Question about John Deere 325 345 Tractor Service Pricing Manual
John deere ignition module 345 blows fuses - John Deere 325 345 Tractor Service Pricing Manual
  • 246 Answers
SOURCE: My fuse keeps blowing on my neutral safty switch
Hello williamhowar:
>>As I am Sure you are Aware, Most Backhoes do a Lot of Bouncing and Jarring. LOL.
>>If you can Trace the Harness, then Check of a Bare Wire that is May be Touching the Unit.
>>If the Harness is Good, then I will Require some More Information about this Unit in Order to Assist you Further.
>>Send me the Model Numbers Off the Unit, Please. With these I can Locate the Proper Manual and Better Assist you.
Thanks.
Respectfully
jbridger (John)
Posted on May 14, 2009
  • 9 Answers
SOURCE: john deere mod 345 no spark
first find the wire that is grounded to mower to ignition
and check that it is isolated if mounted on some plastic and disconnect it
if it runs to start switch check wire for cuts also
most common problem is the coil located under the top plate held on by 4 /5 screws on sides.
remove top and follow plug wire back to coil
you can clean the curved edges of coil that are against motor {magneto} with sand paper and clean mag
remove plug and lay threads securely agains frame and check for spark {hold by wedging not by hand as you can get a jolt!}
Posted on Aug 20, 2009
nova2nv
  • 197 Answers
SOURCE: Fuse blows when engage blade
The electro-magnetic coil side of your PTO is shorted out.On the 318 it is very easy to replace,just under front screen.
Posted on Nov 14, 2009
  • 394 Answers
SOURCE: Our new to us john deere 345 tractor won't keep running
You may try blowing backwards from behind the fuel filter into the gas line. Not to much air pressure though. Make sure the gas cap is off.
Posted on Mar 13, 2010
nova2nv
  • 197 Answers
SOURCE: Hello my name is John. I have a 345 John Deere
345's have a habit of the choke sticking at the carb.Another problem they have is the fuel pump diaphram will crack and allow your engine to fill up with fuel,to much fuel in crankcase will end up past the rings when not running and smoke pretty bad when fired up.
Posted on Jun 25, 2010
When I turn my john deere sabre off at the key the engine shuts down, however ten seconds later the fuse blows. Also brand new safety switches are killing engine when released. Suggestions?
Somewhere, probably in the ignition switch circuit there is a short circuit - otherwise the fuse would not blow. You'll need to take a test meter to each circuit in turn to isolate the circuit and then find the short. Be logical and patient!
Apr 29, 2015 | John Deere Garden
Why would a mdl 1035 john deere tractor keep blowing the starter fuse
There is a distinct possibility that this tractor was originally equipped with a 6 volt system. If it has been upgraded to a 12 volt starter, the ignition will need to have a resistor installed to bring it back to 6 volts.
I could be all wrong on this but it's worth checking.
Mar 06, 2015 | John Deere Garden
John Deere 345 won't shut off
I would start with either replacing the key switch, or tracing the wires to make sure they are not touching together somewhere, completing the ignition circuit.
Apr 14, 2013 | Garden
John Deere 345 Water cool Seems not to be Firing
Time delay module on the left upper side of engine.It has a couple of yellow wires,1 red,1 black,1 orange.These will fail,replace it.
Apr 21, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Mar 13, 2010 | John Deere A,b,g Tractor Carburetor Float...
Our j-d 345 lawn mower tries to start but it seems
Time delay module?Does it seem to crank faster?
Sep 26, 2009 | John Deere Garden
John Deere 325 345 Tractor Service Pricing Manual Logo
118 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
