Question about Nintendo Wii Fit for Wii
Wii fit weighin too light!
We got a wii fit for Christmas and it has suddenly started weighing about a stone too light! (Worked out by weighing myself on scales as well as on the wii fit!) It was stored stood up against a wall overnight just before this happened and im now wondering if that has caused the problem! Is there any way of rectifying this to make it weigh correctly again?
I have tried resetting individual miis but this hasnt worked.
  • senadevaney Feb 09, 2009
    Problem is that it weighed me too light and now it is calling me a heffer. I weighed myself three times this morning and got a 8 pound differential.
  • Anonymous Mar 05, 2009
    I had the same problem and adding the extra footpegs and new batteries worked like a charm. Weighing perfectly now. Thanks. Now I'm really motivaated cause I now show in the overweight section which is where I though I was!
    Sniper:
  • 80 Answers
I would suggest that you ensure that the board is calibrated properly and that you don't step on it until directed to do so. I'm sure you're already doing this, because it won't let you go on without doing so.
The other solution I would offer is to change the batteries in the unit, and ensure that you are setting the Balance Board on a smooth, sturdy, and flat surface. If you are on shag carpet, it will not function properly. If you have average carpet, try using the little adapters that attach to the feet.
Remember that for the purposes of this program, the exact weight isn't what is most important, but relative weight. Any time you are tracking weight loss, be sure to mark your progress using the same scale. If you chart the Wii vs traditional scales, you should notice that the decrease is the same, regardless of what your starting point may happen to be.
Posted on Jan 27, 2009
I just read this and followed the advice to add the feet to the bottom. It worked like a charm, I was weighing in 35 lbs lower than normal! (I wish!)
Hope this helps you as well!
Posted on Jan 28, 2009
Wii board does not show correct weight, sometimes im a stone heavier or half a stone lighter my actual weight
The Wii balance board isn't known for being hugely accurate, I wouldn't pay too much attention to what it says your weight is.
May 10, 2011 | Nintendo Wii Fit for Wii
My Wii Fit is synchronizing just fine with the console but it disconnects the remote when it does. Also, when it asks me to turn on the Wii fit the light flashes and then goes off. The batteries are brand...
I had the same problem myself. After nearly 40 mins of trying and trying the Wii fit board eventually synchronized with out the Wii remotes being affected. The main thing is to make sure you do not hold down the red button on Wii console for more than 10 seconds as this unsyns the remotes. Hope this helps
Jan 07, 2010 | Nintendo Wii Fit for Wii
Hello- We have a wii console that we got at christmas time. today I went to use my wii fit and put in the disc and the I recieved a message telling me to remove the disc, shut off console and look at my...
The only thing I can think of is that when you were moving, your wii got damaged.
I can only recommend sending it to nintendo to fix, or buying a new one. Only do these if someone else does not find a solution
Aug 04, 2009 | Nintendo Wii Console
Wii Fit Weighing Me Wrongly
You should probably put it on a board but if that doesn't work, you could try putting something weighing 12 pounds on the board or in your pockets or whatever.
Feb 28, 2009 | Nintendo Wii Fit for Wii
Wii Fit Doesn't work
Do not stand on the Wii fit board until it says to. The board needs to reset itself before any tests are completed. For best accuracy, complete all the initial tests and follow the instructions to the letter.
Feb 05, 2009 | Nintendo Wii Fit for Wii
Canot use Wii fit balance board
Ensure batteries are fresh. Ensure that Wii Fit (or other Balance Board game) is started up completely before pressing the power button.
Jan 04, 2009 | Nintendo Wii Fit for Wii
I got wii fit the disk wont work !!!!!!
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Dec 27, 2008 | Nintendo Wii Console
Wii fit
contact wii
Jun 28, 2008 | Nintendo Wii Console
Nintendo Wii Fit for Wii Logo
369 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
