Question about Hampton Bay 24002 Ceiling Fan
Hampton bay vendome 232809 bearing noise
Sounds like a bad bearing. any way to service the fan
Buffalo12980
  • 625 Answers
SOURCE: I need the default code for a hampton bay fan
I checked the hampton bay site and unfortunately whatever dip switch setting on the fan is, the remote needs to be matched to it. better get out the ladder!
Posted on Sep 12, 2007
ceiling-fans
  • 20 Answers
SOURCE: hampton bay fan noise
The fan does not need to be oiled. The bearings are what manufacturers described as "permanently-sealed", which means that they're designed such that they don't require oiling. The manufacturers recommend against oiling, and if you really wanted to do it, you'd have to be an expert, because there is some very complex disassembly to be done, which requires specialized tools.
HOWEVER...
The problem is not related to oil. A lack of oil does not produce a hum. If a fan's bearings are low on oil, the sound generated is a scraping or brushing sound. A hum, on the other hand, is an electrical sound. All fan motors hum to some degree -- the cheap made-in-China ones, like in your Hampton Bay fan, hum more than others. There are some steps you can take to reduce the hum:
* If you are using the fan with a solid-state control (i.e. a dimmer), that will cause the fan to hum. These controls are dangerous when used with fans, and a fire can result. You should have a qualified person remove the switch immediately and replace it with either a regular on/off switch OR a discrete-speed (i.e. 3-speed or 4-speed, rather than variable-dimmer) switch. Specially-designed ceiling fan switches such as this are available at your local Home Depot or Lowes. You could also use a remote-control system.
* If you have a remote control or other speed control system, make sure that the pull-chain speed control on the fan is set to the "high" position (highest speed possible) and left there.
* Make sure that all the screws are tight -- this includes screws which hold up the fan's mounting bracket, hold the blades onto the fan, and hold any applicable glass onto the light kit.
* Even if you don't have a speed control, the motor will still produce an electrical hum -- and the blades, which are physically attached to the motor, serve as mechanical amplifiers -- they take the tiny electrical hum and amplify it just like the big brass funnel speaker on an antique gramophone (record player) takes the tiny vibrations of the needle on the record and amplifies them to a comfortably audible level. High-end fans have a rubber flywheel attached to the motor between the blade holders and the motor unit -- and since rubber doesn't transmit vibrations well, this effectively deadens the sound. Your fan doesn't have one of these, but you can effectively replicate the noise-dampening effect by putting rubber washers between where the blade holders touch the bottom of the motor AND between where the screws which hold the blade holders onto the motor, meet the blade holders themselves. This will completely remove the path along which the sound vibrations can flow to the blades, and thus your hum will stop.
I hope this helps you! If you have any other questions, or need clarification, please ask!
Posted on Jun 17, 2008
SOURCE: Hampton Bay Remote
Hampton Bay Almeida 52" Ceiling Fan 52101916 ... Had fan installed remote fan would not go on ... nothing not even light ... changed batteries electrician that installed it said take it back to the store he would install another fan .. just bought fan last year HELP
Posted on Aug 04, 2008
  • 26 Answers
SOURCE: Hampton Bay 52 In. Clarington. How do I reverse the fan?
Try these two: 1) look for a small switch up near the light area on the dark-colored area of the fan. If a switch is there, then simply flip the switch to the other position; 2) if you have a remote control for the fan, the reverse mode may appear on the remote control. Hope this helps.
Posted on May 19, 2009
  • 323 Answers
SOURCE: hampton bay fan makes squeeking noise
If the fan is fairly new, remove it and return it to Home Depot. It is almost certainly something that has fallen down into the motor and is rubbing loudly enough to make a squeak as the fan runs faster.
The fan itself has sealed lubrication and you don't have to lubricate it.
Posted on May 26, 2009
My Hampton Bay ceiling fan has been making a sound - like a clicking noise - during every revolution of the fan, and at each of the 3 different speeds ever since it was installed.
Try a bit of chewing gum on each of the blades separately, it seems to be out of balance.By trying each individually and turning on each time you should find the imbalance.Cheers Michael....Australia
Jul 21, 2017 | Hampton Bay Dryers
How to get details about hampton bay fans?
do an online search of company or specific model ---notify hampton bays customer service
Hampton Bay Customer Support
Jun 06, 2017 | Hampton Bay Dryers
The pull chain for our Hampton Bay Sibley 52" Ceiling fan quit working so we think we need a new light kit???
You just need the switch by the sounds of it.
