Question about Fujitsu Plasmavision P42VCA30EH 42 in. Television
NO ENCIENDE Y PARPADEA
EL INDICADOR DE ON/OF PARPADEA UNA VEZ EN VERDE, OTRA EN ROJO Y PARA. LUEGO EMPIEZA DE NUEVO, ROJO, VERDE, STOP
4 Suggested Answers
  • 3 Answers
SOURCE: modelo fujitsu asy14rse-w que cae agua por el split
la linia de donde la agua se debe salir a de estar tapada. quitale el cuvertor i mira como esta la line de pvc adentro
Posted on Sep 12, 2008
  • 963 Answers
SOURCE: Hola. Cordial saludo. Tengo el siguiente problema
Mi espa?ol es s?lo un poco. Utilice traductor Google (translate.google.com) para obtener esta informaci?n:
http://www.techlore.com/article/15444/Understanding-Sony-Television-Blinking-Codes/
Resalte con el rat?n y pegar en el traductor Google, si es necesario.
Dos parpadeos parece ser un problema de alimentaci?n.
Posted on Mar 05, 2011
bronk50
  • 27725 Answers
SOURCE: conecte mi cargador en un puerto usb he ido una especie de corto y ahora no enciende
google translate
plug my charger into a USB port I have been a kind of short and now will not start
did you smell anything burning ? or was there any sort of burning smell
test all power and data leads that attach to your hard drive SATA
the leads from your (motherboard to your hard drive) make sure they have a secure dust free connections and are not faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty
even something as small as faulty fan lead can cause you problems
computers need all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all power and data leads make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
check the CPU central processing unit make sure it has thermal paste and dust free secure seating
also check your computer ram modules and cmos battery make sure it has charge and they are dust free and securely seated some motherboards cmos batteries are soldered in
hope it helps
Posted on Jul 24, 2012
Como programar tv vizio a control dish
Estimado Chuy, primeramente le quiero pedir una disculpa por responderle tan tarde, estoy consiente que en este momento posiblemente su control ya este programado a su televisor. De cualquier manera quiero tomar el tiempo para proveerle los pasos y codigos a programar el control, puede ser que en un futuro los necesite. Para programar su control ala t.v hay ciertos codigos que permiten que el control se programe a las funciones de la t.v. Los codigos para una t.v Vizio son 627, 505 y 506 Oprima el boton transparente de T.V localizado en la parte de arriba del control por 5 segundos hasta que los demas botones se iluminen en rojo, una vez se iluminen ingrese un codigo seguido por el signo de numero por ejemplo: 627#, luego el boton de 'Record' 3 veces (es el boton ***** con un punto rojo) una vez haga esto vera que el boton de t.v se iluminara 3 veces. Esto debera programar el control a su t.v. Si necesita ayuda puede contactarme directamente a kimberly.escobar@dish.com. Gracias por su tiempo.
Jan 06, 2012 | DISH Network IR Remote Control
CODIGO PARA PROGRAMAR CONTROL REMOTO
¡Hola
Cuatro d?gitos de los c?digos de control remoto universal para TV Insigina son los siguientes
0103 0189 0217 0135
0133 0116 0167 0456 0029
Cinco d?gitos del c?digo remoto universal para TV con RCA Insigina RCR312W modelo de control remoto son los siguientes
11423, 11564, 10171, 11204, 11326, 11517, 11710, 11963, 12002
Entrada directa de c?digos
1.Pulse y mantenga presionado el bot?n SETUP hasta que el indicador rojo permanezca encendido y luego suelte el bot?n SETUP.
2.Pulse y suelte el bot?n del modo deseado (TV, VCR, etc.) El indicador rojo parpadea y luego permanece encendida.
3.Introduzca el c?digo de 4 d?gitos a partir de las tablas de c?digos. Nota: despu?s de una entrada de un c?digo v?lido, el indicador rojo se apaga. De un c?digo no v?lido, el indicador rojo.
4.Con el dispositivo, la prensa de canal hacia arriba. Si el dispositivo responde, sin necesidad de programaci?n adicional es necesario. Nota: Si algunos botones no funcionan el dispositivo, pruebe uno de los otros c?digos para su marca.
M?todo de b?squeda de c?digo
Si despu?s de intentar "Entrada directa de c?digos" el dispositivo no responde, o si su marca no est? en la lista, trate de hacer una b?squeda en la biblioteca de c?digo para el c?digo, siga estos pasos. OK.
