Question about Toys
420d cat backhoe won't move forward or backward
When i backed it into the shed, it worked fine. now the engine will start and run great but when i move the lever to go forward or backward nothing happens. i can hear a faint clicking noise when i shift it . i dont know if this is common ? the click is comming from a switch (relay?) under the right side instrument panel. i switched it with another one like it , bu it still dosn't work.
catriver
  • 878 Answers
SOURCE: Side by side stopped working but clicling noises every second two.
Read, this model posted has a main board in back that controls the refer. Your problem sounds like the overload and relay on the compressor but you need to do a test to verify. On the main board in back there is a blue harness, 3 pronged, that is marked line, defr and comp. Lower left hand corner. You need to get a jumper wire with alligator clips and with the plug out, jump line to comp. Now plug it back in, this will send 120V directly to the compressor. See if it starts. If not and it does it clicking thing, chances are it's the overload and relay, or the compressor itself. You have five years warranty on the compresser. If it starts, it's the board it's the board giving you the problem. This of course is for the GSH model posted...Catriver..post back.
Posted on Feb 11, 2007
the dr
  • 447 Answers
Ok the motherboard is malfunctioning. Ive observed this exact problem before. Replace the board and all will be normal again. If you keep lettig it click and click it may finally kill that relay that you descibed to me or even worse the compressor itself.
Posted on Dec 02, 2007
  • 15 Answers
SOURCE: Power door locks dont work
hello on the door locks not working could be a couple problems open the driver side door and were the door hinges are there is a small tube with wires in there that runs from the door into the side of the kick panel inside of the car these wires are your windowns locks and more now were the door open you will have to cut tube with a razr knife so you can see if any of the wires are broken now if there is no wires broken now the power door lock actuators inside the front right-and left door could be bad or the door look swiches this is not unlikey you can check this by removing the door panel you will see a rod or cable going from the door lock down the bottom of the door
now on the key not working that sounds like the door lock rods there that hooks to the lock on the inside of the door is off or one of the plastic clips that hold the rods has broken if it is not locking or unlocking your doors it is not unlikey for both sides to be broken you will have to remove the door panels to check
Posted on Mar 02, 2009
SOURCE: Power window problems on driver side
It sounds like there may be a short in the wires. Check the wiring inside the door jam. the wires should be within a rubberised sleeve, possibly a blue and tan coloured wire.
Marc from Barrie
Posted on May 05, 2009
SOURCE: Case 580C model 33 backhoe - transmission problems
Pregunta , tienes, el manual de la case 580 ck, donde se muestra el circuito hidrailico de la transmision, si es asi, embiame una foto del circuito o el manual y te puedo apoyar.
Posted on Jun 01, 2009
1972 jcb backhoe not moving backwards or forwards
Sorry no info on any model this old.
May 09, 2016 | Cars & Trucks
I drove my mower into my shed after the last use and now I cannot get it to move either forward or backward, even pushing it
Lift left hand foot pedal to full extent with top of foot may find that it is not engaging idle pulley, may be time for a new drive belt
May 30, 2015 | Craftsman YT 3000 42" Kohler 22 hp Gas...
Caterpilla backhoe 420D hour meter not working
Go to this link, search the forums for help with 420 cat hour meter. It is probably a simple fix even if you have to replace the unit. Join the forum for free, and ask your question in the tractor-backhoe forum. THANK any one who offers assistance and let the forum know what you finally did to fix the problem so WE CAN ALL benefit from your experience! There are many wise operators,owners, and mechanics on this site.
Mar 28, 2014 | Caterpillar Backhoe Tractor
Lawn boy self propelled mower won't move backwards
is it belt driven can you pull it back when it not running
Apr 11, 2013 | Garden
CAT 420D IT - lack of power- changed two fuel filters, one by injector pump and other between left front tire and fuel tank. Air filters cleaned, tractor serviced, Then used air to blow thru lines back...
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
This is for car and truck problems related to Factory Installed Systems not add on aftermarket systems.
This post can't be removed or moved, please re-post the question in the correct product category. Thanks
Nov 02, 2012 | Cars & Trucks
I have a Noma model signature 1340, 12.5 HP riding tractor. i am not sure of the age. last time we used it to cut grass, it worked great. we parked it in the shed. went to use again and it starts and runs...
Hi, Just got your request and am now going to look up all I can find on this model of tractor. In the mean time double check your push or drive lever again to make sure it is not binding and make sure the blades are not selected, although I am sure they are not but at this point I am not ruling anything out. I will have to dig into this issue and check on the trans axle set up for you.
Oct 22, 2011 | John Deere Garden
I have a John Deere RX 75 that worked perfectly fine. I just did maintenance by greasing some fittings and I sprayed WD-40 on some of the moving parts under the seat (throttle, levers, etc.). After I...
If it's a hydrostatic, most likey you pulled the manual over-ride (only way to move the tractor manually). By leaving the over-ride level in the disengaged position, the tractor will start & run, but not move forwards or backwards. Correct by closing the the lever to it's closed (operational) position.
Oct 18, 2011 | John Deere Garden
24 hp LA165 mower. While mowing the mower stopped moving. Engine runs, blades turning but won't move forward or backward (the side lock has been released and the pin at the back is pushed in) 11...
check the connecting rod to the tranny. follow the gear handle and you should find a rod connecting the handle to the axle make sure you're in neutral and adjust the rod until the handle starts to move
Jul 17, 2011 | John Deere 24HP VTwin Hydrostatic 48"...
Cat backhoe doesnt even go up a hill in forward, reverse is fine
http://www.heavyequipmentforums.com/showthread.php?t=19510
If you go to this site, and join, AFTER you make five posts, ie: comments on any topic anywhere on the site - five times (hit reply button on any post and comment) you can ask any questions concerning any equipment known to man or beast. It's free and a very good site with tons of great info and pictures.
May 29, 2010 | Caterpillar Backhoe Tractor
No starter engagment on cat 420d bachoe no power
From what I have discovered with my own Cat 426 it is likely the forward reverse selector. It has electronics and contacts that will NOT allow the starter to receive any power if the contacts are open as there are safety interlocks that will not allow the machine to start.
May 18, 2010 | Caterpillar Backhoe Tractor
Toys Logo
275 people viewed this question
Top Toys Experts
Tom Chichester
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
