Question about Ovens
Hi my Leisure Cuisine Master 100 fan oven isn't working - it heats up for a bit, but the fan doesn't come on and then the orange temp light goes out as if it's up to temperature even though it's only been on for a few minutes.
  • 833 Answers
SOURCE: SMEG CC92MFX5 STAINLESS STEEL SIDE BY SIDE OVEN
Two things sharyn, first check the breakers. It is possible that one of two that control the stove tripped...they are in tandem. Shut them off and back on. If no fix: You'll have to remove and test the element. (if more than one element is involved here...it might be the thermostat) Breakers off, pull the element out and have someone take an ohm meter and test the unit. Still no good? Then it will be the thermostat or relay. Let me know what you find.
Posted on Dec 07, 2007
SOURCE: aeg competence b 8139-4-m - oven not heating up
your heating element is probably bad. all u have to do is, make sure the oven is off, pull elem. away from it's holders on the top or bottom of the oven, then pull the elem. loose from it's sockets then, straight out of the oven. take to home depot, or lowe's, or an used appliance store. installation is reverseal.
from sid
Posted on Apr 20, 2008
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    SOURCE: my oven turns off on me after only a minute never heating up fully
    Could be caused by either of following;
    1. Faulty thermostat.
    2. Faulty thermal cut out switch. (controls power to cooling fan).
    3. Faulty cooling fan (not fan inside oven).
    Test thermostat by setting thermostat to low temperature like 60 oC. If oven gets much hotter then its a faulty thermostat.
    To test cooling fan and thermal switch take oven out and remove top or rear panels to expose components.
    When oven gets hot the cooling fan should turn on. If it doesn't then check to see if there is a mains voltage present.
    If mains current exist but fan is not turning then replace fan. If mains voltage is not present then its the thermal switch.
    Posted on Sep 17, 2009
    barkencoa
    • 3463 Answers
    SOURCE: CANDY OVEN
    It will be the oven element that has failed, you need to fit a new one.
    It is located at the rear of the oven compartment.
    Posted on Feb 22, 2010
    Testimonial: "GR8 JOB HAVE ALREADY SEARCHED ON THE NET BUT THIS CONFIRMS. NICE ONE CHEERS."
    My leisure GRB6CVK electric oven(main oven) has stop heating up. Fan and light works but no heat. Help pls. Any thoughts. Sheryl
    Unplug stove and take wires off element. test for continuity on the poles. Also check wire ends.
    May 24, 2014 | Ovens
    My oven doesn't heat up
    It could be the switch or heating element
    Mar 17, 2013 | Thermador SM272 Electric Double Oven
    I just moved into a house with a Gaggenau EB 846-6. Light and fan work. Heating element doesn't seem to work in top or bottom 'socket'. Also, neither heating indicator light illuminates
    since neither light is going on, then i believe that you either have a bad thermostat, or possibly that you only have half of the voltage going to it, and gaggenau doesn't have gas units so it doesn't have a glow bar like the previous guy said.
    Jul 21, 2012 | Ovens
    What kw is my leisure cuisine master 100
    If this is the RCM10CR model with electric hob and oven than it has a maximum rating of 13.8Kw (Page 6 of the manual, a pdf of which can be found here: http://www.leisurecp.co.uk/upl/31115-RCM10CR.pdf )
    If it is the dual fuel RCM10FR then it has a maximum rating of 7.7Kw (page 6 of the manual, a PDF of which can be found here: http://www.leisurecp.co.uk/upl/55403-RCM10FR.pdf )
    Jul 28, 2011 | Ovens
    Oven won't heat up, you can see a little orange light glowing and it heated a little bit, but now the light does not come on at all. Also, not sure this is a double oven, but it does have the broiler...
    The ignitor is not working right and is going bad....
    have the repair man replace the ignitor, or DIY....
    Check out this tip about your problem...
    Oven not Working or Oven not Heating
    Oven Problems Replacing the Igniter
    heatman101
    Jun 15, 2011 | Magic Chef 9112 Gas Double Oven
    Main oven light works fan runs but oven doesn' get warm
    ROSIERES Oven not heating? How to replace a ROSIERES fan oven element
    This video will show you how to replace fan oven element in your
    Please remember to subscribe to our YouTube channel for all appliance tutorials
    a 4 THUMBS rating is appreciated for answering your FREE question. You searched for ROSIERES element How to Repair Home Appliances
    May 23, 2010 | AEG U3100-4 Electric Double Oven
    Leisure levc66x - bang from fan oven blew tripswitch - fan operating but no heat - top oven ok - 18 month old unit
    It appears that the ring element for the oven has burnt out and will need replacing.
    Hope this helped.
    May 13, 2010 | Ovens
    Ovens Logo
    26 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
