Question about Samsung Digimax S630 Digital Camera
Lends wount open
When i turn on the camra the lends wount extend out and open. then there is a triple beep, and shuts off how do i fix this?
We had the same exact problem with our camera. Tried calling Samsung for help,but customer service hours are limited. We took our camera back to the Walmart, showed them the problem, and they refunded our money.
Posted on Jun 25, 2007
SOURCE:
I have a brother xr 65 and the reverse stitch lever fell off how can i fix it?
I'm not sure that this type of problem lends itself to a DIY fix. You might need a technician's expertise.
Jul 15, 2015 | Brother Sewing Machines
On my 2000 grand Marquis when I turn on the heat smoke comes out the vents like antifreeze or something ! How to fix?
try going to autozone or any auto supply that lends tools for free ask for their pressure tester and fittings for your cooling system. open hood make sure vehicle has not been running for at least 8 hours. open coolent tank and attach the tester. Pump it up to 13lbs or high test limit., check in and outside of the car. I beleve you will find your heater core is leeking or a heater hose has gone bad .I suspect it will be the heater core . if this was helpful please leave me good feed back.
Nov 20, 2014 | Cars & Trucks
My camera lends got stuck and it wont come out like it used to
This happens a lot. Gears inside the lens assembly can get dirt in them, or be damaged by pressure on the assembly when it's extended. Here is a blog which details the things you can try to get it working again. They say if you follow their steps, you can get the camera working again about half the time.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
The blog is about a lens error, but it applies to your problem also.
Good luck, and hope this helps!
Jun 10, 2010 | Cameras
Morning, I have a Olympus U700, 7.1 dig camera approx 3 years old.The lens wont open up on pushing of the power button. Error displayed in window is 5fO8 and 5eO2, can you help me?This is the second oly...
i had exactly the same problem with my camera and have just managed to fix it. turn the camera on, and as as the lens extends remove the battery so the lens remains extended. then make sure the lens barrel is correctly aligned. press down on the front of the lens, when you hear a click that means the lends guiding pins have been re-aligned. BE CAREFUL as this could permanently damage your camera, so do as a last resort if out of warranty. check out link for more
http://translate.googleusercontent.com/translate_c?hl=en&sl=fr&u=http://www.fixya.com/support/t3268546-olympus_700_error_code_5e02&prev=/search%3Fq%3Dolympus%2Bu700%2Bcamera%2Berror%2B5eO2%26hl%3Den%26rls%3Dcom.microsoft:en-gb:IE-SearchBox%26rlz%3D1I7SUNA&rurl=translate.google.com&twu=1&usg=ALkJrhg9vW2KLyPE2-5oM9nKDhHw9eSAxg
Nov 29, 2009 | Cameras
REPLACE DASHBOARD LENDS
Take all the screw holding the instrument panel and slowly take it off. Now, you can change all the busted bulbs at the instrument panel.
Nov 11, 2009 | 1999 Nissan Quest
DC-T50
Dear Sirs,
The lends on my camera will not open. The light comes on in the view screne and shows Error 3 on it. I have no idea what it means. What I meant is that it will not open is that the lends will not open out completly it opens to about a 1/4" to 3/8" and is stuck there. How can I get it to open completly or must I sent it to your shop to get open?
May 20, 2008 | Gateway DC-T50 Digital Camera
Optio m20 beeping?
i got it!!! on my cam i hold down the menu button at the same time power on, it will showup a " ver 1.00" and lens move a little maybe u have to do it 2 times but second time it should work
Dec 08, 2007 | Pentax Optio M20 Digital Camera
Samsung Digimax S630 Digital Camera Logo
27 people viewed this question
Top Samsung Cameras Experts
Jerry Z
Andy Bale
Andy Bale
Are you a Samsung Camera Expert? Answer questions, earn points and help others
