Hhb cdr 800 It won't record. It keeps saying set up,then it says check disc. I'm using the same cdr,s that I always use,nothing new,this problem just started.
2 Suggested Answers
  • 112 Answers
SOURCE: about the HHB CDR 850 compact disc Recorder
You may need a new laser - it's a sony unit inside.
Posted on Dec 09, 2007
Disc types that have worked for recording in the past are getting a "Not Audio" error upon reading. Specifically HHB CDR80's.
hi, i would try not using cdr discs. alot of older decks had issues reading "r"discs try cd'made for music not data. that should fix u up.
Apr 19, 2016 | Yamaha Natural Sound Cd Recorder Cdr S1000...
Hi there, when recording analogue from mixer to HHB Burner 830 the blank cd does not read properly, and records blank even thou the connections are in the right ins and out (phono to phono) And the input...
I can only assume that it's not changing the analogue signal into a format suitable for transferring to a CD. Check the recording settings. Make certain the signal is being converted to say a WAV format or MP3 etc.
May 01, 2017 | HHB BurnIt CDR830 CD Recorder
AFTER recording is made Tried to finalize and it says repair... what is causing this .
The CDR lost track of the information on the disc. This most often happens when the unit is powered off before the disc was ejected. Give the unit about 40 minutes to go through the disc contents and locate the tracks. When the Repair message goes away, then you can finalize the disc.
I hope this helps
Sep 24, 2010 | HHB BurnIt CDR830 CD Recorder
Cd not recording
Be sure to "finalize" the recorded cd before use in another cd player. Another thing is there are always a few bad discs in a spindle of blank discs... And sometimes you will get "check disc" or "bad disc" when a blank disc is inserted. I would be sure to use blank discs for audio use, not computer use, with your Yamaha.
Apr 14, 2010 | Yamaha CDR-D651 2-Disc CD Recorder
Can't finalize after recording, disc error
So are they always CD-RW?
I have a Pioneer PD509 which is a spittin' image of the HHB CDR830 but tied down to use CD-Audio discs only.
My experiece with Rewriteable Media has been that they don't hold up to multiple uses. I used them to make quick 'n' dirty dubs of cassette audio then worked it into a polished copy with proper track marks and sweetening later for copy over to a CD-RA. After a few passes I'd start getting audible problems when copying off the -RW's, so I routinely just use them about 5 times. With two DVD players and a Blu-Ray I sometimes get through the errors on one of them for one final digital copy and then I can them.
BTW: you may want to try the failing disc in a DVD player. Mine will play through an unfinalized CD but can't cue up to anything. So if the recording is vital you might retrieve it that way. Just remember to pause the Recorder at the end of the last cut you want because the DVD will just crash right into the old data without changing track numbers or any warning.
Mar 04, 2010 | HHB BurnIt CDR830 CD Recorder
Anytime I try to record with my HHD BurnIT cdr 830, the red record light will only be bleeping and the time counter will not work as well. And there will be nothing recorded on the cd.
Just a guess, but did you ever try to hit the record a second time once you're all set up to start? The first press of the record button places the machine in record/pause mode after it calibrates itself to the disc.
Jan 19, 2010 | HHB BurnIt CDR830 CD Recorder
HHB burn it...I record on coaxial from Tascam DAT. 1st five tracks are great but the 6th track sounds horrible like there is a scratchy sounding distorted delay. It does this every once in the while . What...
I had this happen a lot on my Pioneer PDR-509, which is pretty much the same machine, when using marginal mongrel-brand CDR's. It's annoying but I have seen nothing to explain or detect it in real time so something can be re-recorded.
Nov 17, 2009 | HHB BurnIt CDR830 CD Recorder
Denon CDR-W1500 not recording
I had the exact problem and could not get any of the CR-Rs that I had to work. I looked up the code in the user's manual where it said the error means it's not a recordable audio CD and to refer to page 6. I looked at the front of the manual and saw that it mentions that the CD-Rs must be audio CD-R discs. I did some research online and found that there are in fact differences between CD-Rs that are just marked that and those marked as Audio or Music CD-Rs. I bought a set of CD-Rs that clearly had marked "Compact Disc Digital Audio Recordable" on the package. When I inserted this disc, I had no problems getting the recording to work. So, make sure the discs you use are clearly marked "Audio" or "Music". A computer burner won't know the difference, but your Denon recorder will.
Jan 27, 2009 | Denon CDR-W1500 2-Disc CD Recorder
My CD Recorder is not reading my blank discs. What can be the pro
hi not sure if this helps but some disc ,s ive used on my 500s won,t work either so i changed the type of disc and it seems to do the trick i think some disc,s just aren,t good enough ie cheap ones .
Jan 13, 2009 | Philips CDR600 CD Recorder
About the HHB CDR 850 compact disc Recorder
Aug 14, 2007 | HHB CDR850 CD Recorder
 Grubhead
Grubhead
