Question about Water Heaters
Relief valve leaking on sta kleen 502
Hot water leaking from relief valve. what do I do?
  • Water Heaters Master
  • 5,089 Answers
1) Copy following link for TP valve troubleshoot steps:
http://waterheatertimer.org/How-to-replace-TP-valve.html
2) Add a comment and say what you find.
Posted on Dec 31, 2012
My water heater pilot light won't stay lit
I would try cleaning the thermo couple surfaces with some steel wool... Both where the flame contacts the sensor, and the electrical contacts. Even a small increase in voltage may be enough to hold the pilot valve open. Both black, and white soot on the sensor end, can act as an temperature insulator, lowering the output voltage.
As for finding the part numbers for replacement: http://www.reliancewaterheaters.com/media/48391/242117_RPPCR01111-Reliance-Parts-Catalog.pdf
Feb 17, 2016 | Water Water Heaters
How to change out copper piping from release valve
If the release valve referred to is the pressure release valve, then a water leak out the attached vent pipe is an indication that the valve is failing. To change the valve, the water must be allowed to cool (turn off AC power or gas) and the water level inside the tank must be lowered (drained) to below the level of the pressure relief valve. Once this is accomplished the vent pipe is unscrewed from the relief valve and the pressure relief valve is unscrewed from the water tank. A new pressure relief valve with a sealant on the threads, is then screwed and tightened into place with the outlet port facing downward. The vent pipe is attached to the new valve and the tank refilled with water. A hot water facet must be opened to allow air to exit while filling. Upon becoming full (water will begin to flow from facet), turn off the facet and restore AC power or gas, therefore allowing the water heater to heat up. When the first hot water is utilized there may be some air expelled from the facet.
Sep 13, 2015 | Water Water Heaters
I have a 21v407 Rheem water heater that is leaking from the top relief valve. The leak i believe, is from under the valve. what is this problem. and how do u drain this thing?
Shut off the water supply valve over the heater. Shut off the electric or gas to the heater.
If you have any house or basement water valves below the level of the heater, open them and open a valve that is higher to vent it.
If necessary, open the drain at the bottom of the heater and using hose or buckets, lower the level below the relief/thermostatic valve. Be careful, the water is hot and softens even heavy hoses.
Once the water level is down, unthread the downtube (if there is one) from the discharge of the relief valve, unthread the relief valve from the heater and either dope/tape the threads or replace the relief valve.
Write back with any questions.
Sep 09, 2011 | Rheem Water Heaters
I can not light the pilot on my reliance sta-kleen 502 (30 gallon) waterheater. please help
Reliance is Rheem
Replace thermocouple is best start point.
Example Whirlpool manual shows general replacement steps on page 22:
Buy thermocouple at hardware or home center. measure length before going to store.
http://waterheatertimer.org/pdf/Whirlpool-6510397.pdf
Utube videos show how to replace thermocouple
Many things can affect pilot:
Low gas pressure, Water or air or debris in the gas control valve, High-heat event causing ECO to trip requiring new gas control valve, burner and tubes needing clean-out, FV sensor tripped, loose or bad thermocouple.
Manual above shows general steps for doing some of these things, but service technician is probably best choice if thermocouple does not fix problem.
Gas water heaters require periodic maintenance.
If repairs cost more than $330, then buy new gas water heater and install yourself.
Use the old one for a solar collector.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 22, 2011 | RELIANCE ELECTRIC WATER HEATER
Pressure releif valve leaking
Hot water pressure relief valves serve two functions. The first is to remove high-pressure water from the hot water tank. The second function is to act as a high temperature valve to remove water that exceeds a predetermined point for the valve. Both of these relief settings are preset at the valve factory. Many pressure relief valves will come with a metal tag that identifies these release points. If you're attempting to remove the hot water heater pressure relief valve, pay careful attention to ensure that you replace with the correct valve.
Your hot water heater has a pressure relief valve safety mechanism. When pressure inside the water tank exceeds certain limitations, the valve opens up to allow the pressure to be released. A faulty pressure relief valve will not release excess pressure, which could cause extensive damage to your home. You should test the hot water heater pressure relief valve once every six months to ensure proper operation. If the pressure relief valve fails the test, replace the valve with a new one immediately
Locate the pressure relief valve on your hot water heater. The pressure relief valve has a lever handle on top with a drain pipe attached to it. The pressure relief valve is most often on the side of the water tank toward the top. Newer models of hot water heaters have the pressure relief valve on top of the water tank.
  • Inspect the area around the pressure relief valve for signs of leaking water. If there is leaking water near the relief valve connection, replace the relief valve. If no leaking is evident, proceed with testing the pressure valve.
  • 3
    Examine the area below the pressure relief valve drain pipe. Most water heater closets either have a drain in the floor below the pipe or the pipe is inserted into another pipe to direct the water out of the home. If the end of your drain pipe is not in another pipe or there is no drain in the floor, place a bucket under the drain pipe to catch water when you test the pressure relief valve.
