Question about Danby 60 Pint Dehumidifier, Premiere Series, DDR6009REE
My danby DDR6009REE compressor will not kick on, the filter is clean, the tank is empty there is no obstruction in front of grill, this happens frequently we need it to keep the room at 95 degrees. It is in a small room with no windows
4 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: I need a manual for a Danby Dehumidifier
You can get the manual on the link below.
http://demandware.edgesuite.net/aabh_prd/on/demandware.static/Sites-Appliance-Site/Sites-CompactAppliance_Primary/default/v1302286861520/pdf/ownersmanuals/danby/DDR6009REE_manual.pdf
Posted on Apr 11, 2011
Testimonial: "Just what I needed thank you"
heatman101
  • 43501 Answers
SOURCE: I have a new Danby
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Posted on May 27, 2011
heatman101
  • 43501 Answers
SOURCE: Danby Dehumidifier DDR5011 is not working
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
Posted on Sep 14, 2011
How do I determine reason that my Danby Dehumidifier isn't cycling on to compressor for more than 3-4 seconds at a time? Fan always runs but compressor only kicks in for 3-4 seconds then back off.
I would say low on gas or bad switch/thermostat.
The compressor probably has a shutoff for low freon. You would need a set of gauges to check for that.
Bad thermostat? You'd need a ohm meter.
User error? What kinda settings or controls do you have on the control panel?
There was a recall on these in 2014 for catching on fire.
Gree Reannounces Dehumidifier Recall Due to Serious Fire and Burn Hazards...
Jul 16, 2015 | Danby DDR6009REE Dehumidifier
DEHUMIDIFER WONT START
empty the tank, and clean the dust off of the condenser in the front or clean the filter. if it still won't turn on, may have a bad sensor or a siezed compressor.
May 09, 2012 | Midea Dehumidifiers
Danby 25pt dehumidifier not collecting water, fan is working can hear the compressor kicking in, is almost 5 years old though, is it time for a new one?
Christina, there are 5 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 2..
1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
I hope this will help you troubleshoot & solve the problem. Thanks for choosing FixYa.
Aug 18, 2011 | Danby DDR586R Dehumidifier
My Danby DDR583R dehumidifier no longer dehumidifies unless I set the humidistat to the lowest, constant run setting--then the compressor kicks on. The humidity reading says 14% which I know to be...
There are a several things that can mimic a faulty humidity sensor.
1. The air intake filter is clogged and needs to be removed and cleaned.
2. The coiling coils need to be cleaned.
3. Ambient air temperature at floor level is between 40 - 60 degrees.
level
problem.
If the above fails to help solve the problem, replacing the Humidity Sensor is certainly an option. But, before you jump into it, make sure you have an accurate wiring diagram, so you know which sensor is which. As the part does not come with installation instructions.
I hope this helps you and thanks for choosing FixYa.
Jul 27, 2011 | Danby DDR583R Dehumidifier
The compreesor only stays on for a few seconds then kicks off. how do I set it so it will stay on
Dave, there are 5 basic, yet solvable reason for what you described. Please pay particular attention to numbers 1 & 2..
level
problem.
Hope this helped you to troubleshoot & sole the problem.
Jul 20, 2011 | Danby DDR5009EE Dehumidifier
Danby premiere mod. unit shuts down after operating for a few minutes
There are 5 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 2.
level
in basement applications . Raising the unit up off the floor,
problem.
Hope this helps you to troubleshoot & solve the problem.
Jul 09, 2011 | Danby DDR4010E Dehumidifier
Power light flashing on danby dehumidifier won't work
As I tell most folks who complain about the problem you're having
the unit without the filter. To remove the filter on your model it will either have a pullout tab on
the right side of the unit, behind the louvers on the front. Or remove the bucket and the filter
frame will be just on the inside top of the opening behind the front louvers.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to clean
in basement applications level. Raising the unit up off the floor,
problem.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks
Jun 25, 2011 | Danby DDR2504 Dehumidifier
I have a new Danby Model #DDR6009REE and have set it up and while the fan operates no water accumulates in the tank. Pressing the switch inside makes no change.
heatman101
Apr 30, 2011 | Danby DDR451 Dehumidifier
I just bought a Danby Dehumidifier model: DDR6009REE The fan runs constantly even when the humidity setting is reached and the compressor is off. has anyone patched the power for the fan by putting...
All new generation dehumidifiers are designed to have the fans run all the time and the compressor comes on when the relitive humidity rises above the setting that you have chosen. I spoke with the company and asked them why this is so, and they told me that it is more energy efficient to have the machine on all the time so that when the compressor kicks in there is a small draw on electricity.
Apparently when the old dehumidifiers came on it was the compressor that turned on immediately, and the fan, and this caused a very high current draw. The new design has the fan on all the time and this helps to circulate the air evenly around the area being dehumidified - thus more efficient overall coverage.
I understood their explanation, but still do not like this new method of operation.
Jun 26, 2010 | Danby DDR6009REE Dehumidifier
Danby 60 Pint Dehumidifier, Premiere Series, DDR6009REE Logo
61 people viewed this question
Top Danby Dehumidifiers Experts
Bill Long
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
