Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Replaceing frt fork seal 95 H D hertige softtail
Need to know the oil level for frt fork after seal replacement
  • 91 Answers
6 ozs a side 5wt for softer ride 15wt for stiffer ride
Posted on Jan 19, 2009
Fork oil level on a 95 Honda Magna 750
Let someone else chime in but on my '83 magna it 13 oz
the bikes have changed a lot since then.. 4.8 oz sounds very low
Jul 24, 2013 | Honda Motorcycles
I have a 2003 Honda CR250r and recently replaced my fork seals and fork oil. I checked the manual and the oil level says 325-405 depending on stiffeness wanted. I went for 375 and now my forks are pretty...
Hi, Robinpereira my gut tells me you either your fork oil is too heavy or you put too much in. Drain the forks and measure what comes out if it;s way over specs adjust as necessary if it's exactly what you put in then replace 350cc and see how that works.
For more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
2004 cr250r fork oil capacity
SHOWA FORK seal replacement CR 250 pt 1
SHOWA FORK seal replacement CR 250 PT 2
CR250 2002 2003 pdf
http://www.partsfish.com/page/oem-parts-for-honda
Honda CR250R Owner Manual Competition Handbook
Jun 03, 2017 | 2003 Honda CR 250 R
How to fix fork seals and what are they for and how do you know when they need replaced?
Hi,,,,,,fork seals are to stop oil coming out of your forks,,,,if your forks have oil on them ,then the seals need replacing.(you cant fix them)
hope this helps
Mar 30, 2011 | Yamaha FZR 600 Motorcycles
My front fork seals need replacing on my 2005 model TE450, i don't know the specifications, and exactly how much oil to use in each fork
forks need to be removed,and disasemble,and cleaned,new fork seals,reasembleb fit new seals, refit damping cartridge,fill fork with 5w fork oil upto 120mm from top,refit spring, refit fork cap
Aug 14, 2010 | Husqvarna TE 450 Motorcycles
Replacing fork seals and need to know amount of oil for outer fork on a twin cartridge tpye fork rm250 2005
Outer cartridge on the twin chamber Showa fork for an RM250 uses 350ml of 5W oil.
May 14, 2010 | 2005 Suzuki RM 250
What size fork seals do I need for a 2000 ZX6R Ninja? I'm going to replace the fork seals because one of the forks leaked dry, what else besides fluid and seals do I need to do this?
http://vitek.vellum.cz/manualy/Kawasaki%20Ninja%20ZX-6R%2000-02%20Service%20manual.pdf
its not quite the easy process it used to be here is the shop manual for you to use,
10w oil
oil level 116mm no spring !
Nov 04, 2009 | 1978 Suzuki GS 750 E
82 honda sabre fork seal replacement
No special tools other than maybe an air-impact whench to remove the Allen bolts in the bottom of the fork sliders. These hold the botom of the metering rods into the forks and will spin if you don't have Honda's special tool which fits down the inside of the fork tube. Air wrench spins them off no problem.
V65 Sabre has fule filter behind battery and fule shutoff valve under seat.
Loosen upper triple-clamp pinch bolt before trying to remove fork cap.
Drain oil out of fork, then remove axle and access the metering rod holder bolt at the bottom inside the area whre the axles goes. Use an air wrench and appropriate Allen bit.
Remove fork cap, being careful of the spring pressure.
Remove fork from bike and take out spring and metering rod. Pry dust seal out of fork slider and use snap-ring pliers to remove retainer from beneath dust seal. Use fork tube to hammer seal and slider bushing out of fork slider.
Replace seal and use old seal to cushion it. Make a fork seal driver from split PVC pipe and hammer seal and slider bushing back in. Remove old seal and replace retainer clip. Install dust seal.
Reinstall on bike and install spring. With bike properly supported, stand on pegs and use ratchet, extension and socket to apply pressure to spring and thread cap carefully onto top of fork tube. Reinstall metering rod holder bolt in bottom of fork using thread-locker and air-wrench. Don't over-tighten; just ue high speed to conteract tendency of metering rod to spin inside slider.
Remove fork cap again and fill to appropriate level with 5 weight fork oil (Pro Honda SS-7 or equivalent). Use turkey-baster to remove excess oil to proper level (5 1/2 to 7 inches fully compressed depending on damping quality desired).
Jun 03, 2009 | 1985 Honda VF 1100 Sabre
Front fork leaking oil from bottom of the seal.
change the oil seals and oil in the fork,and avoid wheelies on the bike and off road biking
May 17, 2009 | 2004 Honda CRF 250 R
Replaceing frt fork seal 95 H D softtail
Specs for a FXSTC is 10.2 oz
for FLSTC its 11.5 oz
For your year bike use heavy duty fork oil
Jan 18, 2009 | Harley Davidson Harley-Davidson Motorcycle...
How to fill the front suspension on a ktm exc 2001
If you get the sevice manual or contact a dealer to get the correct oil amount for your bike, they need to know the model and year, you have to have the forks off the bike. take the fork caps off, take the springs out compress the upper fork tube all the way and add the specified oil. if they also give you the measured amount from the top that's the best way to get both fork oil levels exact. there is a special tool that you set the oil level in millimeters and it sucks out the oil to the right level, but before you do that step after adding the oil always pull and push on the cartage rod several times to remove air from the cartage tube. you will hear the air coming out and you will feel the changes in the cartage rod as the cartage tube fills up with oil and the air is removed.
something i'm confussed on though is if you replaced a seal you would have had to brake down the fork to replace it. you would have poored the oil into a container, cleaned all the internal parts,and used a fork seal driver to install the new seal. part of your question asks where do i put the oil in? thats in the open end of the fork after you have taken off the fork cap. It sounds to me like you only replaced the dust seal on one fork. that is not going to fix your leaking fork. you need to replace the oil seal thats pressed inside of the top fork tube.
Dec 01, 2008 | 2008 KTM 200 EXC
Lands Phones Logo
83 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
