Question about Creek 5350SE Amplifier
Creek left channel static
3 Suggested Answers
SOURCE: Creek 5350SE amplifer left Channel dead
It's the ribbon cable that is likely at fault. There are actually three computer type ribbon cables in the amp. I believe the cable that is responsible for the drop-out of a channel is the widest (longest) of the three, but you really need a tech to look at it and replace the cable. But please note that the new cable may also have defects in manufacture and that it may take some time to order a new cable from Creek. I had a tech solve the problem permanently by removing all three ribbon cables and then hard-wiring the connections together - that is to say, point-to-point wiring. My cost was about $250, but as you can imagine, there is extensive labor involved. Good luck!
Posted on Aug 13, 2009
Grubhead
  • 5342 Answers
SOURCE: Creek SE 5350 one channel without sound
I think you will find that the fault is either a dry joint somewhere (have you moved it recently?) OR more likely a transistor. It might be caused by one getting very hot! Thus shutting down and coming back on when cool.
The best way to track this troublemaker down is to spary each transistor (in the left channel only don't bother with the other or Power section) with Servisol Freezer spray. Wait for the thing to play up then spray -one at a time- if it pops on you have got the bugger! To make certain apply a soldering to it and it should act up again. Spray again to confirm.
Posted on Apr 12, 2010
Str-gx800es sony receiver problem- right channel speaker sound is 'static', low and distorted. I have checked checked all speaker and output/input source cable connections with no luck. All left channel...
If you have checked the speakers and wiring, the right channel has a audio driver or output problem, which explains the low volume, static, and distortion. A service technician will be required to fix the receiver so it will balance the left side.
Jan 10, 2011 | Sony STR-GX800ES Receiver
Apr 11, 2010 | Creek Destiny integrated Amplifier
Left channel goes on and off.
Well, if messing with the RCA cables affects the problem what does that suggest? Have you tried swapping the Left with the Right to see if it follows the cable or stays with the component?
Feb 23, 2010 | Creek 5350SE Amplifier
Jul 12, 2009 | Creek 5350SE Amplifier
Behringer xenyx 802 static in left output
if its only on left channel you have to change the ic output from that channel.
Jul 08, 2009 | Audio Players & Recorders
Yamaha RX-V596 main rigth channel problem
The right or left (side) output channel has blown out. If it uses discrete transistors you'll have to replace two of them (one PNP and one NPN) along with several resistors that are part of the circuit (I'm guessing the static occurs on any input source).
Now , if the static happens only on certain input, then the problem should not be in your amp.
May 21, 2009 | Yamaha RX-V596 Receiver
Terrible static on left side of all channels
Hi...
Unplug all the inputs to the amp.
Does the problem go away?
If its only the left sometimes, it sounds like the speaker selector switch or source selector switch needs a good cleaning with some de-oxit and a small brush
Apr 27, 2009 | Audio Players & Recorders
Speaker problems
You've probably tried this, but when you do the channel test you can turn the volume up or down on whichever speaker is currently being tested (the static). Maybe your speakers have been adjusted somehow.
Jun 08, 2008 | RCA RT2300 System
Reciever get louder in one channel then static then goes back to normal
HAI,IT'S A SMALL PROBLEM ANY DRY SOLD INLEFT AUDIO SECTION
Apr 30, 2008 | Nakamichi AV-10 Receiver
Creek 4040 Amplifier blown some speakers ?
I would suggest not using the amp before the problem is sorted. It may damage your new speakers :)
  1. It is possible that your input selector switches may be Noisy. What happens when you operate them, does it exasperate the problem?
  2. Noisy control pots may also be contributing to the problem. taking the lid off and giving the pots and switches with decent squirt of contact cleaner lube (I use CRC2-26)
If you still have issues, is the problem there on both channels?
If it is then there may be a power regulator issue.Is there a DC offset on the left and right speaker output(check with a DVM).
You can find a schematic here.
I am happy to talk to you more about the problem. I would need to talk a bit further with you, just ask away in here.
regards
graeme
Feb 11, 2008 | Audio Players & Recorders
35 people viewed this question
Top Creek Audio Players & Recorders Experts
 Grubhead
Grubhead
Pieter Vleeshouwers
Pieter Vleeshouwers
ray gallant
Are you a Creek Audio Player and Recorder Expert? Answer questions, earn points and help others