Sep 19, 2011 | Insignia IS 20" TV040919 TV
Codigos del control remoto zenith zn620
Helo
Tres d?gitos a distancia universal para Zenith son los siguientes:
000 / 001 / 004 / 023 / 038 / 058 / 059 / 064 / 121 / 135 / 136 / 153 / 0016 / 0017 / 0092
Cuatro d?gitos de los c?digos de control remoto universal para Zenith son los siguientes:
0121 0009 0050 0078 0091 0138 0059 0131 0038 0111 0134 0153 0064 0004 0135 0226 0227 0245 0247 0252 0266 0288 0310 0338 0358 0023 0058 0039 0001
Aug 04, 2011 | Zenith ZN620 Remote Control
Mi televisor no enciende solo se prende el foco rojo y parpadea en donde dice timer
bueno tengo una television pt4298hd akai el problema no enciende parpadea el foco de timer 10 o 9 veces y no enciende destape la tapa de atras y desconecte un cable rojo que tiene el nombre de screm y la television enciende pero no se mira como debiera porque se mira el color verde y el rojo pero como si le faltara el color azul mi televisor es una dlp akai de tres lentes y quisiera saber cual es el problema
May 02, 2011 | Akai PT4298HD Rear Projection Television
Mi control de dish no quiere hacer nada quien me ayuda
Hola mi nombre es Kimberly Escobar con DISH Network servicio al cliente. Lamento escuchar que este teniendo un problema con su control de DISH Network, seria un placer asistirle proveyendole informacion que le sea de uso para resulusionar el problema. Si el control no esta haciendo nada primeramente debe asegurarse de que el control este en el modo de SAT significando que cualquier boton que oprima el control el boton de SAT en la parte de arriba se debe encender en rojo. Si ningun boton se enciende en rojo puede intentar poner baterias nuevas en su control, si no funciona significa que el control no sirve necesitaria uno nuevo, si el boton de SAT se prende en rojo puede intentar reprogramar el control a su recibidor. Para hacer esto tiene que accesar la pantalla de System Info en su televisor, puede hacer esto oprimiendo el boton de Sys Info enfrente del recibidor. Despues en el control va a oprimir el boton de SAT hasta que los demas se enciendan rojos cuando vea que se encienden rojos ingrese un numero entre 1-15 seguido por el signo de numero (#) y el boton de record una vez. Trate el control deberis funcionar. Tambien puede entrar a nuestra pagina web http://www.dishnetwork.com/SupportSection/remote-control aqui encuentra ayuda en como arreglar el control y el procedimiento. Si necesita mas ayuda por favor contactenos directamente al 1800-333-DISH gracias espero esto le ayude.
Feb 09, 2011 | DISH Network IR Remote Control
Cambie el filtro por uno nuevo y la luz sigue prendida en rojo como cambio a color verde
Una vez que filtran la luz se vuelve roja, sigue siendo rojo hasta que se resetea. Para restablecer el indicador del filtro, presione ambos LOCK y DISPENSADOR DE AGUA
botones simultáneamente y mantener durante 4 segundos. Hacer luz verde que parpadea tres veces cuando el indicador
se restablece.
Feb 05, 2011 | Maytag MSD2655HE Side by Side Refrigerator
Hola amigos tengo un problema con un Tv Sony wega modelo kv-29fa515 chassis BA6/9 el tv me enciende osea arranca bien imagen, color y sonido pero alcabo de cinco segundos se me cae la imagen osea queda la...
por favor si alguien tiene informacion que me sirva para arreglar esta falla,le agradesco de corazon.el tv enciende y la pantalla queda oscura,el filamento enciende y los voltages de catodo estan elevados(192v) si aumento el escren, aparece imagen muy al fondo,la pantalla tiene lineas de retorno y cambia de azul a verde.
Jan 12, 2011 | Televison & Video
COMO PUEDO QUITAR EL MODO DEMOSTRACION DE UN SONY BRAVIA 32BX3000
Entras al menú .... ajustes.... inicio automático. Ahí empieza una configuración inicial del TV y encontraras una seleccion de Modo entre Tienda y domestico. Seleccionas domestio y listo.
Un saludo...
Nov 02, 2010 | Sony Televison & Video
Mi ricoh aficio 1013 sale error SC 552, quisiera saber a que se debe eso....!
así usted tiene un problema con la unidad de fusión, antes de llamar a un técnico que usted podría tratar de restablecer el código al entrar en el modo de servicio y restablecer el código de allí. Siga los siguientes pasos y usted podrá fácil de hacerlo:
1. pulse el botón (amarillo [C] cancelar)
2. a continuación, pulse el número en este
orden 1-0-7
3. a continuación, pulse el botón (rojo [C] parada) y por algún tiempo, hasta que en la pantalla LCD no aparece el menú de servicio.
4. cuando vas a ver el menú de servicio en la pantalla, oprima el número 1 sobre la almohadilla de número de la tecla y presione (OK) y luego con el cursor de flecha derecha al lado del botón (OK) Pulse hasta que vea en la pantalla el número [5.Mode ], cuando este está en la pantalla pulse el botón [OK] y luego otra vez con la flecha del cursor al lado de la [OK] pulse hasta que en la pantalla aparecerá el número de [810. Perdí mi código SC] cuando este aparece, pulse el número 1 en el número de teclado (confirmar que en la pantalla que está escrito el número 1 y presione juntos la tecla [OK] y la tecla para seleccionar el tipo original (esta clave se encuentraen el marco del [Aceptar]) Ahora que usted ha reinicia la máquina por la que se escuchará el sonido como empieza cuando se enciende por el tiempo que los abetos también si usted no presiona la tecla junto obtendrá un [error] en la pantalla LCD si esto suceda, inténtelo de nuevo, si después de algunos momentos de tratar de que no son capaces de reiniciar la máquina llame a un técnico.
Jan 14, 2010 | Ricoh Aficio 1013 All-In-One Laser Printer
MI PROYECTOR EMPIEZA A ENCENDER Y SE APAGA.
buenas noches. tengo un problema con mi proyector.. hace unos minutos encendio y se veia la imagen pero luego lo desconectaron y cuando volvi a encender solo prende la luz de power pero no sale la imagen quen podra ser???
Aug 29, 2009 | Dell 2200MP Multimedia Projector
Fujitsu Plasmavision P42VCA30EH 42 in. Television Logo
94 people viewed this question
Top Fujitsu Televison & Video Experts
Electro Med Services...
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
