Question about Kenwood DV-605 Multi-disc DVD Player
When I insert a DVD into the player I get a "disk error" msg
The owners manual does not cover this. Is it a matter of reprogramming something or more like an electrical problem in the equipment?
  • 12 Answers
SOURCE: Disk error with Kenwood DV-605 multi-disc DVD player
Try the following
when the error is on the screen, press the number 1 key on the remote, this should take you to the fist chapter of your DVD no matter which region it is
Miguel
Posted on Feb 16, 2008
All the dvds I insert are reading disk error.
Sounds like it is time for a new unit. your problem is not worth fixing as it is either a failing laser pickup due to age, or the laser beam is caked with tar from smoking.
New blurays are quite inexpensive.
Please dispose of the unit responsibly.
May 09, 2014 | Philips Magnavox MWR20V6 DVD Recorder/VCR
When i insert a disk I get error. I don't have the owners manual so not sure if I am operating right?
What is the model of your player? mention it so that i can provide owner's manual.
Oct 27, 2012 | Audio Players & Recorders
I get insert disc error on my player. It sounds
More than likely this is an inner system malfuction of the dvd player the owner can try buying and using a cleaning disc for the dvd player, but if that does not correct the problem it is probably beyond his ability to self repair.
Jan 19, 2010 | Sony DVP-NS700P DVD Player
Disk Error, CD only
It may not recognize the CD if it is a copy. try an original CD and see if it works.
Nov 30, 2008 | Onkyo DV-C601 Multi-disc DVD Player
No disk error
If cleaning with a cleaner disk and solution did not work, then you have to clean the lens directly.
Remove the cover and access the inside of the DVD, unplug power first.
Use soft cotton sticks and isopropyil alcohol to clean the lens, here is a picture of the lens pickup:
As usual do the job at your risk, if you want to call for repair you can use the number listed in the owner manual.
Oct 14, 2008 | Cambridge Audio DVD89 DVD Player
DVD Player Displays 'Disc Error'
try a cleaner disk, if that doesnt work, junk it and buy something better than this one...cheap dvd players have a habit of not working very long....
Mar 31, 2008 | Durabrand DVD-1002 DVD Player
Try the following
Miguel
Jan 03, 2008 | Kenwood DV-605 Multi-disc DVD Player
NO DISK error
it is probly the parental setting in which you have to use password to change . if you lost -password then your shit out of luck so far just like me.
Nov 28, 2007 | Coby TF-DVD7100 Portable DVD Player
Dawoo DVD Player showing No Disk error
you have dirty lens, try to cleaning with 100% cotton buds. or you have damage laser eye, or broken flex ribbon wire, but first you have to do is to cleaning the lens with cotton buds.. if not reading after you clean the lens! change the laser eye and flex ribbon wire.
Aug 31, 2007 | Daewoo DVDS151 DVD Player
Kenwood DV-605 Multi-disc DVD Player Logo
59 people viewed this question
Top Kenwood Televison & Video Experts
Jaime Hernandez
Jerry Greenberg
Jerry Greenberg
Are you a Kenwood Televison and Video Expert? Answer questions, earn points and help others
