Question about Refrigerators
GE profile performance TPS24BP leaks water and makes thin ice
  • 833 Answers
SOURCE: Ge profile side By side ice maker water leak
This sounds like the float mechanism has gone bad. Remove it and have a look. It may be the float or the switch on it that is bad. There is also a solenoid valve. Parts kits are available. Shut off the water first!
Posted on Dec 22, 2007
  • 1314 Answers
SOURCE: GE Profile Ice maker/ Water Dispensor not working
ok try this for me and let me know how it works there is a water tank in the fridge and on installation you have to hold down the water for about 5mins to fill it up now the ice disp will be a separate issue hold my rating and let me know if your water flowes first
Posted on Jun 13, 2008
  • 4 Answers
SOURCE: Water leaking - GE Profile Refrigerator, Model: TPX21PRX
Check to see if the drain at the bottom of your freezer is plugged. When the refrigerator goes on defrost, the water has to go somewhere. Look below the coils in the freezer section and see if there is ice in the drain.
Posted on Jul 15, 2008
SOURCE: GE top freezer ice maker leak
I have the same problem -
Posted on Aug 11, 2008
  • 19 Answers
SOURCE: Ice maker in our GE profile refrigerator is not working
Ice maker Diagnostic Test:
- Remove the ice bucket
-Turn the ice maker off, wait 15 seconds than turn it back on
-Press the ice paddle three times, this will begin diagnostic test.
-PLEASE DO NOT TOUCH ICE MAKER DURING DIAGNOSTICS
-In 3 minutes you should see the rack inside turn 360 degrees
-AND the ice maker bowl should fill with water
-IF either DID NOT work, call 1-800-GE-CARES for ice maker replacement. A service call is approx $80. The $80 will be deducted from the part/labor if you choose to purchase/install parts from the service technician. If not, you will pay for the service call. Good luck.
Posted on Apr 05, 2010
I have a side by side GE Profile refrigerator with ice and water in door which is about 10 years old. I just noticed a thin layer of ice in the bottom of the freezer. I removed it but it returned a few...
hi look to the back of inside of freezer lower part just above where you saw ice you will see a gap that the freezer drain there a hole in the middle may be cover with ice take hair dryer and melt ice and blow out drain that should do it jim
Oct 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My daughter's GE Profile performance TPS24PPBGRS side by side is accumulating ice at the bottom of the freezer. Can you help us with this problem? Everything else seems fine. Thank you
I had the same problem. Check the hose that feeds water to the freezer. Mine had cracked and was leaking to the bottom and freezing. good luck
Aug 27, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Side By Side Ice Machine & Water dispenser not getting water
you may have a pin hole in your water line to your dispenser or you could be leaking at the water valve itself on the water dispenser side. you'll have to pull the refrigerator out from the wall and look where the main water line goes into the back of the refrigerator. you will probably have to take the back off to see. be sure you put the back of the refrigerator back when you are through.
Jun 05, 2010 | GE Profile PSW26P Stainless Steel Side by...
Me GE Profile PSC23M Side by side ice maker quit making ice and water was on floor behind refrig. Is a water line frozen or clogged or do I have to replace ice maker?
It sounds like you just have a leak at the back. Try swapping the wires on the dual water inlet valve. Then try the water dispenser and watch on the back for where the water may be leaking before it gets up to the ice maker.
Oct 04, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE Freezer Leaking
Open the freezer door, remove the bottom tray, smash the ice on the floor with your fist to remove it. Now get a glass of hot water and pour it into the trough which is at the bottom of the back wall of the freezer. Allow a few minutes for the ice to melt then remove it with an ice pick or scrrewdriver. Once the ice is out, pour more hot water into the trough. Now take a long tube ( an old washer fill hose works perfectly) and stick one end in the hole in the trough. Now fill your mouth with warm water and blow it very hard through the tube. Once the drain is clear, pour some hot water and a very little amount of bleach through the hole.
Apr 06, 2009 | GE Refrigerators
Icemaker in ge profile refrigerator
Pull it out and push it back at the right position, see if it is working.
Jul 10, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE profile performance tfx30ppz ice dispenser not working
Had the same problem. The water line from the valve to the ice maker was cracked due to heat from the compressor.
Jan 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Dec 22, 2007 | GE Profile PSI23NCR Side by Side...
Refrigerators Logo
80 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