Hampton Bay Customer Support -Troubleshooting & FAQ ' The Home ...
www.homedepot.com/c/SPC_BRD_HamptonBay_Help
  1. Cached
  2. Similar
Find Hampton Bay customer support, replacement parts, warranty information, troubleshooting and ... Ceiling Fans Patio Furniture Lighting Bath Fans Fireplace
Hampton Bay - Ceiling Fan Parts - Ceiling Fans & Accessories - The ...
www.homedepot.com > ... > Ceiling Fans & Accessories > Ceiling Fan Parts
  1. Cached
Shop our selection of Hampton Bay, Ceiling Fan Parts in the Lighting & Ceiling ... Hampton Bay 3-Light Universal Ceiling Fan Light Kit with Shatter Resistant Bowl .... Fan Light is an ideal choice for replacing worn or outdated fan light fixtures.
Hampton Bay Lighting Parts and Accessories ' eBay
www.ebay.com > ... > Hampton Bay Lighting Parts and Accessories
  1. Cached
  2. Similar
Replaces Hampton Bay and many other similar ceiling fan remote controls. Common replacement for model number UC7078T or FAN-HD with a reverse button.
Hampton Bay Replacement Parts
hamptonlightingadvice.com/hampton-bay-replacement-parts/
  1. Cached
If you have a Hampton Bay product such as a lighting fixture or patio furniture or maybe even some solar lights or ceiling fans then you may need to find a ...
Hampton bay fan and lighting company website store
hamptonbayfanandlighting.net/
  1. Cached
Hampton bay fan and lighting online store. Menu. Skip to content. Hampton bay moved to new ... Hampton bay moved to new website >>>> hampton bay ...
Hampton Bay Ceiling Fan Parts
www.ceilingfansbay.com/hampton-bay-ceiling-fan-parts/
  1. Cached
Do you need help to find a Hampton Bay Ceiling Fan Part? ... known and reputable manufacturer of ceiling fans, bath fans, light fixtures, patio furniture, chandeliers and more. ... Easy Way to Finding the correct Hampton Bay replacement part:.
Hampton Bay Ceiling Fans & Lighting
  1. Cached
If you need a Hampton Bay replacement part, we can help you with that. Here are the most common Hampton Bay replacement parts that people search for, and ...
Lighting Replacement Parts For Your Ceiling Fan
www.ceilingfanreplacementparts.com/hampton_bay_lighting_replacement_parts.html
  1. Cached
  2. Similar
Hampton Bay lighting replacement parts are readily available to let you maintain for many years the beauty and function of your ceiling fans, lamps, chandeliers, ...
Hampton Bay Google Search
Nov 21, 2016 | Hampton Bay Dryers
My Hampton Bay Victoria 70 in. French Beige Ceiling Fan has started to sway and make funny noise anything above a level 3
swaying fans are a symptom of out of balance. The blades have to be all at the same height to the ceiling or from the floor . It it was ok before but just started this when the noise started then it may be failing bearing in the fan.
with most fans that means a new one but take it to an appliance shop as it may be repairable.
bearings will be from a bearing supply shop
Apr 01, 2015 | Hampton Bay Dryers
We bought a Hampton Bay fan model ALTURA 56 inchs. Since a year we have a noise came from the motor. Wath is the best way to fix this situation.Thank you!! Guy
If you are using a dimmer switch get rid of it and get a FAN control. Also, you can check the capacitor to see if it's going bad. Hampton Bay is just a low-end store brand for Home depot. You get what you pay for.
Mar 30, 2015 | Hampton Bay Dryers
Why is my hampton bay fan making a constant chirping sound even when off
Never heard of a chirping noise in a fan. Did you check the inside of the housing for a bird? That's just a low-end store brand for Home Depot. Take it back!
Feb 10, 2015 | Hampton Bay Dryers
Does this model fan require oil -- just noticed a little noise coming from the fan - sounds like it needs lubrication!!
Most household fans come with prelubed Bearings that are supposedly lifetime bearings, but a lot of times even these fail.
If you can disassemble this fan you might attempt it, but more than likely you will spend more time than the Fan itself is worth.
The other thing to check is to make sure that the fan Body is not rubbing against the Props anywhere.
Jan 10, 2011 | Hampton Bay 52 In. Cameron II Plus Ceiling...
Hampton Bay fan has a grinding noise
I have worked on many fans because this fan is ten years old. I want to say that this fan has ball bearings in it. Have you tryed WD-40? If so did it work? Are you able to look inside, through the top of the fan to see if some thing is in its way?
Nov 04, 2009 | Dryers
Hampton Bay fan bearing noise
its not the bearings sounds like you need to level the mount and that scraping it the fan blade mounting plate hitting the side of the 'case' that surrounds the motor assembly ive never heard of bearings in the motor going or needing lubrication other than what factory placed in them...remember Hampton Bay is the Yugo of electric appliances too
Aug 03, 2009 | Hampton Bay 24002 Ceiling Fan
Hampton bay fan makes squeeking noise
Apr 07, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Hampton Bay 24002 Ceiling Fan Logo
47 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
