Question about Denon AVR-2113CI Receiver
How do you connect Bose 901 speakers to a Denon AVR 2113CI
2 Suggested Answers
marsrover
  • 682 Answers
SOURCE: Bose 901 speakers hookup
http://www.bose.com/pdf/customer_service/owners/og_901.pdf
Posted on Jul 04, 2008
How to connect denon AVR 1513+Bose Acoustimass 5
Plug the speaker wire from the speakers themselves directy to the receiver or you can plug them into the acoutimass module and the module into the receiver using speaker wire.12_16_2013_3_46_09_pm.gif
Feb 19, 2013 | Denon Avr-1513 5.1 Channel 3d Pass Through...
Denon avr-2113ci hdmi can't change source
Can you update the firmware on the amp as this could also affect the connection between the players.
Jan 15, 2013 | Denon AVR-2113CI
How do I turn tape monitoring on my Denon AVR 3803 on/off? I recently purchased a set of Series V Bose 901's and I am having a difficult time figuring out how to activate the equalizer.
Short answer from personal experience.
There is no way around this part. Get a separate power amp for the 901's if you want to use them in a multichannel way or alongside non-901 speakers.
Connect the Active EQ between the pre-outs and the amp input. Run speaker assignment, levels, etc and have fun.
Oh, but you don't have pre-outs. Bummer. Most AVR's will NOT pass digital sources to analog tape outs. Page 40 of the manual confirms that.
no can do. sorry. You need Pre-Outs to feed an external amp.
May 22, 2011 | Denon AVR-1803 Receiver
Will bose 901 speakers work with a AVR-4308CI
Yes they will, I have a set on a denon receiver amp ( not sur of the model # its in another town). The main thing for bose 901's is that the equlizer has to be connected somewhere beteen the preamp and the main amp, most higher power amps have a switch that opens a set of patch cord jacks that the Eq. can be connected thru. So you should verify this feature with any amp you chose. With out the Eq connected the 901's have no bass or highend sound.
Apr 11, 2011 | Bose 901 VI Main / Stereo Speaker
I cannot connect my bose 901 series v1 active equalizer to my denon av surround receiver avr-891
The reason: You can't use the Active EQ (or ANY processor) in a tape Monitor loop with anything but 2-channel stereo material. As soon as you activate the loop you lose digital sources.
Adding to YOUR particular problem is that the Denon doesn't have a volume-controlled pre-out to feed that amp. If you want to deal with controlling the separate amp volume manually you COULD connect the Active EQ between DVR Out and the 901 amp IN but you would have a stereo mixdown instead of true front channel from the speakers.
Bummer.
Dec 26, 2010 | Bose 901 VI Main / Stereo Speaker
I have a Harmon Kardon AVR 247 and I want to connect with Bose 901 VI equalizer. No other speakers are connected, just the 901's. Where do I connect the wires from the equalizer to the AVR 247...
I have this exact setup. 901s are my Mains.
The AVR247 has PreOuts on all of the channels.. No jumper to remove either. Just get a power amp or two and place the 901 EQ between the AVR247 and the Power Amplifier.
Jeff
Nov 28, 2010 | Bose 901 VI Main / Stereo Speaker
I have a Denon AVR 3805 receiver. It does not have a Main Amp in or a pre Amp out in the back. How do I properly hook up the Bose 901 equalizer to this receiver? I use the 901 speakers as surround...
By properly, you must mean WITH the Active EQ.
According to this picture, you're in luck BUT...
http://www.audioholics.com/reviews/receivers/denon-avr-3805/denon_AVR3805_rear_lg.jpg
(Short answer from personal experience.)
There is no way around this part. Get a separate power amp for the 901's if you want to use them in a multichannel way or alongside non-901 speakers. A good 100-wpc amp will do. (I like Carver)
Connect the Active EQ between the Front pre-outs and the amp input. Run speaker assignment, levels, etc and have fun.
Helpful Hint: If you don't have sufficient between-speaker room for proper reflection off the front wall you CAN turn the 901's around and you won't believe the amount of air these things push! I have actually felt it ten feet away after explosions or crashing ocean wave sounds. Now THAT is multi-media.
Oct 14, 2010 | Bose 901 VI Main / Stereo Speaker
Denon AVR 2807 with Bose Acoustimass 15
Well,i can tell you are not very focus,cause you posted Denon AVR-2807 with Bose AC 15 problem,but under your details,you put down AVR-5807!
First of all,it is so unfortunate that you are NOT able to gain and experience to true ability in sound for this wonderful receiver when you are using a dual tweeters speakers and expect to have good sound separation as a TWO WAY speakers(a tweeter and a midrange-for true high frequency and mid frequency sound separation.)
Secondly,you have defeated the audio configuration of the Denon AVR-2807,since all your speakers are control BY the Bose subwoofer.
Now,i could show you a way to hook this up,and it doesn't matter how you connect them, they are the "bicycle tires" installed with a "Porche"engine if you know what i mean.
If you want a good recommendation for your "beast",i will more than happy to show you the way!
Cheers,
solutiondoct
Sep 28, 2008 | Denon AVR-2807 Receiver
Jul 02, 2008 | Denon AVR588 Receiver
Is it possible to to have a home theatre with Denon AVR 3600
one option that may yield results, since the bose connection to equalizer is presently not possible is to set the speaker out put on the denon for 'small' on all but the front speakers.
and then set the delay for all speakers based on the distance to the amp.
this should result in better audio that that with the bose eq.
will work on the issue of using the eq. with the denon if you like. but, you will likely not improve on the sound with the denon set up correctly.
good luck
mark
Dec 17, 2007 | Bose 901 VI Main / Stereo Speaker
Denon AVR-2113CI Receiver Logo
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
