Question about Music
I have a Yamaha Dtxpress IV and the headphone jack, doesn't play in stereo anymore. I have tried different cords and still it doesn't play out in stereo. Can this be fixed ?
  • 17 Answers
SOURCE: i want to connect my YAMAHA DTXPRESS IV SPECIAL to my PC
Any pro-audio interface with a midi input would do the trick. There are numerous products out there that offer this. You can get a simple usb midi interface, and connect the Yamaha up with a midi cable running from the midi out of the drum module to the nidi in of the interface.
one of the simpler ones:...
http://www.amazon.com/M-Audio-Midisport-Uno-MIDI-Interface/dp/B00007JRBM
Posted on Mar 04, 2009
  • 1138 Answers
SOURCE: sampling into yamaha dtxpress iv
If you have a sampler, you could midi out of the DTX brain into the midi in of the sampler to trigger the sounds. If not ,try downloading KORE2 from Native Instruments onto your computer and triggering it using the above mentioned method . Midi out from your brain to Midi in on your computer. Hope this helps.
Posted on Jan 18, 2010
  • 5603 Answers
SOURCE: yamaha dtxpress humming low sound in headphones
Likely a filter capacitor in power supply is failing if it has started doing this. SOMETIMES devices have a very small amount of hum normally. Also sometimes unbalanced instrument cables can pick up hum.
Posted on Feb 12, 2010
  • 5603 Answers
SOURCE: Put wrong power adapter into a Yamaha DTXPRESS IV
You should immediately quarantine what you plugged in and compare it to the correct one.
IF you put too low aq voltage of the CORRECT polarity nothing should have happened.
If you put backwards polarity of any voltage the regulator is probably fried internally and possibly an input bypass cap. Also if you put an AC adapter and it wants a DC the same destruction could happen.
if you put too high a voltage, possibly the power input cap may be bad.
It appears that the correct supply is the PA3C which is a 12 volt, 700ma with positive on the center pin.
Posted on Mar 30, 2010
  • 5603 Answers
SOURCE: In some pictures for the Yamaha DTXpress IV
I see pictures that show an extra device beneath the Hi-Hat and the ads mention a "stereo hi-hat controller"... on the RHH130 there is a clutch to improve the feel of the Hi Hat... I think this is what you see in some ads.
Cut and paste:
This hi-hat pad design attaches to a standard hi-hat stand. Inside of the pad is a sensor system and built-in hi-hat clutch that feels,realistic when pressed. The RHH130 also features a dual zone design consisting of pad and edge sections that offer greater dynamic realism. The pad can also produce a foot splash.
Posted on Jul 23, 2010
My DTXPRESS 4 was dropped on the ground . Not too hard but none the less dropped. now the kick wont trigger from the drum brain. Where can i get it fixed ?
This depends if the cables were plugged in or not...If they were, probably the jack for the defective input has had the solder to the board broken OR the cable has been damaged. Move the kick to a tom inout and see if the trigger works... If it does, then the Kick inout connector is probably broken away from the solder. Unit will have to be opened for inspection to find the defect. If the kick doesn't work at all in the other position, the cable from the kick MAY have been stretched or brolen.
Aug 15, 2011 | Yamaha Dtxpress Iv Special Electronic Drum...
WHEN I STRIKE THE BASS DRUM, THE CRASH CYMBAL SOUNDS AT THE SAME TIME....EVEN WHEN NO CYMBAL IS CONNECTED TO THE INPUT JACK.
If you leave an input open they MAY cross couple... try plugging a set of headphones into the cymbal input jack... this will ground the cymbal input... then see if you still get the cymbal sound... IF you STILL get the sound, then the multiplexor that scans the input has a problem and you need to take it for repair. Repair on the surface mount boards is not a DIY without proper tools and skills. If the grounding stops the cross coupling, then you MAY have a problem with the cymbal or its cable.
Feb 15, 2011 | Yamaha Dtxpress Iv Special Electronic Drum...
Sampling into yamaha dtxpress iv
Jan 13, 2010 | Yamaha Dtxpress Iv Special Electronic Drum...
Midi Output
If you only have a stereo output from the DT you need to record audio to a sequencer track so you can remix it better.
Dec 10, 2009 | Yamaha Dtxpress Iv Special Electronic Drum...
Bought a used dtxpress set pre-pogrammed.
The info is on pg.35 of the drum owners manual at http://www.dtxperience.com/dox/dtxp4_en_om_b0.pdf. Hope this helps.
May 11, 2009 | Yamaha Dtxpress Iv Special Electronic Drum...
I want to connect my YAMAHA DTXPRESS IV SPECIAL to my PC
Jan 24, 2009 | Yamaha Dtxpress Iv Special Electronic Drum...
Music Logo
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
