Question about Friedrich Dehumidifiers
I need a part for my Friedrich D70BP 70 Pint Dehumidifier with built-in drain pump, front bucket and continuous drain
The plastic piece that connects the tube to the continuous drain cracked
  • 30 Answers
SOURCE: haier 30 pint dehumidifier continuous drain problem.
Many just attach the hose at the reservoir; from your description, Haier apparently has a separate location. Check that the point that the hose attaches has an opening (many don't, they expect you to drill it). It should then drain through gravity. Check to make sure that no part of the drain hose is higher than the bottom of the reservoir, otherwise it can't drain. It won't siphon because each time the the tank empties, the suction is broken and the siphoning can't continue.
Posted on Aug 31, 2008
SOURCE: I need a manual for the Kenmore #54701
Here is a link for the manual. You can download it and save it or print it.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0406271.pdf
Hope this helps, it's from www.managemyhome.com
Maryanne
Posted on Jun 17, 2009
  • 3 Answers
SOURCE: I have a Kenmore 580.53701300 dehumidifier (70
Jim,
I have this dehumidifier and the owner's and parts manuals to go with it.
I will scan them and email them to you.
Hope this helps!
Jamie
Posted on Aug 06, 2009
  • 37 Answers
SOURCE: 50 pint dehumidifier has drain hose connected but
safety switch is turning off the dehumidifier....you need to drain out the bucket more often....or put the drain hose into an actual drain....ive seen some people run a small plastic hose from the dehumidifier to the sump pump hole in their basement.
Posted on Jan 27, 2010
SOURCE: We have a Frigidaire 70
I had the same problem with the LAD 704 DUL......I tilted the unit back just a little bit. The water is now flowing through the hose and into my drain....
Posted on Jul 03, 2011
Hi. My dehumidifier stopped working. It powers on, but does not do anything.
Check if the full light is lit. If so check that the float switch is free.
On page 5 step 3 they discribe how the float switch needs to be free?
http://www.sylvane.com/media/documents/products/friedrich-d70bp-dehumidifier-owners-manual.pdf
Jan 16, 2016 | Friedrich Dehumidifiers D70bp
How to get direct drain option to actually work on my Edgestar DEP700EW dehumidifier?
The outlet is probably clogged with moss or foriegn bodies. Clear the water way.
Sep 11, 2014 | EdgeStar 70 Pint Portable Energy Star...
Why does Frigidaire dehumidifier send water outside bucket?
Good Afternoon Jean,
I understand that your Frigidaire dehumidifier, model# FAD704DWD, is putting the water that it collects out onto the floor as oppose to the bucket. I suggest contacting the manufacturer for more information. They should be able to point you in the right direction for assistance. Hope this is helpful.
-Best Regards-
WP
Jul 02, 2014 | Frigidaire FAD704DWD 70 Pint/Day Energy...
Why does blower wheel stop on Frigidaire dehumdifier?
Good Afternoon Desi,
I understand that the blower wheel is not spinning on your Frigidaire dehumidifier, model# FAD504DUD. I also see that the compressor will stay on unless the dehumidifier is unplugged. I suggest you contact the manufacturer for further assistance. They can possibly clarify why the compressor stays on and why the blower fan is not working. If not, they should at least be able to point you in the right direction of having your dehumidifier working. Hope this is helpful.
-Best Regards-
WP
May 30, 2014 | Frigidaire FAD504DUD White Energy Star 50...
Power s on unit doesnt run no fan nothing
Mosr dehumidifiers have a switch that shuts the unit off when the water tank is full check this float to make sure it is not stuck in the off position also empty the tank if it is full.Hope this helps.
Dec 10, 2013 | Friedrich d70bp dehumidifier,70 pt.,115v
I own a Whirlpool Dehumidifer Model Number AD 70USS1. I have a drain hose connected to the unit, however, recently the unit's internal collection bucket fills with water to the point that the...
superstee - You're having to empty it because either the drain hose you have connected to the unit is clogged or the drain hole a the hose connection is clogged. Therefor, the water is drained into the tank, rather than the drain hose. Also, the drain hose would not be any longer than 5' and must drain down, as the dehumidifier does not have a pump. It relies totally on gravity.
Remove the hose and check it for clogs. If clear check the drain hose connection, using an 18" long appropriately sized Zip Tie. Carefully insert the Zip Tie and continue to push it in until you reach the bend in the tubing. Gingerly work past this bend, until the Zip Tie bottoms out or you run out of usable Zip Tie. The while slowly pulling it out, rotate the Zip Tie. This will dislodge the clog. As you reach the end of the Zip Tie removal, be prepared for some water to follow. CAUTION: BEFORE DOING ANY OF THE ABOVE TURN THE MASTER ON/OFF SWITCH TO OFF AND UNPLUG THE UNIT.
The above should solve the problem for you. Please let me know. Thanks.
Jun 08, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
Light says "bucket full" but
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
May 27, 2011 | Friedrich D65A Dehumidifier
My whirlpool AD70USS 70 pint dehumidifier won't run , it just beeps. There is power and the bucket is in place properly, The unit is clean and nothing is plugged and the fuse in the panel is ok
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jan 17, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
50 pint dehumidifier has drain hose connected but fills up the drain bucket and stops running....
Jan 27, 2010 | Frigidaire Dehumidifiers
Fdk45p1 dehumidifier
Has anyone figured out how to get a 25-pint Frigidaire dehumidifier (model FDD25S1) to put water out the drain hose for continuous draining instead of into the bucket? It appears to be impossible to connect the hose in a way to avoid water leaking into the bucket.
Jun 06, 2008 | Frigidaire FDL45P1 Dehumidifier
Dehumidifiers Logo
87 people viewed this question
Top Friedrich Dehumidifiers Experts
jhnolson
J.D. Browning
J.D. Browning
bobalix
Are you a Friedrich Dehumidifier Expert? Answer questions, earn points and help others