  • 4
    Pull the lever handle on the top of the pressure relief valve up with your fingers. A working lever will lift up without difficulty.You should begin to hear water going through the drain pipe. Slowly release the lever to shut off the pressure relief valve. The pressure relief valve is good. If you did not hear water running through the drain pipe, lower the lever on the pressure relief valve and replace the valve. If the lever is difficult to raise, do not force the lever. Replace the pressure relief valve.
  • Now with all that said if you have a closed loop water supply system and you have a pressure vessal/expantion tank it may have gone bad and is making the TP valve leak. you can call your water provider to see if you have closed loop system.
    Feb 04, 2011 | Whirlpool Water Heaters
    I have a Reliance Sta-Kleen 805 Electric Water Heater that is leaking from the cold valve but the water is coming out hot. How do I repair it?
    If I understand correctly you have residential electric water heater, and your shut off valve located above water heater on cold-water line is leaking?
    1) Hot water would come out of this valve if it's leaking because water inside tank is hot and under pressure ... also remember, hot water rises so tank is probably heating the water inside the cold line during hours when no hot water is being used.
    2) You probably need to replace the valve. But if water is leaking because a pipe is rusted, the valve may be ok, and just the pipe needs to be replaced.
    Take a photo of your problem to hardware store or home center.
    I used to work in those stores and could help folks get the right parts.
    3) Here are some steps for replacing the valve.
    Shut off main water source into house. This is usually located underground in same box where meter-reader looks at meter.
    Your water heater shut off valve is called a gate valve, and it will be 3/4"
    All water heater pipes are 3/4"
    You will need two 10-12" pipe wrenches, maybe a new gate valve, maybe a new flex connector, probably short 3/4 pipe pieces, teflon tape for each threaded pipe.
    Hardware store or home center can get you the right materials, just take a photo over to hardware store
    4) When you get started, turn off water heater circuit breaker for a couple hours so water will cool down. You don't want to get scalded with hot water.
    Do NOT drain the tank.
    Simply open a bathtub faucet on hot side to release pressure.
    When finished, turn on the water, and make sure water is flowing out of tub spout in full stream before turning circuit breaker ON
    Add a comment for more free help.
    Also take advantage of fixya phone service.
    For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
    Jan 23, 2011 | RELIANCE ELECTRIC WATER HEATER
    Just purchaced a 99 jamboree with an atwood G6a-8e water heater. while on a trip I lit the water heater, and after 30 minutes someone told me water was leaking from the side. I noticed the pressure relief...
    It's gas operation only, but has electronic ignition for propane. ( just to confirm, if you look at back of water heater, it would have a metal or black plastic cover and hydro cable going in side or top of it.)
    There are usually 3 things that may cause pressure relief to leak. 1) Faulty,corroded pressure relief valve, which usually needs to be replaced if it goes faulty. 2) water temperature is getting too hot, which could indicate a faulty thermostat. 3) If your hooked up to city water, the pressure may be too high, causing excess pressure build up in hot water tank, thus pressure relief opens. If your running off your on board pump, this is probably not the cause, as they are usually set at 40 psi.
    Ist, - try pulling lever on relief valve slightly open ( careful it's hot !!) to clean out any calcium that may be logged on seal thus causing leak. If that doesn't do it, and the hot water isn't running out steady and appear to be under extreme pressure while leaking, then I'd change the pressure relief valve. Remember when you do, shut off water to system, and relieve pressure by opening a tap, and pressure relief as well after that. New one shouldn't be too expensive, just make sure you get same thread, 1/2"NPT or 3/4"NPT. Use a little teflon tape, or pipe dope whatever you prefer when re-installing as well as clean threads a little before.
    If it really starts gushing out pressure relief when heating or heated, and water seems hotter than normal, it's more than likely a faulty thermostat. I'll wait for your reply on what condition your experiencing before I go in to how to change the thermostat.
    Nov 17, 2010 | RTO Atwood Water Heater - 6 Gal LP
    Relief blowing out hot water every hour or so. Controller? Set at about 125.
    try replacing the pressure relief valve to do so turn off water to heater and turn off power or gas which ever you have drain water from heater. then using pipe wrench remove old relief valve. when installing new valve use teflon tape on threads to prevent leaks then thread by hand back into water heater and use pipe wrench to snug dont over tighten turn water back on after full and no leaks turn power back on or relite piolit
    Nov 24, 2009 | Water Heaters
    Relief valve constantly releasing water.
    lower your thermostats a bit. If your temperature is set to the hottest setting, then chances are no relief valve will do
    Jan 08, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
    Water Heaters Logo
    73 people viewed this question
    Top Water Heaters Experts
    Donni Steen
    Gil Shultz
    Are you a Water Heater Expert? Answer questions, earn points and help others
