Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool ghw9100lw1 high speed spin keeps knocking
  • Whirlpool Master
  • 17,130 Answers
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Posted on Dec 31, 2012
5 Suggested Answers
Jimster
  • 240 Answers
SOURCE: Whirlpool won't spin at high speed
Sounds like you may have lost your basket drive and clutch assembly. This is a pretty involved job to replace for sure, and requires you to remove the inner basket, drop the transmission, etc. Does the unit make any wierd noises, like popping or grinding? Does it agitate ok in wash? I would bet almost for sure that its that basket drive and attached sub-pack thats went bad. If you want to try and tackle this yourself, let me know, and will get you directions to do so. Good Luck!!!!
Posted on Feb 02, 2008
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool Duet Washer will not start
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
kapishtech
  • 2272 Answers
SOURCE: Whirlpool washer (top loader, 5 years old) will
The tub spins but the machine will not go in high speed. you have a worn clutch. Usually, the clutch will wear out due to a bad set of brake shoes,or a busted comb filter in the tub.This has to be checked.
If the lower half of the clutch is turning when the unit is supposed to spin, yet the upper half does not, the clutch may be damaged or even the white plastic brake release cam above it could be worn. The clutch kit comes with a new brake cam also. Check fig for more help:-- c768d6f.jpg
--------- "if the clutch gets hot when running in a spinning cycle, even for a short time, that means that the clutch is "sliding" and that is the reason that the washer does not spin on high speed spin".You check the clutch in your washer after the spinning cycle and if it is really hot.Replace the clutch. ----------
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Oct 02, 2010
  • 6277 Answers
SOURCE: Whirlpool Duet Washer GHW9100LW1 symptoms of
Always worth while adjusting the 'balance'!
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Sep 01, 2011
Whirlpool Duet Washer Model # GHW9100LW1 is not spinning properly, leaving the clothes wet.
could be a couple of things ,none of them good! not easy to get this thing apart by your self and not cheap to fix.
Dec 15, 2017 | Whirlpool Washing Machines
Whirlpool Cabrio Washer does not spin the water completly out of the clothes
probably not getting into high speed spin mode
they spin slow in the initial stages to allow the clothes to become evenly distributed then after the water is removed they pick up speed
It is possible a problem in the program board not advancing to high speed
Call in a technician for a proper diagnosis and a quote
Jul 07, 2016 | Whirlpool Washing Machines
What will cause my Whirlpool washing machine to set on low speed spin cycle?
The machine uses automatic load sensors to balance the load and when you put something in the machine that is big, like a comforter, it knows that it cannot balance that item. So with a front loader it wont spin at high speed because it would be off balance and either damage the machine or the machine would "walk" because of the off balance motion.
Apr 28, 2014 | Whirlpool Washing Machines
I have a Whirlpool Duet model GHW9100LW1 purchased in Nov 2003 and the tub just began a serious knock during the high speed spin cycle. I checked the shocks, springs to ensure they were connected and they...
Hello with the limited information you have supplied this sounds like it is going to be the bearing, this is not something I would suggest a DIY fix since you have to replace the rear half of the drum with this model. If you have any other questions please feel free to comment. Good Luck! Mike
Oct 01, 2009 | Washing Machines
Flashing code F-6
F06 Drive motor tachometer error The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU)
• Check the Drive Motor
• Check the MCU
• Check the Wire Harness
Replace failed component.
Apr 12, 2009 | Whirlpool GHW9300 Duet Washer
Whirlpool Duet GHW9150P knocks when spinning
I had that problem while the washer was under warranty. Luckily my neighbor is a repair man. He removed the front cover just under the door. There are shocks under the barrel that keep it aligned. One of mine was damaged and the barrel became misaligned. Check that area, that might be your problem. Good Luck!
Nov 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet washer has started to make much more noise in the high speed spin mode, is this normal or is it a service issue?
A loud, roaring noise in high spin speed usually indicates the tub bearing is failing. A large job best left to the professionals.
Jul 04, 2008 | Whirlpool Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
75 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
