Question about Bushnell Medalist Rangefinder
Does not register distance accuraely
Fell into pond, dried it out reads close ok but cannot read pin at distane accurately, can it be opened and cleaned or are electronics damaged?
3 Suggested Answers
  • 133 Answers
SOURCE: The unit I have has stopped giving me readings. When I look through the viewfinder, I see the pin but there are no distance readings. Depressing the button on top doesn't work.
Bushnell will honor the warranty if the unit doesn't look like its been dropped. The warranty on these units is two years. If everything is kosher....then sent it in. They will replace it with a new one. You can go to their website and get all the service center info. They will ask that you send in 10 bucks for return shipping.
mtg
Posted on Jun 02, 2009
  • 133 Answers
SOURCE: Bushnell yardage Pro won't read distances. Short
Bushnell has discontinued service on the yp500, yp400,yp800,yp800.yp1000. Basically all the units that look like this one. They will offer you a new unit at wholesale price.
call 800.423.3537 and ask them
mtg
Posted on Oct 08, 2009
JZ300 Autofocus not working
Beyond sand getting in, the lens may have been damaged from the impact if it fell on the lens while extended. It may need to be serviced by a technician.
Apr 13, 2014 | FUJIFILM FinePix JZ300 Digital Camera
Engine code 15
use a real scan tool ($9 ask), if in USA and is 1996 or newer.
plug it in and read all the codes.
No vehicle distance (speed) sensor signal detected during road load conditions.
this means the VSS is dead.
the veh, speed ,sensor.
is the speedometer dead too?
is the A/T shifting funny? (tranny)??
the fsm is here, you can read all about it .
emission control chapter,.
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
then
wiring
8w-30-12 (8w-80-38, 3 pin connector fell off tranny tail, or loose or pins corroded, or wires there mangled.)
VSS
chapter 21 tranny page 32 bam there it is.
Apr 08, 2014 | 1996 Jeep Grand Cherokee
Are laser distance meters really accurate?
They are accurate to a point, it can be very difficult to get an accurate distance reading because of terrain and if there are obstacles in the way like trees.
Jan 22, 2014 | Measuring Tools & Sensors
I purchased a new LR 559 Callaway golf rangefinder from a QVC auction. The problem with it is it isnt even close to accurate. I have a measured archery range back to 65 yards and the rangefinder is way off...
its a piece of ****, that happens when you arder through qvc. When you arder electronic devices for weights or measurements, first you must know exactly what you are looking at, make, model, and series,,, then read all of the reviews you can,, then go to a pro store-- (like our shop we are a pro archery shop) we refuse to work on peoples bows they bring in that they bought online, because half the time they recieved something that they did not order, they dont look like they did in the picture that the seller posted... always read reviews and ask the professionals.... I would return the item even if it was an auction, if you cant return it then ebay it-- but be honest when you post descriptions of the item, and the problems that you may be experiencing, trust me the buyers will appreciate it...
Sep 11, 2010 | Nikon Unisex LR550 Rangefinder
Black max 7kw generator high voltage output
Those voltage readings MAY be normal.
The AC waveform may cause your meter to read inaccurately. You would need to use a TRUE RMS meter to accurately read the voltage.
The siple meters actually read the AVERAGE voltage and then are calibrated to mulltiply it by the "form factor" for a sine wave. OFTEN these generators don't produce a clean sine wave. A square-ish wave will read higher on the garden variety meters.
Compare the brightness of a lamp comparing to when run on your utility.
The frequency depends on engine speed ... yours is running a bit fast...check it under at least half load and if off, adjust the govenor slightly.
May 01, 2010 | Briggs & Stratton Power Products 5,550...
To read and open the emael
Hi there, after open internet explorer click tools option. From there select internet
options and there you found a option" delete temporary internet files, history, cookies.
" Just delete them & then close the internet explorer. After that go for email reading
the page will open.
Thanks & waiting for your feedback.
Apr 12, 2010 | Yahoo Mail
Printer error can find any paper jam but still wont start!
Yes it could be. Some pin at chip of ink tank, read when printer turning on (reading presence/existence). Some pin read when start to print (reading "information" ). If there are some pin not connect, status monitor (ink level) is ok, but when start print error accured.
May 29, 2009 | Epson Stylus® RX640 All-In-One InkJet...
My PS2 fell on the floor!
Use to have this problem alot, there is a track on the under side of the tray a little plastic pin follows, it has jumped the track, do not force it closed or you could break the track, hopefully it isnt broken already. Have you ever opened a ps2 before?
Dec 12, 2008 | Sony PlayStation 2 (PS2) Console
Receiver
COULD BE A WEAK REMOTE BATTERY A BAD REMOTE OR A BAD RECEIVER.
YOU CAN BUY AN EXTERNAL UNIVERSAL RECEIVER. THAT CAN BE MOUNTED CLOSER TO THE DOOR AND IS CHEAPER THAN REPLACING THE CIRCUIT BOARD.
BUT REMEMBER, I HAVE SEEN A RV POWER INVERTER PARKED NEXT TO THE GARAGE STOP A NEW OPENER FROM WORKING AT A DISTANCE OF 5 FEET.
SO I ALWAYS SUGGEST TURNING OFF POWER TO EVERYTHING YOU CAN JUST AS A TEST.
HOPE THIS HELPS
Oct 31, 2008 | Sears Craftsman LiftMaster Chamberlain...
Bushnell Medalist Rangefinder Logo
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
