821 : Type mismatch; 'tools.ConvertToMB'
Getting Script error "821 : Type mismatch; 'tools.ConvertToMB'" when trying to recover the macine from recovery media. Also, it is only the CDROM device that seems to be detected by the boot strap: "Port-04: CDROM, HL-DT-ST BDDVDRW GGC-H20N" I'd assume the HDD should reside at port 2 but the message is "Port-02: No device detected", as for the other ports 0-5 (except for port-04). Is my HDD broken and the only option to get a new one?
SOURCE: HL-DT-ST DVDRAM GSA-T20N ATA Device
i have the same probleme and i want a solution plz
Posted on Sep 17, 2008
hardkiss69
  • 43 Answers
SOURCE: DVD/CDROM NOT WORKING
Hi, it appears that CDW/DVDRAM is only detected in BIOS but in normal windows. This is a known issue from Microsoft eventhough you are using Windows Xp or Vista the CDW/DVDROM is not detected and does not appear in My computer icon. This can be easily fixed by a registry tweaks.
Please click on this link http://support.microsoft.com/kb/929461/en-us and then delete the upper/lowerfilters which is blocking the CDW/DVDROM to appear on your windows.
Hope this helps!!!
Thanks
Posted on Sep 18, 2008
try this ..
you must start regedit ( start -> run [See screenshots at the bottom] Type here: regedit )
search the HKEY_LOCAL_MACHINE/SYSTEM/CurrentControlSet/Control/Class/
search for "4D36E965-E325-11CE-BFC1-08002BE10318"
if you doesn't find anything, search only for a part of the string.
now search the propertys UpperFilter an LowersFilter and kill the value. If only one prop. is there, you must kill only the one value
on my laptop it works!!
http://www.computerhilfen.com/hilfen-26-186214-0.html
cheers ...
Posted on Nov 03, 2008
SOURCE: code 39 error, not working driver corrupted
DisparitionCD was the answer. thank you. A setup information software from the internet.
Posted on Nov 14, 2008
antking
  • 51 Answers
SOURCE: HL-DT-ST DVDRAM GSA-T40L ATA DEVICE
1. Using Device Manager
To fix this error, first try to update the driver from the Device Manager. To open Device Manager, right-click My Computer on your Desktop, and then on the Hardware tab, select the Device Manager button.
In the Device Manager window, identify the CD or DVD drive item (with Yellow exclamation mark), right-click on it and select Update Driver. Follow the screen instructions to update the device driver and restart your PC.
if can't try this:
2.To fix the error by editing the registry, perform the following
steps:
1. Exit and close all applications currently running on your PC.
2. On Start > Run type Regedit and press the Enter key.
3. Next, navigate to the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\ Control\Class\ {4D36E965-E325-11CE-BFC1-08002BE10318}
4. Delete any of the following registry entries if they exist under this key:
* LowerFilters
* LowerFilters.bak
* UpperFilters
* UpperFilters.bak
5. Restart your PC and open My Computer to ensure that the CD-ROM drive is visible.
6. Also, open the Device Manager again to ensure that the yellow exclamation mark and the error code is now gone.
7. Restart your PC and open My Computer to ensure that the CD-ROM drive is visible.
8. Also, open the Device Manager again to ensure that the yellow exclamation mark and the error code is now gone
Posted on Jan 02, 2009
Deleted photos after transfering from a sds card which i also cleaned is there any way of getting them back, they are not in the recycling bin.
Are you looking for the solution to get back the deleted data from the digital camera memory card then you should try the software to recover camera memory card on your PC. This software comes with the capability of restoring the whole memory card data.without single error.
Jan 28, 2013 | Cameras
Tip
How to Recover Pictures From Fujifilm FinePix S700 Storage Media
With 7 mega pixel camera, 10x optical zoom, 2.5 LCD, picture stabilization mode, and i-Flash intelligent Flash, the Fujifilm FinePix S700 fulfills all the requirements of any photographer. The storage media (SD and xD memory cards) used in this camera allows the photographer to save audios, videos, and photos of different sizes. Damage in storage media can occur any time, resulting in fatal consequences, like inaccessibility of data saved in the memory card. In most cases, the photographer encounters an error message stating that the card is corrupted. To overcome such corruption scenarios, the photographer needs to restore the data from an updated backup. But all photographers do not create a backup on regular basis. For them, a third-party Camera recovery software acts as a boon and helps them recover the data.
As a real-world instance, you encounter the below error message while trying to view the pictures saved in your SD card (inserted in Fujifilm FinePix S700):
"CARD ERROR"
After the above error message pops up, the data saved in the SD card becomes inaccessible.
Cause:
Few main causes for the above error message are:
1.Incorrect SD card format.
2.Incompatible SD card.
3.Memory card corruption due to unexpected camera shutdown, virus infection, and interrupted read or write operation.
Resolution:
To resolve the above error message and to access the data saved in SD card, you will need to:
1.Use a compatible SD card.
2.In case of memory card corruption, format the card in Fujifilm FinePix S700 camera. Though formatting brings the card in reusable state, all the audio, video, and picture files get deleted. To recover the deleted data, you will need to choose a powerful Camera recovery software.
Such recovery tools use effective scanning methods to ensure complete Camera data recovery. These tools can be downloaded from the Internet and used by anybody. Such applications are safe as they harm the original data saved in the memory card.
