Question about HP Media Center PC 873n (P9875A#ABA) PC Desktop
Won't complete booting
My computer shut down during the night. When I tried to boot it, it keeps shutting down during the process. Each time I try the to boot, the process gets shorter and shorter. The fan is running. Is this computer done?
  • 1 more comment
  • S_Nandha May 11, 2010
    How far along the boot up does it go before it shuts down? is there any messages or any text on the screen?
  • markus
    markus May 11, 2010
    check the cpu cooler...maybe its dusted...
    You can check the temperatur in the bios....when the cpu is to hot the system shut down..
  • machadojr_fe May 11, 2010
    does it beep at all and what have you tried so far?
    Problem Solver:
  • 6 Answers
Sounds like at the very least, the hard drive is. This is common when a file required by the OS is corrupted, and the OS tries to not damage data so it restarts or shuts down.
Posted on Jan 19, 2009
My lap top shut down and would not restart. I called the company and they said I needed to reinstall programs. They sent me two discs, but I cand get them to load.
Step 1:
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your computer and operating system Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
Mar 15, 2013 | Dell inspiron 14r-n4110 laptop intel
It keeps shutting itself off ?
When does it shut itself off? Is this happening time you press the power button and during the boot cycle it shuts off without completing the boot to windows? If it shuts down after you've worked on it for a while it could be that it is running hot. If you let it sit a while to cool off then press the power button, if it completes the boot cycle and allows you to work it is definitely running hot. Normally when they run hot if you immediately try to reboot, it will fail. If you let it cool off it will boot successfully. Computers run hot because of a fan not working, dust clogging the fan vents or the Thermal Paste around the CPU and Heat Sink has become hard or too thin to keep the unit cool. If it's not running hot you might have a power supply or motherboard issue. Try removing the power cord and press and hold the Power Button for 30 seconds to release any Static Buildup. Then plug the power cord back in and try to reboot.
Mar 18, 2012 | Dell OptiPlex GX280 PC Desktop
Hi, My Samsung R580 I3 JBB2-US keeps on shutting down. If I close the lid when I re-open it shuts down & I have to restart or it freezes and I have to force restart. Sometimes when I boot up it...
You can try go to Start - Control Panel - Power Options and check what you want computer do when you close the lid of your laptop. Fix that and restart laptop to apply the setting.
If the boot up not complete and restart by itself, in my opinon, there is something wrong on the start up process, could be hardware malfuctions, could be a software not compatible. Try check the start up process to see.(use Start- Run: msconfig)
If this happen often, you should call the Samsung customer services to find out. Laptop i3 should still under warranty.
Hope this will help.
Thanks for reading
Jul 20, 2011 | Samsung R580 Notebook
HI I have a D865 PERL m/b. The CPU overheated, due to a load of dust blocking the heatsink fins. I have cleaned it all up and the heatsink should be fine now, but when I try and boot I get a message...
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
Also you might try
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
hope this helps
May 14, 2011 | Intel D865PERL Motherboard
Hi, i have a Sony vaio and it was working fine until I shut it down overnight, the next morning I tried to turn it on which started out fine but as soon as the windows emblem started loading, it didn't...
or
Also you might try
hope this helps
May 01, 2011 | Sony Computers & Internet
Screen is frozen on 1 of page 4 of books. Battery is fully charged and a book is highlighted. Nothing happens and can't shut it down or do anything with it. Reset won['t work.
or
Also you might try
hope this helps
Apr 25, 2011 | Computers & Internet
When booting up the devise, only the GPX logo appears. seems stuck and won't shut down unless i remove the battery. switch to off position does not work. I can load and delete mp3 files from the computer...
or you might try
hope this helps
Apr 10, 2011 | Computers & Internet
Computer shuts down and doesnt allow to use f8. shuts down first. what to do? virus help?
Your use of "and" is confusing. F8 is not used during the shut down process; it is used during the boot up process. Since you mention F8, it is presumed that you want to use F8 to get into "Safe Mode" instead. When you re-boot a running computer, very often you will not be able to use F8, but if you totally shut down, then start from scratch, you should be able to hold the F8 key down and it intercept the boot up process to handle things properly. Don't worry if you hear a lot of beeps during the boot up process with the key pressed; it merely means the keyboard buffer is receiving more key presses than it has room for. Since they all are F8, when the boot up process looks at the characters from the keyboard, it will see the F8 key, then display the menu options to boot into Safe Mode.
Jan 07, 2011 | Computers & Internet
Quickrestore- keeps shutting down mid-process
Sounds like the cd/dvd is not reading the cd's correctly, Not sure if my compaq restore cd will help but here is the link to cd 1
Download the file burn ISO to cd and boot from cd,
For giggles did you try an external cdrom?
Mar 29, 2008 | HP Compaq Presario 2100 Laptop
Hp xw 6000, keeps shuuting down during initial boot up.
reseat ram if not i'd say to take 1 stick of ram at a time and start the computer with such might be a ram issue or run memtest 1.7 which can be downloaded here http://www.memtest86.com/ boot to cd once downloaded and burned to test ram
Mar 19, 2008 | HP XW6000 PC Desktop
HP Media Center PC 873n (P9875A#ABA) PC Desktop Logo
115 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
