Question about Home
Have a Mansfield 16. Runs intermittently, I can see water coming in to bowl. Not a flapper design but a Mansfield flush valve tower. Any suggestions without pulling tank?
Can I just replace valve seal or do I need to pull tank and replace tank to bowl seal?
SOURCE: Toilet Refills Every 15-Minutes
I have minute amount of leakage into the bowl causing mold to grow. I believe that it may be the rubber seal for the flapper body to the porcelain.
Posted on Jan 10, 2009
kachbibi1
  • 979 Answers
SOURCE: Toto Dartmouth toilet flapper/chain design flaw
Your right this is a poor design. Space was the main reason for this and functionality was sacrificed. However, you can get a replacement rod at a major plumbing store. You could rig it by attaching a stem to the valve assembly. Allow the chain or rubber piece to slide over it. It is kind of like putting a permanent finger in the path of the chain to give it a "direct" lift up. This would then force the chain to go up instead of at an angle.
Posted on Jan 28, 2009
  • 6 Answers
SOURCE: Toto toilet Power Gravity intermittently running
I suggest that you replace the cap with the new seal, it sounds as tho the valve is not shutting off and the bowl fill tube continues to run. Have you adjusted the water level to 3/4 of an inch below the overflow tube. If not, try that.
Posted on Mar 16, 2009
  • 6 Answers
SOURCE: Our Kohler K3402 suddenly stopped flushing. When
If there is a shower in the same bath is it also draining slowly?
If so check that drain systems air vent, (on the roof).
Find the pipe coming out of the roof nearest the bathroom with the problem and when a second person flushes the toilet you should be able to feel
air moving in and out of the pipe with your hand covering the end. If not the vent could be blocked by leaves or animals etc., this vent has to be clear in order for water to drain properly.
Posted on May 20, 2010
  • 81 Answers
SOURCE: Just installed the cadet 3
The amount of water in any toilet bowl is determined by its construction and no tank adjustment will ever change that. American Standard has a history of having small water surface areas in their low or ultra low flush toilets. Take a large container of water and pour directly into the bowl. If the ending level remains the same, then that is the manufactured level for your toilet.
Not all tanks completely discharge all of the water when flushed. Measure 1.5 gallons of water into a container. Turn off your water supply to the toilet then flush normally. Replace the water in the tank with your premeasured amount and observe this new water level. You might be surprised to find it is at the same level it always is. Since water weighs more than 8 pounds per gallon, one concept used in todays toilets is to have more than 1.5 gallons of water in the tank and use the extra weight push the water past the flapper at a faster rate while designing the flapper to drop after only 1.5 gallons have passed through.
Posted on Sep 29, 2010
Testimonial: "Thanks. Looks like I will be taking this one back to HD. I have heard that the Kohlers are pretty good, any thoughts on them?"
I have a mansfield toilet and after flushing it keeps running, how can I fix that?
Not sure about your brand but many toilets have a flapper valve inside the tank which needs adjusting or replacing. Try this U tube link
How To Repair Mansfield Toilet
Apr 06, 2015 | Home
Why doesn't the waste go all the way down? It takes several flushes.
Welcome to our new world of water conservation. If you have a toilet that isn't newer....you have something in your trap weir. Or your flapper is malfunctioning. Or your float valve isn't filling your tank correctly. Or your bowl scouring ports could be clogged. There are sooo many things that could cause this....
.New toilets do this because their design to use less water has reached the point of no-longer working to clear the bowl contents. Plain and simple. It has became the norm to flush once for #1's and flush (how ever many it takes to flush all waste) for #2's.
Back to old styles...You can remove the tank top and inspect the water level in the tank(should be about a 1/2" below overflow tube when full), inspect the flapper(flush the toilet and see if your flapper is staying up long enough to allow enough water to enter the bowl to cause a syphon action that ends with a suction sound and complete emptying of the water from the bowl), flush your toilet and look in the bowl to see if the water spraying from your rim is adequately dispensing water to scour the sides of the bowl, and also look at the jet that shoots water from the bottom of the bowl...aimed toward the outlet portion of the very bottom of the interior bowl. This jet is what starts the syphon action that empties your bowl. If you have something stuck in your trap weir....you probably need to call your Plumber to auger the object out or break it down to a size that will pass into the sewer.
The small ports that spray your sides can be cleared with a 3/16" stiff nylon brush...the jet down below can be cleared with a 1" stiff nylon brush. Flapper malfunction is repaired by replacing the flapper. Incorrect water level in the tank can be fixed by adjusting the valve float. but chances are that if it is all of a sudden malfunctioning...it probably needs to be replaced...good luck and always know how to turn your water off before starting work on your plumbing.
Be gentle with the parts inside your toilet tank. Using a calcium remover when clearing bowl inner ports and jets will help tremendously....but be certain to read the container and follow all handling/use instructions you read. Be careful.....Nick
Mar 06, 2015 | Plumbing
How do I stop water running into pan after toilet has been flushed &refilled.