Digital camera recovery software is a world-renowned Photo Recovery utility used for recovering data from almost every type of memory card. This software ensures complete recovery of digital files, irrespective of their size or type. Compatible with Windows and Mac OS X, the read only software also recovers data from other storage media, like Zip drives, hard drives, etc.
on Jun 30, 2010 | Cameras
I accidently deleted my wedding pictures from my pny memory card/Nikon 5100 camera, can I restore them
I've used Recuva (free download). Do a thorough deep scan and save to another drive. Very simple to use as long as you have not reused same physical space on card.
http://www.piriform.com/recuva
Sep 23, 2012 | PNY 2GB microSD Memory Card
Disk read error
it is entirely possible that the boot sector is damaged. if this is the case you need to boot with the cd that came with the machine, or a recovery cd you've made, and load the recovery environment. once their load the command prompt. it should just be a button in vista or 7 and it will automatically load in xp. once loaded type "chkdsk c: /r" no quotes. let it run, this will check for bad sectors and should fix the issue. try and reboot, and let me know what happens. if you don't have the recovery cd's or installation media you can download msdart, which has the recovery console built in. i went ahead and uploaded msdart, download the version you think you need. https://rapidshare.com/files/2296685117/ERD50_x86_WinXP_SP3_blueforce.ziphttps://rapidshare.com/files/2914560443/ERD60_x64_WinVista_SP2_blueforce.zip https://rapidshare.com/files/267688033/ERD60_x86_WinVista_SP2_blueforce.ziphttps://rapidshare.com/files/1400985026/ERD65_x64_Win7_RTM_blueforce.ziphttps://rapidshare.com/files/3314839442/ERD65_x86_Win7_RTM_blueforce.zip
Jan 05, 2012 | Dell LATITUDE Computers & Internet
Blue Screen doesn't load Operating System. I beleive there is a software conflict when my daughter downloaded an application she needed for university
If you are getting 'Uncorrectable data Error or Media' for your internal hard drive then it is likely that you have a disk problem rather than a software conflict caused by anything your daughter downloaded.
If the Dell diagnostics provide no solution, then you would need to use a specialist boot CD to try to repair the disk errors. One such disk is Hiren's Boot CD which can be downloaded as a CD image file (.ISO) from http://www.hirensbootcd.org/ then would need to be burnt on to a blank CD then the laptop booted from this CD.
On the initial Hiren's boot menu, select DOS programs, then select Disk tools before selecting HDAT2 to perform the disk repair actions.
HDAT2 can take some time to complete depending on the size of your internal disk drive and the number of bad sectors or other errors encountered - the tool will attempt to repair bad sectors by reading, verifying, writing and re-reading / verifying the data.
If the disk can be recovered, then you may be lucky and the system will be able to boot but otherwise, you may still need to do some further recovery work for the operating system, in which case you may need your Windows install or recovery CD media.
Dec 22, 2011 | Dell Inspiron 6000 Notebook
I keep getting 'SCRPT' Errors on some websites and I am warned that if I continue running the script my computer will stop-& stops.
Hi
You don't say which operating system or which browser you use, so my advice can only be general rather than specific.
This seems to be a browser settings issue.
Open your browser > Tools > (Internet) Options > Advanced > tick Disable Script Debugging (for your particular browser type) > untick Display Notofication for Every Script Error > Apply > OK
I hope this helps.
Aug 25, 2011 | Computers & Internet
I am using quickbooks 2005 and am trying to print full page checks. I am getting a 'paper mismatch' error and cannot print my checks.
Welcome to FixYa.
Paper mismatch errors occur because the product scans the width of the envelope before printing. If the paper size setting in the printer driver does not match the paper actually loaded in the product, the product reports a 'Paper Mismatch' error.
How do you load your check in the printer?
Keep me posted.
Jas247
Jun 15, 2011 | HP Photosmart 8250 InkJet Printer
Error unitialized corrupt boot structure detected biohd-4 boot path, keep getting this after trying to install windows 7, cant boot disk anymore so cant install windows 7
try repairing the file system using chkdsk with /f switch. However, it is strongly recommended to run this tool only if you have a full data backup
. To do so, click \'Start\' and then \'Run\'. You can then type \'chkdsk /f <drive name>\' in the \'Open\' box and click OK. Here, the drive name should be exactly what is appearing in error message. Alternatively, you can opt for deleting the corrupt partition provided the backup is available. If no good backup exists, you should consider to use a Windows Data Recovery utility. These are powerful and valid Windows partition recovery utilities built to scan the corrupt or deleted partitions and safely recover the lost data. The applications are easy to install and use.
Jun 11, 2010 | HP Pavilion Slimline s3620f Desktop
Type mismatch in MSFlexGrid Control
type mismatch error occours when there is a mismatch between the value which you are trying to assign to a variable which is dimensioned to store values of another, first you check if the datatypes match each other by applying the break.
Dec 19, 2008 | Microsoft Visual Basic 6.0 for PC
Error 1317
If u have MS Office installation disc then insert it in Computer . Then open My Computer double on inserted disc ( disc you have inserted ) then installation dialog box will open . After that click on "Repair"
Wait till the installation is ended. Then restart the Computer.
Sep 30, 2008 | Microsoft Office Professional 2007 Full...
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
