Question about Samsung 46 UN46D7000 3D LCD TV
Samsung UN46D7000 46'' HAS NO POWER
This TV won't power on. I get 6 flashes via the lower red LED indicator. If I try and hit the power button again, the LED flashes rapidly. If I disconnect the power cable I hear about 4-5 clicks - guessing a relay inside? I've checked the 3 fuses on the inside and get are what I'm assuming to be good AC voltages; 60v for the larger fuse near the power cable input and 12v for the other two fuses. Non of the electro caps look bad or bulging...
3 Suggested Answers
  • 5 Answers
SOURCE: I have a samsung tv hp-s5053, when you push the
I had the same problem and finally figured out what was wrong and fixed it. If the TV is making clicking sound, 95% the problem is the main power supply board (PSB). The easy fix is to replace the new PSB which can be ordered online from $80 to $100 (model # PSPF 501A01A), or you can buy it straight from Samsung for $129.95. If you are a little handy in electronic, knowing how to solder and troubleshoot electronic components, you can fixed it for a little cost around $30. It was $1.77+ shipping for my case, I guess I'm lucky.
I have read and research a lot of info on the internet forums and here is what I learned about this clicking problem. The clicking noise you hear when turning on the TV is the sound coming from the switching relay. It's the power protection circuit which senses a short somewhere in the system and trying to shut it down. The short can also be from other boards connecting to the main PSB, or within the PSB itself. Of course I'm not certified or TV repair man, but if it is something minor and can be fixed by a handyman, I'll try it first. If it is beyond the basic, a major problem or you have no idea about electronic at all, have it serviced at a certified TV repair shop.
For my case, here are the steps I took to troubleshoot it:
1. Unplug all 4 connectors on the main PSB. Use a Voltmeter to check the voltage on pin 10 of CN804-1 (read the print on the board where it said SB 5V), this is the standby 5V supply. If the voltage is low, not present, or spike on and off, the issue is the power supply. If the TV is totally dead after the clicking stage, this stand by voltage should be 0V or spiking up and down. For my case, the Power thermistor is dead.
2. Visual Inspection: Visually inspect the PSB for any damaged component, especially all the ESR capacitors. Look in the back of the PSB to see if all the solder traces are ok, no crack or black stain causing from burned components. If you find any damaged component, replace it.
3. If everything look good on the main PSB, then the problem is likely on somewhere else, may be the Y-board. At this stage, you should consult with a certified TV repair person.
Here is what happened to me:
Symptom:
-First stage: When turn on the TV, it was clicking for less than one minute then back to normal.
-Second stage: After 3 days, the clicking last longer to about 4 minutes then back to normal.
-Third stage: After 1 week, the power button's blue light is flashing when the TV is off. But "might" turn on after clicking for about 8-10 minutes.
-Fourth stage: No flashing blue light, no response. The TV is totally DEAD!
Solution:
-Visually inspected the PSB. Everything look good except I found an NTC Power Thermistor (next to the switching relay) was bad. It was burned and opened. The number on it is SCK 206.
-I checked the stand by voltage at pin 10 of CN804-1. I have no voltage there but a spiked voltage up and down on the meter (no reading). Definitely the problem is the PSB.
-All solder traces and capacitors look good, so I decided to replace the burned power thermistor. The big problem is to find a new part online because there is no match for SCK 206, SCK 206 is not the part number and no one on the online store knows what substitute part for SCK 206.
After a few days searching for the part number, I was lucky to talked to a technical support from a Amethem company which designed the NTC power thermistor and he quickly recognized the Samsung SCK 206. He gave me a substitute part number of a much better quality power thermistor. The part number is SL227R010 (7Ohms, 10A).
When you have the correct part number, you can find it everywhere. The cost was $1.77 each, and I got it from Digikey.com
http://search.digikey.com/scripts/DkSearch/dksus.dll?lang=en&site=US&KeyWords=sl227r010&x=0&y=0
I solder the new component back to the main PSB. My TV came back to life. Hope it help for your case.