If there is water still running into the toilet bowl, there is a problem with your flapper or flush valve. The most common problem, and least expensive to fix, is the flapper has gone bad and is allowing water to escape past it. Replace the flapper and the water should stop running. If not, it is possible the flush valve or one of the seals holding it to the tank has gone bad and needs replaced. Try replacing the whole flush valve. They come in a kit that includes the valve, flapper, and seals.
Feb 26, 2015 | Home
My plumber installed a NEW Mansfield flush valve in my commode tank. The NEW valve STILL leaks , just like the previous valve !! Water is expensive here in Newnan, GA. Can you suggest a solution to this...
Hi jezdc9...
Readjust the float level in your tank, it is probably set too high, if it is it will always sound like it is leaking.
If that does not solve your problem then clean/replace the "Flapper Valve", it is the part that attaches to the flush handle also make sure that the Flapper Valve Seat is clean and not allowing water to leak by.
Free Answer...Please rate me
Apr 26, 2011 | Home
My Mansfield toilet flushes but only 1/3 of the water in the tank flows out during a flush and the bowl does not get enough water to flush everything.
Check the water level int he tank for it coming up to fill line in tank. Make sure the 1/4 " fill line from the fill valve is connected and in the stand pipe tube to allow water to fill bowl. Fluid master makes a flapper that has adjustments on it to increase or decrease water used to flush. It has a dial to move on it this would be another option if the above tried doesn't help.
Thansk and I hope this will help you with this problem.
Mar 26, 2011 | Mansfield Plumbing Products Home
Toilet runs slightly, can minimally depress the handle to release a bit of water, and it will stop. How to fix?
Toilet runs continuously or doesn't flush adequately
Jiggling the handle might work for a while, but if your toilet is always running or doesn't flush adequately, you need to perform these simple fixes that usually can tame a noisy, inefficient toilet.
Check the Chain
The chain attached to the rubber flapper often becomes loose, causing incomplete flushing and/or continuous running. To fix it, remove links from the chain using needle-nosed pliers until it's tight.
Check Water Level
Improper water levels can also cause problems with your toilet. This can be fixed by adjusting the ball ****, which is located next to the overflow pipe, the open tube to the right of the handle. Adjust the ball **** so the water comes to ½ " below the overflow pipe.
Clean the Surface of the Flush Valve
A continuously running toilet can also be the result of a faulty flush valve. Because the valve is made of rubber, it can decompose or warp allowing water to escape from the tank into the bowl. Clean the sealing surface to see if this will improve the seal. If too decomposed or warped the valve may need to be replaced.
Replace the Flapper
Remove old flapper and replace with a suitable replacement. Attach the flapper to the overflow pipe inside the bowl. Then attach the lever chain from the flapper to the handle lever making sure the chain is taut.
This video will help familairaize you with the flushing mechanism and the repair:
Dec 18, 2010 | Toto Drake ADA Compliant Toilet with...
My mansfield toilet 160 has a weak flushing problem
My toilet had same problem:
I thought it was a clog in the drain pipe.
But the problem was clogged holes where water flushes into toilet bowl.
Here's how I fixed problem.
Purchase:
Gallon of CLR calcium-lime-rust remover from Home depot.
Pumice stone from hardware store.
Home supplies:
Cut off bottom of empty clorox bottle to make container for CLR
Old 3" paint brush you don't use for anything else to apply CLR
Small cup to pour CLR into toilet flapper opening
Steps:
Look inside toilet bowl under rim and see holes where water comes out
Use brush and apply CLR to holes where water comes out.
Use pumice stone to scrape ... pumice stone will not hurt toilet surface.
Flush toilet to clear holes so far.
Turn off water to toilet.
Open flapper to drain tank.
Keep flapper open.
Use cup and pour dose of CLR directly into flapper opening.
(You can also pour CLR down overflow tube... but flapper opening puts whole dose directly onto problem)
Pour another cup of CLR into opening.
Notice how CLR starts coming out the holes into bowl.
Pour CLR down flapper hole until it runs easy and fast out of holes.
Close flapper, turn on water, toilet fixed.
Nov 22, 2010 | Home
My Mansfield toilet model 160 runs periodically for no reason. What is the problem? Do you have step-by-step instructions how to fix it?
The flapper is bad....and allowing water to go through into the bowl very slowly...You need to find the correct flapper for that toilet....even all Mansfield toilets can have different guts inside....then replace the flapper which is very easy to do...
heatman101
Sep 10, 2010 | Home
The flush valve gasket is leaking so the toilet water runs periodically
You prbably just need a new flapper valve. Buy one at Home Depot for a few bucks and it will, simply, snap into place at the base of the tank. Also, make sure that the chain is not too tight and cut off any excess chain after the flapper is installed.
Oct 26, 2009 | Mansfield Plumbing Products Mansfield...
Home Logo
76 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
