and the machine filled with water but they won't wash. She can hear a buzzing sound like the machine is trying to wash the clothes but nothi
Yes , I think the valves also must have jammed in the process and when the hot water filled up in due course it must have released.
It is best to switch off water supply to the machine in such times.
Jan 23, 2013 | Washing Machines
Samsung washing machines water drains continously
The drain hose is too low, you need to lift the height of the drain hose as it is siphoning and won't be able to fill to the required level.
Mar 05, 2012 | Washing Machines
We have a Bosch Washing Machine nexxt 100 series wfmc1001uc, the water lines froze without us realizing, we started to washer while lines were frozen... in the end, we had to replace the hot water inlet as...
Bosch Washing Machine nexxt 100 This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Feb 05, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
Machine water pump continously running on power
problem more than likely faulty triac in electronic board solution : replace motor control board
Feb 25, 2010 | Fisher and Paykel Fisher & Paykel Washer
Hot water running continously
If your FAV6800AW/FAV9800AW has water flowing water with the power off or water fill cycle has ended then your water valve is stuck open. I’m sure crud in the valve seats preventing the washer water valve from seating. The water valves are sealed units and need to be replaced. I Haven’t had to replace yet but I will post links to the SM and parts replacement link. See this post for possible issue with a new substitute 12002242 part replacement.
The Service Manual for reference. Sears Parts Direct for reference.
Appliance Zone AZ
Sears Parts Direct old p/n 25001001 new p/n 12002242
May 08, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Whirlpool LSQ9500LQ0 stops runs only for about 2 minutes
Try this first..Same thing happened to me yesterday..
I pulled the washer away from the water source..unscrewed the water lines from the water intake (not the washer)..there is a screen in the both hot and cold ...my screens were filled with debris..after cleaning the screens the washer works just fine..try this easy fix before you start looking into things like the motor or a switch somewhere...
Dec 19, 2008 | Washing Machines
No hot water to wash
Is the hot water hot that is coming to the washer? Are you using the correct settings on the unit? If yes to both then either the solinoid water valve is bad or the timer switch unit is bad. Try going to a totally hot water setting. While turning on the machine feel of the hot water line at the machine and see if you notice a buzz or feel a click as you turn on the machine. On this setting does water run in and is it hot or cold. If water runs and it is cold try going to a total cold setting and see if you get cold or hot water. Is this a new setup or has it been working and stopped? If new, you could have the hoses connected backward. If you get water in both hot and cold settings but cold both ways then your hot water heater is not working....let me know....
Feb 10, 2008 | Frigidaire FEX831CS Top Load Stacked...
Maytag Neptune MAH5500B Front Load Washer Logo
48 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