Posted on May 21, 2011
  • 8457 Answers
SOURCE: I have a Samsung 40" lcd model LN40A53OP1FX2A
Could be,might not also,any things on the power supply board could be burn and dies,when it getting to much electricity current to it.Dead or dying capacitors on the power supply board are alway bulges or puffing up on it tops.Check the power supply board carefully look at all the capacitors parts,if require replacing,u must have tools like a soldering iron,a desoldering pump or a roll of desoldering braid,a roll of solders,also u must know basic soldering understand basic electronic to do it.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Posted on Dec 09, 2010
Won't turn. on red standby light changes to on but then goes right back red
TV won't turn on - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have the Samsung FP-T5084 50" Plasma tv. I went to turn it on the other day, and it wouldn't turn on. No clicking. No red power indicator light. Nothing. Samsung TV LN52A650A1FXZA won't turn on, keeps clicking
Jun 11, 2015
Samsung TV won't turn on
Jun 11, 2015
Samsung LCD TV LN32A330 power won't turn on
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
More results from www.cnet.com
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old. ... I have an old type sony tv with the big back and the red power light keeps flashing and ...
How do you fix a television that won't turn on? - Ask.com
www.ask.com > Technology > Television & Video
Jan 03, 2016 | Televison & Video
My 55" plasma Samsung tv model number PN51E450A1FXZA. The red power standby light is lite but when you hit the power button it blinks and returns to a solid red with no picture or sound
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Nov 06, 2015 | Samsung Electronics Samsung 51" E450...
Samsung Plasma PN58B860 works fine for about an hour that a yellow error message "Not Available" shows up in the center of the screen and won't go away or allow power off without unplugging the TV.
Do you have a program preview button i.e. one that shows details of current program and the following program. When the message appears try hitting that preview button.
Nov 04, 2015 | Samsung PN58B860 58 in. HDTV Plasma TV
Samsung series 6 led won't turn on
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Aug 18, 2014 | Samsung Televison & Video
LG 17LX1R flashing red LED - TV won't power up
Try changing the input device to something you are sure, works such as a DVD player.
Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
Aug 02, 2012 | LG 17LX1R 17 in. HD-Ready LCD Television
HDMI/ DVI inputs failed approx. one month after connection of Denon home theater receiver with HDMI pass-through feature "on." Gear successfully re-connected via component video...
hi welcome to fixya
i want to clarify first the problem sir so as of now the problem with your tv won't power on then you are using again the old main board is that right ? when you use the new replacement main board the tv is functioning will the only problem is that the HDMI / DVI inputs doesn't work. and now you encountered power supply problem like won't start up or something that cut the supply in which the stand by indicator is turn off so as my idea it has a problem with the old board. but before you come up with the board making sure all the connectors coming from the power supply is properly connected to the main board as will as flexible and lvds cable for the T-con board is properly inserted.just let me know if is that what you are asking for so i can give you additional solution thanks for consulting the fixya.
Aug 30, 2011 | Televison & Video
Red led light flashes 6 times and tv won't turn on
Hi friend,,,,,,
it is an indication of an error code ,,,,,,normally 6 blinking code refers to an power set up problem,see incoming voltage with an multimeter.......
thank u,,,,,,,,
May 03, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Projection HDTV won't power up, red LED flashes in front
i am having same problem. 3 flashes indicate convergence problem according to auto diagnostics that you are seeing(info from service manual).
i am starting by replacing stk392-110 convergence amp ic($6 at electronic.com). just ordered them, will let you know how it goes. please check this site-- http://biobug.org/ht/panasonic/ -- very good step-by-step on procedure.
will need service manual afterward. email me if you want copy.
good luck and godspeed,
bridgeman001
Apr 17, 2009 | Panasonic PT-53WX52 53" Rear Projection...
Philips 42'' Plasma TV 42PF7320A/37 red led error codes
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Mar 08, 2009 | Philips Televison & Video
Samsung 46 UN46D7000 3D LCD TV Logo
165 people viewed this question
Jerry Greenberg
Jerry Greenberg
