Question about ION Audio iTTUSB Turntable
How do i get my ez vinyl tape converter to record stereo
I downloaded an update for my EZ vinyl tape converter and it seemed successful but when I try to record I still get the message that it is set to record in mono
SOURCE: help
Hi if you click on control panel, click on hardware+sound,then click on the recording tab find it will show up as microphone USB Codec click on it, click the properties button,click on advanced tab,
in the default format make sure that " 2 channel,16-bit,44100Hz (cd quality)" is selected, the incorrect default is for 1 channel.
Hope this is of some use to you.
Regards leo21682
Posted on Dec 29, 2008
smarthome2
  • 1114 Answers
SOURCE: Continuous humming Noise in record mode
3 things to check: First, do you have the turntable grounded to the Stereo receiver, if not, make sure you do. Second, what kind of Audio cable interconnects the two pieces of electronics? Should be a very good balanced cable like Monster ILN or Phoenix Gold, or ProFlex. That alone can cause major noise. Third, Are you using a good power/line conditioning surge? Panamax, Furman,Monster all make very good line conditioning surge units. You've got an AC humm, it can be caused by just about anything in your home from a bad light bulb to a loose common wire in any AC outlet. LP's will amplify any kind of noise that's not heard on other devices. Chances are if you tune your receiver to AM you will hear it as well. Hope this helps.
Posted on May 24, 2009
  • 13 Answers
SOURCE: I would like to transfer music from a cassette to
Even simpler than that program is Audacity. You can download it free. The easiest way to accomplish what you want to do is this. Go to WalMart and buy a double male ended headphone cord for about $5 Plug one end into the headphone jack on the tape deck, plug the other end into your microphone jack on your computer. Be sure to turn down the volume to about 10% on the tape deck. This will keep the sound from becoming destorted. Press record on Audacity and start the tape. You can see it record as it plays. Then save that Sound file as the name of the song.
Posted on Oct 22, 2009
  • 19 Answers
SOURCE: ez vinyl converter used to convert to itunes
reload your software Itunes went to 9 and it needs to be updated.
Posted on Dec 24, 2009
SOURCE: The EZ Vinyl/Tape Converter software seems to have
It is probably too late to help you, but others might have this problem and we solved the issue by disabling and enabling.
Click on windows button (bottom left hand corner), control panel - sound - Playback tab
You will find that there are a number of different speaker setups in that area. One set will have the light meter moving, but there won't be sound from your speakers. This is because the modern computer is much more like an amp and has the ability to have different speaker combinations and settings. You only use one speaker set-up.
- double click on a speaker option, advanced tab, and test. If there is no sound, then your speakers aren't connected to that port. Move to the next one.
- Once you find the correct speaker setup for your system, then disable the previous setup and ensure this one is enabled. Once the meter bar lights up for the right speaker combo, all sound will work as expected on your computer.
The modern computer is much like a stereo amp now, and you have to tell it which set to use. (For some reason it works well enough, until you start adding stereo components onto your system.)
Posted on Dec 26, 2010
Product: Ion Tape Express - Tape-To-Mp3 Converter/Player (with EZ Tape Converter software) Problem: I'm able to record my tape tracks as mp3's on the computer, but the sound is always in mono...
In all likelihood, you issue is in your recording software settings. If check the help files included with the program (hit the F1 key to pull these up) and search for stereo, I bet you find a setting on the software is set to mono.
The second spot to look is in Control panel> Sounds and Audio devices> Audio tab. Click Advanced... under Sound Recording. See what control options are available to you since they differ from one audio app to another. This should bring up the setting for your audio input, look for a setting that says stereo or mono.
Hope this is helpful to you.
Jul 27, 2011 | Computers & Internet
I have an EZ Grabber Item No: A07JR. Trying to get VHS film played on a Sharp VC-MH815 6xHead/Nicam/Hi-Fi Stereo Player Recorder. Useing video composite from the player to USB attached to a Toshiba...
This is a solution, probably resolve your problems as well, for converting VHS to DVD, its a tip I posted some time ago, might help you out:-
There appears to be quite a few problems with people trying to convert their video tapes to DVD using a PC and propriety converters, editing programmes etc.
Friends have also has such issues, lip synch being one of the most prolific.
I've successfully converted mine, without too much issue and managed to avoid these issues.
I hook up my VHS recorder with a DVD recorder2_bing.gif which also has a HDD. Daisy chaining it on to a TV to monitor. All with scart leads.
Play the tape, record to the DVD hard drive. Finally edit and dub to DVD.
Have fun ..............
Nov 25, 2010 | Cameras
I am having a problem recording more than 1 track on my new ION tape express cassette conversion system. I was instructed by ION to uninstall the previous ez vinyl converter software and re-install the new...
I have the same problem and do not know the answer. Was searching here for an answer to my problem. Only a small part, 4 tracks in fact, about 5 minutes from a 30 minutes tape are imported to Itunes. where is the solution because it seemed the computer was recording the whole tape without problem. Where is the data gone. Can someone explain. Nico
Jan 12, 2010 | ION Audio TAPE2PC Single Cassette Deck
The EZ Vinyl/Tape Converter software seems to have caused a conflict in the audio codec. I can hear the music on vinyl as it records, but now I can't hear iTunes or web sounds. All my settings for volume...
Jan 01, 2010 | ION Audio iTTUSB Turntable
I would like to transfer music from a cassette to my laptop. How do I do this using EZ Vinyl/Tape converter? Thanks
Oct 21, 2009 | ION Audio Vinyl Recording Turntable
EZ Audio Converter does not export files to iTunes
I've had exactly the same problem, and so far no resolution from Ion. A small bit of good news: the .wav files are on the hard drive, although without any track info. At least on Vista, they are in username/AppData/Local/Temp. The files are name Temp0, Temp1, Temp 2, ...
You can use iTunes to add these files (File/add file) and then convert them to .mp3s, or whatever format you prefer. Or you could convert them first using the tool of your choice, such as Audiograbber.
This is inconvenient, but a lot better than re-ripping the vinyl after EZVinyl hangs.
Jul 25, 2009 | Numark PT01 Turntable
No sound from iTunes audio files
it sounds like EZ A C did not get the audio or EZ put it in a format tha Itunes Cant play. download VLC media player and install it. open the file with VLC and se if it will play it. It will play just about anything it has most of the codex's need to play anything too. if it doesent play it then something is wrong with the input to EZ A C you might have the input muted.
Jun 23, 2009 | Audio Players & Recorders
Need drivers for my ION Audio USB Turntable
Hello
USB audio turntable can be found on this site: Driver Update. have a nice day
Jun 22, 2009 | ION Audio iTTUSB Turntable
EZ Vinyl Converter produces file that doesn't work
Try
Control panel
-Sounds - click on Speech and Audio Devices -
Click onSounds and Audio Devices. or if your in classic view -double click.
Click on Audio tab
Make sure that thedefault devicefor Sound Playback is set to the device hooked up to the speakers
i.e. set it to something other than the USB AUDIO CODEC which is the turntable
Jan 12, 2009 | Televison & Video
Numark turntable records record AND sounds in the room
the mic is in the computer somewhere, there will be a way to mute the microphone either in the vinyl software or in the system settings of the computer!
Jan 10, 2009 | Numark ttUSB Turntable
ION Audio iTTUSB Turntable Logo
78 people viewed this question
Top ION Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Joseph Hoffmann
Are you an ION Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
