Question about McCulloch Electrical Supplies
Mcculloch fg6000mk 11 hp 4 stroke 5.70 kva 5700 watt cost?
Cost of generator to buy
mamicheddy
  • 79 Answers
SOURCE: McCulloch fg6000mk: generator motor runs, no power.
You need to trace out the power wires the come out of the genset. They will end up on a breaker. With a volt meter measure both sides of the breaker. If one side has voltage and the other side doesn't, then your breaker is opened. Press the breaker in closed to see if it actually closes. If it don't then you will need a breaker. However, if no voltage is being produced, it is possible that the voltage regulator let go.
Posted on May 09, 2009
  • 142 Answers
SOURCE: McCulloch Generator model FG6000mk 11hp run good
I did not understand how you turn on generator, as it is always turned on.
If you use the ON/OFF switch it is stopping the prime mover.
If you reset the AC breaker without load, and it stops - it means that you have short circuit after the breaker. Check the output receptacles.
Try this link:
http://weborder.husqvarna.com/order_static/doc/MOUS/MOUS2008/MOUS2008-FG6000MK-7096FG6024-966991401.pdf
Posted on Jun 14, 2010
  • 142 Answers
SOURCE: 11 hp 5700 watt generator wont fire
If you could not start in spite of oil and gas change, checked gas supply, spark plug, ignition cables and coils (magnetos) and so on whitout success, then try this:
Your generator has a low oil level protection, which stops the ignition of the motor.
After "a couple of years" sitting without or with old oil, the level switch may have got lazy or stuck down.
If your oil level seems to be good, while measured, find the oil switch and try to shorten or disconnect it.
If you succeed in running the generator change or repair the oil switch.
I hope that this will be helpful, because I don't have your device in front of me, but some people rank such an answer with 2 thumbs, which means useless. Better dont rank.
Posted on Jul 24, 2010
SOURCE: my 5700 watt 11 HP McCullough generator wont
The spark coil is bad if you have no spark
Small engine repair. Part is expensive.
Have you checked spark for sure?
1) Spray WD-40 directly into carburetor
If machine has spark, it will fire
2) Is exhaust port clogged with carbon and dirt?
3) Get new spark plug
Pull out old spark plug
Put spark wire on plug
Hold spark plug wire with fingers
Put spark plug threads against metal opening where spark plug came out.
Metal to metal
Pull cord or push starter
Look for spark between metal
No spark, then spark coil is bad.
Posted on Oct 26, 2010
kel1guy2002
  • 3740 Answers
SOURCE: I need a spark plug
Hi and welcome to FixYa. I am Kelly.
The standard plug is an NGK "BPR5ES" or Denso "W16EPR-U" There are a number of alternate plugs out there if you use the number above in a cross reference book.
One thing to note... the generator has a "Low Oil" sensor and if the oil level is low you will not see any spark. If after you install a new plug and you still do not have spark... un-hook one wire from the low oil level sensor and check spark again. If you unhook the sensor wire knowing full well the oil level is full.and have spark; the sensor is either dirty or bad.
Thanks for choosing FixYa,
Kelly
Posted on Feb 19, 2011
Has gas in bowl and fire but wont start without starting fluid
McCulloch u spray starter fluid Power Generators Questions ...
www.fixya.com > Forum > Tags > u spray starter fluid > Power Generators
McCulloch power generators u spray starter fluid related questions and ... Question about 13HP 338 Cc Portable Generator # FG6000MK ... My 5700 watt 11 HPMcCullough generator wont ... My generator will start if I spray it with either but won'tstay running in less I keep ... The bowl has gas in it and the needle is clean.
This generator McCulloch fg6000mk 11hp has no spark. I've ...
www.fixya.com/.../t7785814-generator_mcculloch_fg6000mk_11hp_no
Jan 13, 2011 - this generator McCulloch fg6000mk 11hp has no spark. I've checked the gas bowl , a small amount of water in the - McCulloch ... water in the bowl not much also sprayed a small amount of starting fluid in .... My 5700 watt 11 HPMcCullough generator wont start. I'm getting good gas to the plug but no spark.
Won't start. I have a never used McCulloch 5700 11HP ...
www.dqrkc.com/support/t1325485-start
Dec 2, 2008 - Question about McCulloch 13HP 338 Cc Portable Generator # ...evaporated. you might tryt a little spray starter fluid in the spark plug ... My generatorwill start if I spray it with either but won't stay running in ... The bowl has gas in it and the needle is clean. ... My 5700 watt 11 HP McCullough generator wont.
1325485 Won't start. I have a never used McCulloch 5700
Jan 21, 2016 | McCulloch 11 HP 5700 WATT GENERATOR
What would make a McCulloch FG6000MK 11 HP generator start and idle fine but not able to rev-up and generate power.
Have to an ultrasinic cleaning of the carburetor and see if that will clean up the problem,
Bad on parts though most are NLA. but a carburetor from a Honda 11hp horizonal might work on this Chinese Honda cloned engine.
Nov 24, 2014 | Electrical Supplies
Where can I buy a mcculloch 5700 generator carburator
if you can not find a carburator you may need to find a re-built kit on the internet.
Aug 28, 2012 | McCulloch 11 HP 5700 WATT GENERATOR
I need a manual for my fg 6000mk 11 hp, 5700 watt, 5.70kva, 7097-fg6097
Hi Gary,
The manual can be downloaded from this link:
http://www.mccullochpower.com/ddoc/MCCO/MCCO2008_USen/MCCO2008_USen_FG6000MK-7096FG6024_966991401.pdf
You need to have Adobe reader installed on your computer.
You can get it on the Adobe website, www.adobe.com
Hope this helps!
Oct 17, 2011 | McCulloch FG6000MK 5700Watt 13 HP 338CC...
What spark plug does a mc collough 5700 11 hp generator take?
The manuacturers part number is: 030506Q01F910
Manual:
Is there a brand.... on your current spark plug?
Most generators will do just fine with an NGK BPR5ES spark plug in most any environment.
Kelly
Aug 23, 2011 | McCulloch 13HP 338 Cc Portable Generator #...
I have a Mcculloch 5700 watt Generator that needs carburetor rebuilt and can't seem to find parts. Any suggestions on where to get parts ?
Take the make and model #s to a lawnmower shop, they can get what you need, if they do not have it in stock. Also remember to check in tank strainer for restriction.
Mar 04, 2011 | McCulloch FG6000MK 5700Watt 13 HP 338CC...
We have a McCulloch 2300 Generator. It runs, but no electrical output. What should I look for ? Glenn
look for a reset button, either on the generator or on the dash with the recepticals. my 5700 has fuses there also
Jan 03, 2011 | McCulloch FG6000MK 5700Watt 13 HP 338CC...
My 5700 watt 11 HP McCullough generator wont start. I'm getting good gas to the plug but no spark.
Metal to metal
Oct 25, 2010 | McCulloch 13HP 338 Cc Portable Generator #...
Electrical Supplies Logo
64 people viewed this question
Top McCulloch Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a McCulloch Electrical Supply Expert? Answer questions, earn points and help others
